transmission pan leak - JeepForum.com
post #1 of 28 Old 08-03-2009, 11:31 AM Thread Starter
rjs1956
I just can't get my trans pan to stop leaking.Three times I have dropped the pan, changed the gasket, added silicon sealer, and reinstalled. I still have leaks.
The pan rim is not perfectly flat but I feel that I have done a good job banging it close to flat.
I am a novice mechanic. Are there techniques to using silicon sealer that I am not following? How flat must the pan rim be?
rjs1956 is offline
post #2 of 28 Old 08-03-2009, 03:25 PM
greasefingers
greasefingers's Avatar
1994 ZJ
If I am using a cork or rubber gasket I do not RTV on it because I install the bolts with a torque wrench (150 in-lbs) But many people use a small bead on the pan side only.
Currently I am using a ridge type rubber encapsulate metal gasket. This can be removed and reused. I love that gasket
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 28 Old 08-03-2009, 07:10 PM
Turbonut
Make certain it's coming from the pan and not from above.
Turbonut is offline
post #4 of 28 Old 08-03-2009, 09:26 PM
elmer_fud
I vote for trying a gasket.
Brian
95 ZJ, 5.2 V8,160,000 miles
Originally Posted by Speedycat View Post
I am not one to be changing lanes at 70 mph on a lifted truck on 33's, but since I am in Miami, I have to be prepared for the continuous influx of new drivers whose previous ride was a bicycle with wooden wheels.
Originally Posted by FPKites View Post
badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, badger, Mushroom!!! :D
Originally Posted by ZeeJay1997 View Post
Or just tie a 12 lb fish to a one foot pipe.
elmer_fud is offline
post #5 of 28 Old 09-29-2009, 11:22 PM
mrtosh
2005 WK
Can you get the ridge multi layer gasket be found at a parts store? Stealership?
Thanks in advance.
'05 WK Limited QDII, Superlift 6", Bilstein struts,315/70/17 Duratracs, Gibson CB, Volant CAI, JBA UCA's, JKS quick disco, adj. Rear trac bar, 4xguard armor, Diablosport Intune, Xenondepot 6000k HID's, Putco Jet yellow fogs.
mrtosh is offline
post #6 of 28 Old 09-30-2009, 01:38 AM
jeepheller98
also try grey RTV, it is more ridged. and has high oil resistance.. i used to use black on everything like diffs and such, but they would leak, i get no leaks with the grey
98 ZJ 3" lift homemade snorkel. JKS quicker disco 5.2L 150,000, 31x10.5 pro comp muds
jeepheller98 is offline
post #7 of 28 Old 09-30-2009, 10:00 PM
Fireball027
I am not sure if you have a zj or wj, but I had a leak on my zj that was driving me nuts. I thought it was the gasket, cause it was wet, but after leaving it on the hoist for a while I was able to pinpoint the leak. It was coming from the top of the transmission where the shifter mechanism enters the tranny and running down the side and around the gasket and then dripping from there.
Fireball027 is offline
post #8 of 28 Old 09-30-2009, 10:32 PM
Mopargearhead
What kind of Cherokee do you have and what transmission? If its a WJ with a 4.7L and a 545, you only use black RTV on the pan and no gasket. Any other transmission like the 42RE for instance, you can either use a cork gasket or a rubber reusable pan gasket with no silicone or any type of sealant. I have used the reusable gaskets at the dealership for years and never had an issue so those are the ones I prefer and recommend. If you have the 545 transmission make sure you clean the pan with brake cleaner to get all the oils and dirt off or else the silicone won't stick. Learned that the hard way when I first started working at the dealership.
Mopargearhead is offline
post #9 of 28 Old 10-01-2009, 08:33 AM
vansskaterfreek
i have the 46RE and ive tried everything, i tried the reuseable, the cork, even the paper gasket, right now i have black silicone.. havent tried the gray yet... i was just going to buy a new pan, figured it was warped
1998 ZJ 5.9L 122k miles - DD, 242 swap, 3.5" RE, 32" BFG M/T, safari rack, roof-mounted lights, custom steel front bumper with hitch reciever, 10k winch :)
2004 WJ 4.7L 107k miles - her daily driver, 2" daystar BB with scorpion shocks.. not too bad! stuffed 265/65/17 General Grabber AT2'S
vansskaterfreek is offline
post #10 of 28 Old 10-01-2009, 09:41 AM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Had the same problem with my 46RH. Tried everything, even a new pan. Ended up being the seal for the shift rod, appearing to be a pan leak. It was a bear to replace with the motor out. It would take a magician to replace it normally.
HighLonesome is offline
post #11 of 28 Old 10-01-2009, 01:15 PM
Mopargearhead
I've never run into a warped transmission pan before, but I guess its possible. The only ones I've seen leak really bad were where people either ran over a curb or slammed the vehicle down on a rock causing a huge dent. Like others have said check for a leak coming from above the pan. Your pan may not be leaking at all.
post #12 of 28 Old 10-01-2009, 01:34 PM
mrtosh
2005 WK
Soo just to clarify since I'm doing this this weekend, only use RTV if you have a 545? No gasket?
mrtosh is offline
post #13 of 28 Old 10-01-2009, 01:58 PM
mrtosh
2005 WK
10 characters
mrtosh is offline
post #14 of 28 Old 10-02-2009, 09:16 AM
Ved
I second that. I replaced 3 gaskets and even bought a new pan just to find out it was the seal for the shifting rod
Ved is offline
post #15 of 28 Old 11-17-2009, 08:41 PM
bcumby
So...I am having a similar issue, but the pan is all wet and I want to get a look inside so I am gonna tackle a sealand filter first just for grins.
My only concern on my 46RH is this talk of shifting rod leaking and I have found some fluid up around my oil filter, but I just had my rear main changed and the underside of my ZJ has been a wet mess since I got it, so I don;t know the origin of the fluid.
Any pics or steps for diagnosis? I have heard of a transmission actually leaking into the output area where the TC meets up and collecting fluid there too...
I am a skilled amateur mechanic, but transmissions scare me a bit. I am especially worried b/c I found it bone dry on the dipstick before I realized I had a problem.
Any advice?
Thanks,
Brandon
bcumby is offline
How hard to fix transmission leak? allready_gone ZJ Grand Cherokee Forum 5 10-01-2009 04:27 PM
Transmission Oil leak dwaned ZJ Grand Cherokee Forum 5 06-12-2008 04:29 PM
Transmission fluid leak. hanly2 ZJ Grand Cherokee Forum 7 05-03-2007 04:07 PM
Transmission Leak pcorad ZJ Grand Cherokee Forum 0 11-28-2006 07:31 AM
Transmission leak STJGCL93 ZJ Grand Cherokee Forum 3 09-30-2005 08:13 AM
