transmission cable and wiper arms - JeepForum.com
post #1 of 2 Old 01-04-2003, 03:29 PM Thread Starter
automan25
Okay, here's two unrelated questions for you all.
1. - How do I go about removing the wiper arms from my jeep? I need to remove them in order to remove the plastic air vent grille. There are a bunch of pine needles stuck under that grille.
2. - How do I adjust the throttle cable? This is the cable that goes from the passenger side of the throttle body down to the transmission. According to my Chilton manual you need to adjust this whenever you remove and reattach it. The Chilton manual says that I should:
a - Press the throttle cable button all the way down, then push the cable plunger inward.
b - Rotate the primary throttle lever to the wide open throttle position.
c - Hold the primary throttle lever in this position and let the cable plunger extend
d - Finally release the lever when the plunger is fully extended
My problem with this is that I cannot find the throttle cable button. has anyone else done this before?
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
post #2 of 2 Old 01-05-2003, 01:28 AM
MJR
MJR's Avatar
1988
Pull the wiper arms up then pull the little lever on the side then let them down and you should be able to pull them off.
I wouldn't adjust that cable. It doesn't need to be readjusted unless you have a problem. Just unclip it and pull it out then when you are down put it back in.
"Got Groceries"
88 Jeep Wagoneer
MJR is offline
need help removing wiper arms on ZJ jeepguy2008 ZJ Grand Cherokee Forum 8 10-24-2008 09:05 PM
How do the wiper arms come off daveyboy43 ZJ Grand Cherokee Forum 9 08-25-2007 01:59 PM
removing wiper arms 99JEEP ZJ Grand Cherokee Forum 3 06-26-2005 08:51 PM
Removing Wiper Arms Kcolg ZJ Grand Cherokee Forum 1 03-07-2005 10:29 PM
Wiper Arms. TSFSU ZJ Grand Cherokee Forum 4 07-18-2004 05:00 PM
