Transmission line problem,Please help - JeepForum.com
post #1 of 2 Old 07-17-2011, 02:19 PM Thread Starter
98ToughMudder
Hello guys,
I am a new member to the forum, And to the jeep world. I installed my radiator to my 98 jeep grand cherokee laredo, automatic, and the old transmission line that bolts up to the radiator isn't working with the new radiator, when i bolt up the trans line to the radiator, it bolts on fine but it leaks, my friend gave me the radiator with the jeep and the radiator is new, but idk if the radiator was for a v6 or v8, my truck is a v6. I just need to know what exact line i need which is the line that connects to the rad which is half metal half rubber, thats the one i need, the problem i had was that the bolt that bolts on to the radiator was to long for the inlet to connect to the fitting on the rad, so it would just pour out trans fluid. Can somebody help me figure this solution out so i know what i have to buy and have to do, thanks guys!!
98ToughMudder is offline
post #2 of 2 Old 07-17-2011, 02:36 PM
gothchick
Not sure I'm following exactly what the problem is. Would vinyl tape work on the threads to keep it from leaking? If not, you could always just clamp a length of trans hose on the fitting with a worm clamp. That's what I ended up doing when I added an aux tranny cooler. No leaks or issues.
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
94 ZJ transmission line leaking bad trans line clip? hvywt77 ZJ Grand Cherokee Forum 4 09-14-2010 10:16 PM
04 WJ transmission Return Line jimbob01 ZJ Grand Cherokee Forum 7 01-31-2007 04:32 AM
ZJ - transmission cooler line, I think jeep_on ZJ Grand Cherokee Forum 6 05-28-2006 12:37 PM
Need some advice on transmission line problem kamedley ZJ Grand Cherokee Forum 7 09-28-2005 01:45 AM
transmission fluid line crazymike0409 ZJ Grand Cherokee Forum 1 04-06-2004 06:47 AM
