Quantcast Transmission Band Adjustment - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Transmission Band Adjustment
Old 11-30-2009, 10:57 PM   #46
4Slow9erHybrid
Originally Posted by Yardman Harry View Post
Here,
The 8 point socket is 5/16ths
and this is just a simple torque wrench, its been so long, not sure if I used an extension or not.
I did not drop the tranny at all. I was able to torque everything to spec!
I used the same 8 point 5/16th socket. I had my complete front axle off the Jeep at the time and had no need for an extension.
1997 JGC Laredo 4.0 4x4 94000mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is offline   Reply With Quote
Old 12-01-2009, 01:54 PM   #47
Machine15825
What does having your front axle off have anything to do with adjusting your transmission?? To get to the band inside the transmission it is almost impossible without a short extension or a deep well socket....
Machine15825 is offline   Reply With Quote
Old 12-01-2009, 02:24 PM   #48
4Slow9erHybrid
The adjuster for the front band is on the outside. I had the front axle off for a completely different reason. But that gave me easier access to that area. I'm not suggesting to pull the front axle to do this adjustment.
Old 12-01-2009, 03:01 PM   #49
Machine15825
Oh alright... Its on the outside on the side of the trans... Didn't think the front axle would have anything to do with getting to it... right?? Or is yours different than mine???
Old 12-01-2009, 03:18 PM   #50
4Slow9erHybrid
Try getting a torque wrench on the adjuster while you sit IN FRONT of the transmission (looking towards the rear). You will see that the front axle, driveshaft makes it hard for you to get in there, All I meant is that with the front axle off it might have given me access to that area from a better, more convenient position. Maybe that's why I did not need an extension. I don't know as I never adjusted it before.
Yes, mine is different than yours: 4.0 Laredo with a 5.9 Limited interior. Which of course has nothing to do with access to transmission.
Old 12-01-2009, 04:48 PM   #51
Machine15825
You don't need the extension for that adjuster anyway.... With drive shaft or without.... The drive shaft wasn't in my way at all... But okay... You need it for the one that you pull the pan to get... Thats what I was talking about using the extension for.
That's odd... I have a 4.0 in my limited... The limiteds came in 4.0, 5.2, and 5.9 supposedly in my year... My insurance says special addition on.... So that's got to make it cool ??
Infinity sound system, leather interior
Old 12-05-2009, 11:37 AM   #52
drespecki
So, with all the adjusting going on the 42re front band, what is the general consensus for backing out the adjuster? Some say 2, manuals say 3... I have it at 3 and think it is too loose.. If I go 2, will anything become damaged?
It only hurts while you're breathing..
drespecki is offline   Reply With Quote
Old 12-14-2009, 09:29 PM   #53
Rickyb
wait, do you NEED an 8point socket for the rear band in a 46rh? or what else would work
Rickyb is offline   Reply With Quote
Old 12-14-2009, 09:33 PM   #54
Machine15825
Torx bit will work too
94 YJ: 4" lift. 32-11.5-15's.
Old 12-14-2009, 09:38 PM   #55
Rickyb
okay sweet, im going to buy an in/lb tw wrench tomorrow. so are the only causes of bad bands just slippage?
Old 12-14-2009, 09:39 PM   #56
Rickyb
also what size torx bit
Old 12-14-2009, 09:41 PM   #57
Machine15825
buy a torx socket set it'll have it on the set. I don't remember what size. It will be hesitant shifting out of 2nd sometimes too. A lot of different things can be caused by band adjustment
Old 12-14-2009, 09:48 PM   #58
Rickyb
ahh i hope it fixes my issues if not im selling my zj for $1500 any takers ??
Old 12-15-2009, 12:29 AM   #59
Rickyb
one more question, when it say's 'loosen it x amount of turns' define a 'turn' is that a full 360 of the bolt?
Old 12-15-2009, 01:21 AM   #60
ratmonkey
Living dead mod
ratmonkey's Avatar
Areyouserious?
As for the socket. A regular torx will not do it. You may as well just go and buy a spline socket set. It'll do 8, 6, 12, and e-torx heads as well as partially rounded bolts.
ratmonkey is online now   Reply With Quote
Glock Forum
