Transmission Cooler - JeepForum.com
post #1 of 2 Old 07-17-2006, 09:51 PM Thread Starter
bill9000
Transmission Cooler
Hi, I've got a '98 Grand Cherokee, and the transmission line going to the radiator has a nasty leak... factory wants $130 for a new rubber hose... I want to put an aftermarket transmission cooler on it, (they are like $40 instead), and bypass the radiator...
will this work on it's own???? it seems bigger than the area of the radiator that is reserved for the transmission...
thanks in advance for any help...
bill9000 is offline
post #2 of 2 Old 07-17-2006, 11:05 PM
sgarlic
An aftermarket cooler will work actually better than just the radiator cooler will.. especially if you mount the aux cooler in the air stream, like in front of the condensor.
bulkpart.com has some great coolers there.. and you can buy the adapter kit you need for an extra like 9 bucks if you want it.
96 5.2 Ltd - Flame Red - Every factory option except engine block heater,
, removed silencer, 15% tint.
sgarlic is offline
Get by without Transmission Cooler??? Nburns24 ZJ Grand Cherokee Forum 22 04-29-2009 12:53 PM
Transmission cooler fisher1630 ZJ Grand Cherokee Forum 13 02-25-2008 05:29 PM
Transmission cooler on 5.7 WK Podedwards WK Grand Cherokee & XK Commander Forum 5 07-08-2007 05:26 PM
Transmission cooler? DuneCrawler ZJ Grand Cherokee Forum 2 06-20-2004 10:43 PM
Transmission cooler baseball_coach WJ Grand Cherokee Forum 1 01-20-2004 01:58 PM
