Transmission line cooler - JeepForum.com
post #1 of 3 Old 06-25-2007, 09:22 PM Thread Starter
djdoug99
Changing out my radiator in my 96 ZJ and am having a very difficult time disconnecting the transmission cooler line, the one on the bottom, it says its a quick disconnect but It wont budge. It looks like it just slides down, but there is a white peice inside the retainer that sticks out with tongs on each side, do I grab these and do something with these?
Is there a special tool I need to do this or can I do it by my hand?
djdoug99 is offline
post #2 of 3 Old 06-26-2007, 04:55 AM
Yardman Harry
O
Yardman Harry's Avatar
You need a set of plastic pieces that looks like this
Pick them up at Advanced or autozone for about 13 bucks for the whole set
Harry
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #3 of 3 Old 07-21-2007, 08:50 AM
02_limited
I picked a set up like those. I assume they go over the rubber part, make sure it's tight fitting and apply a lot of pressure to pull of the rubber hose?
02 WJ Limited 4.7 Quadradrive
02_limited is offline
transmission cooler line Q@uestion rschuler ZJ Grand Cherokee Forum 18 05-04-2010 07:24 PM
transmission cooler line leak bigphil76 ZJ Grand Cherokee Forum 1 01-29-2010 10:43 AM
Transmission Cooler Line leaking... 1badjk WK Grand Cherokee & XK Commander Forum 3 10-25-2009 07:32 PM
Transmission Cooler Line Fitting Bricolage ZJ Grand Cherokee Forum 5 09-08-2009 08:44 AM
ZJ - transmission cooler line, I think jeep_on ZJ Grand Cherokee Forum 6 05-28-2006 12:37 PM
