Transmission Fluid Question - JeepForum.com
post #1 of 3 Old 07-18-2002, 12:05 PM Thread Starter
cdempsey
I have a '99 Grand Cherokee with about 34,000 miles on it. Per the maint. schedule in the owners manual it is time to change the transmission fluid and filter. But, I have been told by two people at NAPA that the transmission fluid and filter on my Jeep is good for 100,000 miles. Which is correct? When should I change it? Thanks for you help.
'96 XJ, 3" BDS lift, 31x10.50 Dueler AT's, Safari Brush Guard, Hella Lamps, Yakima Rack.
cdempsey is offline
post #2 of 3 Old 07-18-2002, 01:04 PM
Kess
go by what ur manu. sched says, this will not void warrently, and the first dose of anyfluid is good to change in about 1/3 of the time if the car was broke in
In comission:2004 WJ, stock....
Retired:1994 JGC Laredo I6 4.0L, Smittybilt Outland brush guard, 1 3/4" Daystar coil spacers, custom air intake with tube K&N, Borla cat-back, KC Daylighters 6" 150w stainless steel, Xenon superwhite headlights 85/100w, 235/75/15 Pirelli Scorpian A/T, billit aluminum grill inserts
Kess is offline
post #3 of 3 Old 07-18-2002, 08:59 PM
Drafter75
I agree with Kess... you don't want to void your factory warranty. What the heck would some counter jerk at NAPA know about WJ maintenance schedules anyway? Does he own one?
The maintenance schedule also calls for changing the transfer case fluid and front/rear diff oil at the same 30K interval. If you aren't doing this yourself, bring plenty of money to your dealer... these service items don't come cheap.
Drafter75
Proud V8 ZJ/WJ owner of
1993-1998-1999-2002 model years.
Have you hugged your Jeep today?
Drafter75 is offline
Transmission Fluid Change Question malibubts ZJ Grand Cherokee Forum 3 08-30-2009 06:50 PM
93 5.2L transmission fluid question ubu ZJ Grand Cherokee Forum 3 07-20-2009 03:09 PM
transmission fluid question? elmer_fud ZJ Grand Cherokee Forum 2 06-21-2008 08:53 PM
04 Transmission fluid change question... WoodiE55 ZJ Grand Cherokee Forum 9 05-10-2007 09:29 AM
Transmission fluid change question Stuart ZJ Grand Cherokee Forum 4 02-24-2006 06:30 AM
