transmission cooler line replacement - JeepForum.com
post #1 of 3 Old 04-28-2002, 06:40 PM Thread Starter
jimbo2
I have a 94 grand C. and need to replace the transmission cooler lines. are there any tricks or things I need to know in advance to keep me out of trouble or is it pretty straight forward. I do have the manual to guide me. thanks
jimbo2 is offline
post #2 of 3 Old 04-29-2002, 06:37 AM
Big Dumb White Guy
Big Dumb White Guy's Avatar
not sure. but if you don't get an answer here try <a href="http://www.jeepin.com" target="_blank">www.jeepin.com</a> or <a href="http://www.jeepsunlimited.com" target="_blank">www.jeepsunlimited.com</a> . you might get a answer there.
repost Nazi's suck!
A guy walks into the psychiatrist office wearing only Glad Wrap shorts. The shrink says, "Well, I can clearly see you're nuts."
Big Dumb White Guy is offline
post #3 of 3 Old 05-02-2002, 10:09 PM
kuzma97ZJ
you are going to need special pliers or little plastic tools that seperate the quick dissconnect fittings on the cooler and tranny sides of the lines. they look like little circles with a collar comming up through the middle. they are cheap and can be used over and over, mainly they are for fuel lines comming up to the fuel rail. I needed them when I did mine.
1997 grand cherokee 4.0L, forest green, 3" skyjacker, 1" spacers, adj. front track bar, skyjacker sway bar dissconnects, procomp steering stabilizer, 31" super swamper LTB's, safari bar w/ 2 KC's, custom roof rack w/ 2 KC's, tow hooks front and back, CB, dynomax turbo muffler, custom K&N filter charger, 2 12" sony explode subs.
kuzma97ZJ is offline
transmission cooler line leak bigphil76 ZJ Grand Cherokee Forum 1 01-29-2010 10:43 AM
Transmission Cooler Line leaking... 1badjk WK Grand Cherokee & XK Commander Forum 3 10-25-2009 07:32 PM
Transmission Cooler Line Fitting Bricolage ZJ Grand Cherokee Forum 5 09-08-2009 08:44 AM
Transmission line cooler djdoug99 ZJ Grand Cherokee Forum 2 07-21-2007 08:50 AM
ZJ - transmission cooler line, I think jeep_on ZJ Grand Cherokee Forum 6 05-28-2006 12:37 PM
