Quantcast Transmission band adjustment - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Transmission band adjustment
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 01-02-2009, 02:06 PM   #1
98zjteen
I am going to change out the fluid on my 46re trans. (5.9L) While I am there, I was told that I should check the band adjustment. Should I re-torque the front and rear bands or should I just leave it. Currently, it is shifting hard and hits really hard on the kick down. Also, what filter does everyone run? I dont like Fram, plus it says that it should be replaced every 15,000 miles instead of 30,000.
98zjteen is offline   Reply With Quote
Old 01-02-2009, 03:01 PM   #2
98zjteen
Nevermind about the filter, I got a wix. Has anyone done band adjustments?
Old 01-02-2009, 03:29 PM   #3
Art101
http://www.jeepforum.com/forum/f13/transmission-band-adjustment-327109-post2765400/#post2765400
Art101 is offline   Reply With Quote
Old 01-02-2009, 03:43 PM   #4
98zjteen
thank you. does anyone have the service manual spec for the band adjustment on the 46re
Old 01-03-2009, 08:16 PM   #5
98zjteen
Nobody knows what the stock spec for adjustment is?
Glock Forum
