Transmission-No reverse - JeepForum.com
post #1 of 17 Old 12-06-2005, 07:18 PM Thread Starter
mmstone
Hello-
I drove all day with no problems. At the end of the day, I pulled into my driveway (very steep) and tried to put the Jeep into reverse...no go. Drive works fine. I thought it may be linkage...does anyone have any ideas?
Thanks in advance for any and all help!!
1997 GC Laredo 4.0 I6, Selec-track, 242 Xfer Case, 3.73 Rear, Rebuilt Transmission, 165K
mmstone is offline
post #2 of 17 Old 12-06-2005, 09:33 PM Thread Starter
mmstone
More info ....
Just got home to take a look at the Jeep (my wife made the above post). Anyway .... the jeep runs absolutely fine in drive. All shifts seem good and normal. Reverse is a no go. THe back-up lights come on and there is a slight whirring when the gas is depressed. There is a little movement but the vehicle doesn't travel.
Any ideas? Bands? If its a band, can just the band be replaced or are we looking at a rebuild?
Also, last week I had the shifter detent recall performed. Could something be messed up or shifted?
Thanks again for any and all thoughts!!
Jeff
mmstone is offline
post #3 of 17 Old 12-06-2005, 10:55 PM
FLAWLESS
Check your fluid level yet?
I used to have an old Ford truck that would do that when it was low on fluid.
FLAWLESS is offline
post #4 of 17 Old 12-06-2005, 11:01 PM
-Joe-
-Joe-'s Avatar
Any slippage when you are going into overdrive? (Try turning it off and back on as your driving and see how it shifts)
I had a slippage (more of a real rough shift) going to overdrive then lost reverse gear all together. (After i lost reverse and drove a bit i had a grinding noise that lasted about 10 seconds, it made it home but it got replaced)
I believe the reverse gear is part of the overdrive unit.
Could be:
Gearshift linkage damaged/out of adjustment
rear band is out of adjustment
valve body malfunction
rear servo or front clutch malfunction
overdrive unit direct clutch malfunction
(According to 42re service manual)
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 17 Old 12-07-2005, 09:24 PM
Jeep-Tech1
Sounds like a hard part problem. Like a planetary gear set or something.
Jeep-Tech1 is offline
post #6 of 17 Old 12-08-2005, 12:34 AM
PDshooter
I would disconect the trans, linkage and see if I can ingage it by hand in reverse. Make sure you have somone on the brake pedal...that you trust!
96 GC 117K 4.0
Sele-Trac
Retired guard 20yrs
MOS 63H 11B 43E
PDshooter is offline
post #7 of 17 Old 12-09-2005, 02:41 PM Thread Starter
mmstone
Update ...
I ended up taking her to a reputable transmission shop for further diagnosis ... They dropped the pan thinking that an "o" ring may have slipped off the selenoid. This was not the case ... and the bands were good shape and properly tightened. So ... you guessed it ... rebuild.
However, I did pick up a 12 month/18K warranty and its picking up $1100.00 (the cost of my dead trans being replaced with a used one) and I'll be applying it towards the rebuild. So its not as horrible as it could have been.
We should have her back on the road Monday or Tuesday.
Thanks for all the advice!!
mmstone is offline
post #8 of 17 Old 12-09-2005, 05:14 PM
Flyinbrick
Sorry to hear that. The tranny's hooked up to our I6 are the worst. I had a MOPAR rebuilt tranny put in back in April. Runs good now.
Do yourself a favor and have them install an external transmission cooler. If you plan on keeping the ZJ longer, it's a worth while investment IMHO.
Good luck.
BTW how much is the rebuild going to run you?
-Michael-
1997 TJ
White Custom Long Arm with Blue Torch Fab Stretch
Wagoneer Dana 44 Front End w/ ARB, Currie Rockjock 60 Rear w/ Detroit, 37" Baja Claws, Poison Spyder Tire Carrier, Competition Corners, Flat Fenders, Front Stinger, Full roll cage, GenRight Fuel Cell, Snyper Fab Rocker Skids
Flyinbrick is offline
post #9 of 17 Old 12-10-2005, 09:16 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
When they rebuild it, have them install a shift kit. It will help out a lot as well.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #10 of 17 Old 12-10-2005, 08:08 PM Thread Starter
mmstone
I'll call them on Monday and see if it isn't too late. If it's not ... what do you recommend I go with?
Also, is there anything that I should have done with the trans is out?
Just trying to be a bit pro-active for once.
BTW - The overhaul is running $1728.00. Surprisingly the warranty is picking up $1100.00 of that ... so it's no too painfull.
Thanks again guys and I'll be upgrading my account right now.
mmstone is offline
post #11 of 17 Old 12-11-2005, 06:11 PM Thread Starter
mmstone
Shift kit info ...
I hate to post again so quickly, but tomorrow is creeping up on me.
What type, brand, model ... etc. of shift kit should I get put into this? What excactly will it do? Just move the shift points?
Also, while the trans is out is there anything else that I should to to the Jeep?
Thanks again!!
Jeff
mmstone is offline
post #12 of 17 Old 12-11-2005, 06:23 PM
Meerkat
Go with the Trans-go shift kit.
It will firm up your shifts, and there are steps to increase fluid flow (lubrication) to the overdrive unit, which is sadly underlubed in stock form.
HTH
Warren
Black 1996 5.2L ZJ Limited
Meerkat is offline
post #13 of 17 Old 12-13-2005, 04:47 PM Thread Starter
mmstone
Well got her back today with a rebuilt tranny ... runs like a champ! Good thing it was under warranty though. I'm sure my wife wouldn't agree that a rebuilt tranny is a good xmas gift.
Now onto the next problem ... whatever it may be.
Thanks again for everybody's input on this matter. It is greatly appreciated.
mmstone is offline
post #14 of 17 Old 12-13-2005, 05:31 PM
Woody
Woody's Avatar
1985
Glad it's working now. Mine's getting a five speed on Saturday hopefully!
Woody
Woody is offline
post #15 of 17 Old 11-21-2015, 08:21 PM
mattshepp
Originally Posted by mmstone View Post
Hello-
I have the same problem right now.. idk wat is happening..
mattshepp is offline
Transmission sometimes slips when going into Drive or reverse? crmaverick ZJ Grand Cherokee Forum 6 02-08-2012 02:00 PM
transmission hard shifting from reverse to park intrevic ZJ Grand Cherokee Forum 2 10-07-2009 07:08 AM
4.0 Transmission ''clunks'' Or Sounds Like It ''drops'' When Shifted Into Reverse littlefdl ZJ Grand Cherokee Forum 3 04-07-2009 08:47 PM
transmission (no reverse) trinjgc ZJ Grand Cherokee Forum 2 12-11-2005 11:21 AM
Transmission/Reverse Problem. youngj21 ZJ Grand Cherokee Forum 3 12-06-2005 03:08 AM
