Transmission overdrive and lockup solenoid - JeepForum.com
post #1 of 3 Old 02-02-2013, 10:53 PM Thread Starter
ilive4cars0122
So today I replaced the governor pressure sensor and solenoid in my dads 98 4.0. Unfortunately I am running a 1762 code at the same time. My question is obviously i will replace both the solenoid and sensor to get mine in working order....but I was wondering is it possible to replace the transmission overdrive and lockup solenoid without removing the valve body while I'm in there for preventative maintenance? I was looking at the one in my dads jeep and it seems like there is 2 torx screws one on each side and one in the middle with a connector in the middle. I saw a youtube video however where they showed removing the valve body and pulling a harness through the outside of the transmission however. This pic is of the one in my dads 42re. I have the 5.9 and the 46re though.
ilive4cars0122 is offline
post #2 of 3 Old 02-03-2013, 12:55 AM
KoreaZJ
1994 ZJ
Solenoids/harness are together. VB needs to come out.
KoreaZJ is offline
post #3 of 3 Old 02-03-2013, 12:58 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Yep, have to pull it.
ratmonkey is offline
