Transmission dipstick - JeepForum.com
post #1 of 12 Old 09-22-2013, 05:46 PM Thread Starter
abraham743
Okay guys I could use a little help. To start I bought a bucket of 97 zj. I brought it home and rebuilt the transmission put a water pump on it and replaced all the bearings in the rear diff. I believe the transmission dipstick may not be the correct one. When pushed in all the way it pops out about a half inch. I think it hitting the bottom of the pan.
My Jeep is a 97 grand cherokee tsi 5.2 and 44re trans
If some one could look at their dipstick and see what the part number is I would appreciate it. Or if you happen to have a manual with the correct part number that would work too
Thanks for your help
abraham743 is offline
post #2 of 12 Old 09-22-2013, 05:51 PM
E55&98 Jeep
The two Jeeps I have do the samething.
E55&98 Jeep is offline
post #3 of 12 Old 09-22-2013, 06:20 PM
jm8881
Mine did that too, I just snipped about an inch off the bottom and haven't had a problem since.
jm8881 is offline
post #4 of 12 Old 09-22-2013, 06:23 PM
Higgins
Yup! Had same problem on 95, 96, and now 98's
AL
Higgins is offline
post #5 of 12 Old 09-22-2013, 06:24 PM
zjosh93
On my 93 the dipstick sat down perfectly fine in the original transmission. I put a junkyard trans in and the dipstick stuck up about 1/4". I lived with it for a while but the last time I changed the fluid I could see scratches where it was hitting the bottom of the pan. I cut 1/4" off the end and it's back to being perfect.
zjosh93 is offline
post #6 of 12 Old 09-22-2013, 06:46 PM
shaban
Actually, if you snip the end off, your oil level reading is not going to be correct.
As you snipped it off, the stick can go in further and for the same oil level it'd show more on the stick.
Nothing terrible but i'd put some extra marks on the stick with engraver to make up the difference.
shaban is offline
post #7 of 12 Old 09-22-2013, 06:55 PM
JasonStebbins
Mine does this if I don't put it in a certain way. Flip it around 180 degrees.
Poop
JasonStebbins is offline
post #8 of 12 Old 09-22-2013, 08:35 PM
zjosh93
My dipstick fit fine in my original transmission. It was too long once I swapped in a junkyard transmission. I used the original dipstick and tube so the difference must be the transmission pan. With everything original the fluid level was referenced to the top of the dipstick tube since the stick did not touch the pan. After I trimmed the stick it once again references the fluid level to the top of the dipstick tube. The top of the dipstick has a seal that's meant to seal to the top of the tube; this leads me to believe that Jeep meant the dipstick to fit all the way down the tube. I bent the tip a little to get it to stay down first but bending the tip skews the reading as much as cutting the tip and I like having my trans sealed.
zjosh93 is offline
post #9 of 12 Old 09-22-2013, 10:13 PM
ZeeJay1997
As you snipped it off, the stick can go in further and for the same oil level it'd show more on the stick..
The friction at the top should be holding the stick so it doesn't pop out of the tube. If you push the stick down into the pan all the way, the full mark will be at the correct level. Whether forcing it down or cutting it off, the full level is still the same distance from the top of the tube.
ZeeJay1997 is offline
post #10 of 12 Old 09-23-2013, 07:35 AM
Snowfan2
My 5.2 did it and my 5.9 does it. Snip 1/3 inch off the end of the stick and get a new O ring so it stays down and keeps dirt out, if you need one.
Snowfan2 is offline
post #11 of 12 Old 09-23-2013, 04:21 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
I wonder since mopar made the 99up 42re pans slightly deeper if it would fix this issue.
Originally Posted by HighLonesome
coralman is offline
post #12 of 12 Old 09-23-2013, 04:27 PM
chaZJones
same with mine. must be the angle
96 ZJ 5.2L 156k
chaZJones is offline
