Quantcast Transmission Band Adjustment - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Transmission Band Adjustment
Old 11-25-2009, 09:24 PM   #31
baxy
well
if you look at the lever for the bands
I tighten the front band adjuster until I can pry with a screwdriver and get 1/4 inch of clearance between the lever and the servo
same thing on the rear band but I'm looking for 3/8 inch clearance
you have to know exactly what the servo looks like to really understand
baxy is offline   Reply With Quote
Old 11-25-2009, 09:26 PM   #32
Machine15825
Well I've adjusted a cherokee to spec before so I was just curious.
Machine15825 is offline   Reply With Quote
Old 11-25-2009, 09:28 PM   #33
baxy
cherokee is a totally different transmission
the bands work differently than a torquflite
Old 11-26-2009, 09:49 AM   #34
WiCkeDuDe
WJ Jedi Master
WiCkeDuDe's Avatar
I've got a question about this as I am about to adjust the bands on a 42re. I see the FSM wants you to torque the locknuts to spec after tightening and loosening up the adjustment nut. How are you supposed to torque the lock nut if you still are holding the adjustment nut with a socket? Or do you just not worry about it and snug them up with a wrench?
WiCkeDuDe is offline   Reply With Quote
Old 11-26-2009, 11:03 AM   #35
4Slow9erHybrid
I just used a socket, turning little-by-little and checking often to make sure the adjuster stayed in place. I also marked the adjuster with lipstick so that I didn't make a mistake.
Good luck.
1997 JGC Laredo 4.0 4x4 94000mi * 0W30 German Castrol since 75k * 225/75/R15 Firestone Destination AT on Ravine rims * winter 235/75/R15 Bridgestone Blizzak DM-V1 * UC suspension * Monroe Reflex Monotube shocks * factory skids * KOR steering brace * rear Addco SB * Magnaflow cat and cat back system * complete 5.9 interior
4Slow9erHybrid is online now   Reply With Quote
Old 11-26-2009, 01:08 PM   #36
baxy
hold the bolt with either the 5/15 wrench or the torx which ever you have
use your 3/4 wrench to tighten the lock nut , I just go tight a sI can get it in the space provided
Old 11-27-2009, 12:10 PM   #37
WiCkeDuDe
WJ Jedi Master
WiCkeDuDe's Avatar
Yeah I figured it was just snugged up because I dont see how you can get a torque wrench on there at the same time. Ill give it a go this weekend. Thanks guys!
Old 11-30-2009, 01:52 AM   #38
BLACKzj52
baxy can you elaborate any more on the "feel" of the bands?
id like to adjust my front band and from what im reading its dam near impossible to adjust it with a torque wrench unless its out of the vehicle
can you drop the tranny xmember and let the tranny droop and gain access to the frontband by chance? i havnt ever seen anybody ask that question
- John - 22 and learning <-- ORIGINAL
-Black 96 ZJ Limited 5.2L V8 lifted 5" and blacked out with some fun stuff
My Build Thead
Facebook
RIP Troy Edwards
BLACKzj52 is offline   Reply With Quote
Old 11-30-2009, 07:37 AM   #39
Yardman Harry
O
Yardman Harry's Avatar
You can adjust the front band. You just need a special socket. Its an 8 point socket, since the adjusting bolt has a square head. Ill get you the size of the socket when I get home tonight.
I adjusted my bands when this thread was first started. I made sure my torque wrench was calibrated. I have been driving around with my adjustments since the start of the thread. (with better, smoother shifting I might add) So it can be done.
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline   Reply With Quote
Old 11-30-2009, 08:45 AM   #40
muddigger
Wow...0ver 3 years an no adjustment since initial...
Now that's impressive....
What adjustments did you decide to go with?
Thanx for keepin this thread alive....More and more of us noobs need help like this to educate and assist us with our NEW toys...
Willy
muddigger is offline   Reply With Quote
Old 11-30-2009, 12:28 PM   #41
georged
Yardman Harrry: Would you give us the make and model of your inch-pound wrench as some wrenches don't fit. If you used any angled extensions on the wrench also let us know.
georged is offline   Reply With Quote
Old 11-30-2009, 01:44 PM   #42
Machine15825
You are not supposed to use angle extensions to torque anything.... Let alone your transmission bands....
Old 11-30-2009, 09:27 PM   #43
Yardman Harry
O
Here,
The 8 point socket is 5/16ths
and this is just a simple torque wrench, its been so long, not sure if I used an extension or not.
I did not drop the tranny at all. I was able to torque everything to spec!
Hunter Green
White
~Junked~
Old 11-30-2009, 10:18 PM   #44
Machine15825
You should be able to do it with a short straight extension... Never use an angle extension when torquing.
Old 11-30-2009, 10:25 PM   #45
Yardman Harry
O
Yah if i remember correctly that's exactly what I used. A small straigth extension. Never use ujoint extensions
Hunter Green
White
~Junked~
Glock Forum
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
