Transmission not upshifting - JeepForum.com
post #1 of 10 Old 03-21-2001, 11:29 AM Thread Starter
jmsjeep
My 1997 limited w/ quadratrac will not upshift, it lets the rpm's go to 5500 - 6000 without shifting so I have to keep screwing with the gas changing the pressure until it shifts. Any thoughts?
I wonder were that dirt road goes?
'89 YJ 4 banger all stock, replacing all the worn out guts first, 97 grand cherokee limited
jmsjeep is offline
post #2 of 10 Old 03-22-2001, 02:16 AM
KCjeeper
I had mine in the shoplast week because it wouldn't drop-down into 1st gear when I came to a stop. Shop replaced the governer and it is working fine. Do you have a 'Check Engine' light on?
KCjeeper is offline
post #3 of 10 Old 03-22-2001, 12:31 PM Thread Starter
jmsjeep
No lights come on. Does downshift fine, just not up.
jmsjeep is offline
post #4 of 10 Old 03-29-2001, 12:14 PM Thread Starter
jmsjeep
Does any one have any ideas, I don't want to bring it to a shop, without attempting anything myself or at least getting some idea as to the actual problem. I am nervous about walking in with a "transmission problem" I won't know what to expect!!
jmsjeep is offline
post #5 of 10 Old 03-29-2001, 10:08 PM
horatio102
Interesting. If there was a problem it should have switched to the limp home mode where it sticks in 3rd gear full time. I'm just talking out my rump but I'd check for loose plugs and hoses under the hood and on the tranny. Wish I could help.
>shrug<
horatio102 is offline
post #6 of 10 Old 03-29-2001, 11:17 PM
J'sJeep
My friends ZJ started doing this same thing. It is the governor.
Slate 5.9, Rusty's 3", TC intake, Magnaflow catback, JKS discos, RE adj. Track bar, Scorpions, all skids and tows,
J'sJeep is offline
post #7 of 10 Old 04-03-2001, 01:07 PM Thread Starter
jmsjeep
Thanks I'll check it out
jmsjeep is offline
post #8 of 10 Old 04-11-2001, 08:28 PM
Daniel
Hi i am a new member. i had a friend that had a 97 that had the same problem with it reving up really high and not going any where. i belive they ended up replacing the whole trans. my trans has a lot of hard miles on it and it has held up though.
my name is Daniel i have a 97 Jeep Grand Cherokee V8 2wd, Green, custom intake bonnet with K&N cone, true duel side exit exhaust with dual high flow cats and magnaflows. my fastest time at the track is a 15.10 at 91 MPH and it made to 210 HP to the back tires.
Daniel is offline
post #9 of 10 Old 06-25-2001, 07:00 PM
speedo
hows your truck. id check the throttle position sensor.
speedo is offline
post #10 of 10 Old 07-12-2001, 02:23 AM
DMS
Years ago, I experienced the same problem. It wouldn't upshift unless I tried to force it by backing off on the gas. Eventually, it got to the point where it simply slid into neutral. Finally, I began to experience the problem where it hesitated going into Reverse. All of this usually happened during the first few miles, before everything "warmed" up.
The problem turned out to be bad seals in the transmission. They dried out, allowing tranny fluid to leak past them. With the loss of hydraulic pressure, the trans wouldn't shift properly. Once fully warmed up, the seals softened enough to work most of the time.
I was told that, regardless of what the manufacturer says, you need to change the trans fluid yearly. Apparently, there are additives to keep the seals moist. Sounds like a simple solution, but it appears to work. I've always tried to change the fluid as regularly as possible and have avoided the problem since.
Of course, replacing the seals requires almost a complete rebuild of the trans.
98 GCL 5.2l
DMS is offline
Transmission help... dr hook ZJ Grand Cherokee Forum 9 12-04-2008 08:05 PM
Transmission gone out?? irkorn18 ZJ Grand Cherokee Forum 2 06-26-2008 01:11 PM
Transmission, Few Q's Jmila1901 ZJ Grand Cherokee Forum 2 12-03-2007 01:37 PM
93 ZJ upshifting issues DrEvil11417 ZJ Grand Cherokee Forum 10 06-14-2007 03:58 PM
2nd to 3rd gear UpShifting issue Steve1999 ZJ Grand Cherokee Forum 13 12-06-2005 09:06 AM
