Transmission Help? - Page 2 - JeepForum.com
post #16 of 24 Old 07-05-2013, 12:03 PM
ZeeJay1997
Originally Posted by ZeeJay1997 View Post
Filter kit comes with a new gasket. Use a felpro kit.
maybe I should have said filter kit comes with a new pan gasket. filter has built in gasket
ZeeJay1997 is offline
post #17 of 24 Old 07-05-2013, 12:13 PM Thread Starter
corndawg665
Oh ok that makes more sense! Thanks!
corndawg665 is offline
post #18 of 24 Old 07-05-2013, 01:49 PM
dnuccio
and when you go to drop the pan, dont pry on it to drain fluid out of it. i bent my pan and ive had it open 4 times trying to get it to seal.
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #19 of 24 Old 07-05-2013, 01:58 PM
970001zj
and make sure the gasket goes up square in between the pan and the case so it dosnt leak
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
post #20 of 24 Old 07-05-2013, 04:26 PM Thread Starter
corndawg665
Ok so I cracked open the hood and found that I'm missing the white clip used to hold the TV in place. Ill be making a trip to the junk yard tomorrow to get a new one.
post #21 of 24 Old 07-05-2013, 08:12 PM
Left_Clicker
alternate
Thats whats causing the weird shifts, I broke the plastic piece that connects my TV cable to the throttle body. Got another one at the JY for $15.
I wanted to add that if you are going to do the pan drop of your transmission, a no mess way to do it that I've found is to get a pump to pump out all or most of the fluid through the dipstick of the transmission. It leads right to the pan and you can just suck it all out before you drop it so that you don't get an ATF shower. Your driveway will thank me.
Pump was like $8 bucks from Menard's, worth it IMO.
Left_Clicker is offline
post #22 of 24 Old 07-05-2013, 09:18 PM
Afdude88
Or you could have an aw-4.....which has a drain plug. ::
Dana 35c behind a 242, behind an AW-4, behind a 4.0L Inline Six sitting over a Dana 30, all turning stock 215/75/15 tires and moving a 93 Grand Cherokee to places your truck only dreams of.
1998 Grand Cherokee:
4.0L I6
42RE
242 tc
2.5 OME lift
Afdude88 is offline
post #23 of 24 Old 07-07-2013, 01:27 PM Thread Starter
corndawg665
Ok so I dropped the pan, changed the transmission fluid and it came out really thick and dark red. Replaces the filter and stuff. Seems to be doing better so far...
post #24 of 24 Old 07-07-2013, 03:48 PM
Area11
Subscribed for all around info.
Area11 is offline
