#16 | |
Retired back to Bowties
Okay, if you have the bands improperly adjusted you can cause the tranny to overheat and fry the clutch packs and overdrive unit.
Adjusted too loose can result in really hard shifts, which are hard on all the other drivetrain components.
Woody 1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch. |
#17 |
Yea but it’s only people like us that are concerned about it. I believe it is unheard of to have the dealer adjust them?
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new |
#18 |
I always took my vehicles to garages not dealers prior to doing everything on my own, and they actually do care enough to adjust such things.
Dealers do only what they think you will look for.
#19 |
At 198,400 I have only brought my vehicle in twice to the dealer. Once for a re-man tranny and once for the viscous coupling. The only time I brought her in to a local shop was for a Cat replacement after I herniated two discs in my back. Everything else is driveway wrenchin. I have lately found a friend, no it is not my lazy computer-online –game freak son, but it is an air compressor. I wish I have bought one years ago!
#20 |
Ok guys, found the specs I used. Edited my first post, but wanted to let those interested know. Front band 1 1/2 turns out. Rear band 1 3/4 turns out.
zjhitman |
#21 |
Below are the band adjustment specs I snagged out of the forums section of www.ipttrans.com about a year ago. So far no one has mentioned the difference between the 1 and 3 piece rear band. My 99 GC has the 3 piece. Hope this is helpful.
*Always torque adjuster to 72 INCH lbs. (not foot lbs) before backing off the specified amount of turns.* Please note that these adjustments may vary from the factory service manual. A solid band looks like one piece whereas a wrap band looks like it's made of three sections (widthwise). 42RE Front band- back off 3 turns Rear band (wrap)- back off 3 1/2 turns Rear band (solid)- back off 2 turns 44RE- RH Front band- back off 2 turns Rear band (wrap)- back off 3 1/2 turns Rear band (solid)- back off 2 turns 46RE- RH Front band- back off 2 1/2 turns Rear band (solid)- back off 2 turns 47RE Front band- back off 1 3/4 turns Rear band (wrap)- back off 3 turns. |
#22 |
O
Hey guys, this is great info. Gonna go out and have some fun now.
Just a thought, but maybe this should be part of the FAQ? yell at me if this is a stupid idea, but just a thought for all the noobs like me out there. THanks again guys!
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green 1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end 1999 Mazda Miata MX5 - Jet Black 1990 Jeep Cherokee Sport I6 - 4.0 litre White ~Junked~ |
#23 |
What do you mean, this is in the FAQ.
Okay, I just put it there.
#24 | |
O
Hah, you made me feel like an even bigger noob when i read that! Thanks Woody.
#25 |
Hey, this is some great info, but (speaking of Noobs LOL ) could i see some pics of someone adjusting the bands? Or is it realy simple, like take off the pan, and their are two OBVIOUS bolts to turn in all the way and then out 2.5 turns??? My trucks got 156,700 miles on it and the tranny fluid is brown and i doubt this has ever been done.
#26 |
Is there any other socket I can use besides 15/64? I can't find that socket anywhere. I need to adjust my front band my transmission feels like it's slipping between 1-2 when I accelerate hard.
2000 Grand Cherokee Laredo 4.7L V8 Quadra-Drive 1987 Wrangler 4.2L |
#27 |
Anyone?
123
#28 |
I have a 1998 GC Laredo
It has a 4.0L What transmission do I have??? Nevermind 42RE Last edited by Machine15825; 11-25-2009 at 07:24 PM.. |
#29 |
I do them by feel
and I do them all the same 42RH to 48RE kind of hard to explain next time I get one in the sho pon my bench I will take some pics and show how I do them the torque methode is fine ... but I find both bands a little loose when done to spec |
#30 |
okay. you do them by feel?? You have got to explain...
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
