Transmission pump leak...need advice quickly. - JeepForum.com
post #1 of 13 Old 07-02-2013, 12:50 PM Thread Starter
brewcity1
Hey guys...my mechanic told me that my transmission pump has failed causing a leak at the seal. My tranny does leak...but would a transmission pump failure cause a leaking seal...or is it that the seal cant stop all the fluid from leaking?
He quoted me $1250 to fix it!
I do have a warranty...but it does NOT cover leaking or broken seals.
I need some advice please.
Thanks so much!
2004 Grand Cherokee Limited 4.7L
General Grabber AT2's 255/65/17
1" Addco rear sway bar
brewcity1 is offline
post #2 of 13 Old 07-02-2013, 04:10 PM
um7267
I just paid 450 for new seals and trans flush, sounds high to me but i dont know where to find a pump, maybe time to swap trans. It would be around 400 labor and the cost of the trans
2004 Lexus Es330, alive; 1999 Cherokee Sport
1998 Grand Cherokee, sold
1997 Grand Cherokee; Black and Gold, Limited 4.0....RIP 2005
to the good times and the bad, the family we have and lost, little brother 1988-2011
um7267 is offline
post #3 of 13 Old 07-02-2013, 06:20 PM Thread Starter
brewcity1
Thanks...thanks not what I wanted to hear.
post #4 of 13 Old 07-02-2013, 06:24 PM
dusterdude
How the hell did the pump fail causing a seal leak?thats a bunch of hokey crap.
dusterdude is offline
post #5 of 13 Old 07-02-2013, 06:36 PM Thread Starter
brewcity1
Thats what I am asking you guys? Does that make sense?
He said the pump if shot, and that is what is causing the leak.
He also said he's really not sure if the seal is busted or not until he takes it apart to make sure. However...can a broken pump cause a seal to fail? Or could the tranny fluid leak past the seal if the pump is broken and leaking a lot of fluid?
I obviously have NO idea about transmissions.
Thanks for the help.
post #6 of 13 Old 07-02-2013, 07:17 PM
PolkaPower
What I would do is make an account here and ask the question in the Ram or Dakota forum. The 360 46RE combo is very common in Dodge trucks. These guys have helped me out with tranny questions quite a bit.http://dodgeforum.com/forum/
PolkaPower is offline
post #7 of 13 Old 07-02-2013, 07:22 PM Thread Starter
brewcity1
sounds good...thanks (as always) Polka!
post #8 of 13 Old 07-02-2013, 07:43 PM Thread Starter
brewcity1
BTW...is it a hard job to replace the front seal (if broken) or the pump on a 5.9L transmission?
post #9 of 13 Old 07-02-2013, 07:48 PM
um7267
yes and no
replacing the seal is easy, dropping the trans is the hard part... i dont have a lift or way to move the trans out from under the body so i had to take it in
um7267 is offline
post #10 of 13 Old 07-02-2013, 08:01 PM Thread Starter
brewcity1
yes and no
Ahhh...gotcha. Sounds like I'll be taking it in as well.
post #11 of 13 Old 07-04-2013, 08:40 PM
dusterdude
The bushing in the pump is probably bad causing the seal to leak,you can replace both
post #12 of 13 Old 07-04-2013, 08:46 PM
David97
Some shops around me can almost fully beef up/overhaul a trans for that price. Well depending on what you want 1k-2k anyways.
If your gonna spend that much id look into something like that. Spending that much money why not beef it up a tad as well? Just my .02
David97 is offline
post #13 of 13 Old 07-04-2013, 11:52 PM
dnuccio
i did my pump seals myself. i had access to a lift at school. replacing the seals took 10 minutes. dropping and reinstalling the trans took around 6 hours total
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
