Transmission Band Adjustment - Page 6 - JeepForum.com
post #76 of 84 Old 05-28-2011, 10:21 PM
freakinheep89
For future reference since nobody has any RH specific write-ups on the adjustment: 46RH Pan service and band adjustment
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #77 of 84 Old 10-04-2011, 07:47 PM
dmextreme77
Originally Posted by TallyZJ View Post
I adjusted the front band on my 42re today using nothing more than a 3/4" deep socket, short extension, ratchet and a 5/16" small open end wrench.
I even did it with the transmission in place and did not remove any of the linkages.
Its tight there but it is doable.
I used the 3/4" socket to loosen the jam nut. Holding the band adjustment screw with the 5/16" wrench I backed the jam nut way out. I ran the band adjuster screw in and torqued it, then backed it off 3 1/2 turns. I marked one flat side with white paint marker so I could count the turns.
Using the small wrench again, I held the adjuster screw steady and used my left hand finger to run the jam nut back down till it seated.
I then used the socket to tighten the jam nut. Once the jam nut hits bottom you can tighten it and the adjuster screw will not move.
Shifting between first and second is night and day different now.
Yes! This is what I've been looking for. My 1st to 2nd is sloppy and longer than normal. I hope I can do this. Too bad ur in FL. Haha. Thanks for this info.
2001 Grand Cherokee 4L
-4"RC
-265/70 Treadwright's on JK Moabs
-Bunch of misc crap
dmextreme77 is offline
post #78 of 84 Old 11-05-2011, 01:53 AM
Darman
what tool works best for the band adjustment ?can i use a standard 6 sided socket or 12 sided?
Darman is offline
post #79 of 84 Old 11-05-2011, 02:37 AM
Yardman Harry
O
Yardman Harry's Avatar
neither, you need an 8pt socket
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #80 of 84 Old 11-05-2011, 02:53 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Or spline drive, does all kind of external fasteners. 4, 6, 8, 12, e-Torx.
ratmonkey is offline
post #81 of 84 Old 11-05-2011, 02:00 PM
woody96
The front band adjustment bolt is a pain to get to. Youre gonna need a wobbler and a couple of extensions. some models have a square head bolt. 5/16 8pt or 12pt should do the trick.
woody96 is offline
post #82 of 84 Old 11-14-2011, 12:32 PM
martin809
What will happen if you tighten too much. I have been callled to a buddys house and I believe he has tightened his to much. There is way to much play in the adjusting screw. I believe he went to far.
Can this be fixed in the drive way or does it need to be removed and rebuilt?
martin809 is offline
post #83 of 84 Old 09-11-2012, 01:18 PM
jwbrow2
I have a rebuilt transmission on my 94 GC laredo. I am looking to adjust the bands because the shifting is pretty hard and im not totally convinced that my 4.0 is this under powered. does anyone have pictures on how to do it or a guide?
jwbrow2 is offline
post #84 of 84 Old 10-16-2015, 09:27 PM
esidneyw
Hey all, I know this is an old thread, but I am doing this tomorrow on my 44RE '97 ZJ TSi 5.2L and wanted to make sure I understand everything. I have all the correct tools, fluids, cleaning solvents, gasket scrapers, etc. Correct me if I'm wrong, but from what I've read the front band adjustment is to torque to 72 inch pounds and then back off 2 turns. I have the service manual for my '97 and confirmed that setting (service manual says back off 2 1/4 turns). Now as for the rear band, from what I've read on this thread, you torque to 72 inch pounds and back off 2 turns. What I don't understand is my service manual (not haynes manual) says to back off 4 turns...So, which one should I do? 2 turns, 4 turns, or meet in the middle with 3 turns out?
esidneyw is offline
Location of front transmission band adjustment on a 4.0L 99 GC dirtyjeepdc ZJ Grand Cherokee Forum 4 07-09-2009 01:24 AM
ZJ Transmission band Adjustment -cAcHe- ZJ Grand Cherokee Forum 1 01-22-2009 11:49 AM
Transmission band adjustment 98zjteen ZJ Grand Cherokee Forum 4 01-03-2009 08:16 PM
Transmission band adjustment MNWJ ZJ Grand Cherokee Forum 1 10-23-2006 08:43 AM
Transmission Band Adjustment O Holy P ZJ Grand Cherokee Forum 1 04-15-2005 08:46 AM
