| Moto Alliance Viper Elite 8,000lb Winch Giveaway! |
| Jeep Registry | Register | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
Transmission Band Adjustment
#2 |
Do it early in the morning as you may have to run out to the store to buy the correct tool. I could not get to one of the bands, so I left it alone. If my memory is correct you need some type of crows-foot for one of the band bolts.
Cheers Steve Trained Professional Crack-pot Go RU & WVU Football Teams 94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new 03 4Runner V8 (my wife's car) 94 Volvo 850 (my 16-yr old daughter's car) Five cylinder 88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new |
#3 |
O
not having much experience with trannys, i have a question. If i know my bands havent been adjusted in 8 years at least, how would the performance of my tranny differ if i adjusted them? i know, a stupid question, but thank your for any responses.
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green 1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end 1999 Mazda Miata MX5 - Jet Black 1990 Jeep Cherokee Sport I6 - 4.0 litre White ~Junked~ |
#4 |
Can't help you there. Mine is a little sluggish engaging when starting out in reverse and a little slow in getting off in first. Seems like I'm carrying a load of bricks and I hope that a fluid change and adjustment will give it a little more pep. But my jeep has 155k on it and this could be as good as it gets. I fugure I can't do too much harm.
#5 |
Like you guys, I ran into the same problem with my 97 GC with the 44RE. I have both a Chiltons and a Haynes for it and both of them had different numbers for the band adjustments. I called the service manager at the dealer and he transferred my to their transmission guy and I asked him what he used. He had numbers for the front and rear band adjustments that were about 1/2 of the amounts listed in the Chiltons and Haynes. I used his numbers for the adjustments, changed the filter at the same time, put a drain plug in the pan and put it back together. I only did that once, and I don't have the mileage in front of me at the moment, but I think it was somewhere around 75-100K. I have over 250K on it now, and it's still doing o.k. My experience with automatics has taught me that the greater the number of turns out from snug, the slower and softer the shift happens because the piston that is tightening the band has to move further in the bore in the valve body. I think, but don't have hard evidence to back it up, that this slow engagement causes more wear to the bands and friction discs in the clutch packs. After adjusting per the dealer mechanic's specs , mine did shift faster and firmer. Just my 2 cents. If anybody wants those band adjustment specs, I can post them.
Found the specs I used: Front band - 1 1/2 turns out. Rear band - 1 3/4 turns out
zjhitman Last edited by zjhitman; 10-14-2006 at 08:36 PM. |
#6 |
Rford: I would like to go in and do mine as well, before it gets too cold out. Let me know what final adjustments you decided and if it made any difference.
Hitman: please post your adjustments as well. I might take an average of the FSM, IPT, your settings for a final value ![]()
#7 | |
O
my thoughts exactly, thanks for the great info.
#8 |
Retired back to Bowties
When I did my first band adjustment I went with the Haynes manual specs. Wow, the shifting was softer, but very defined. Every time I pulled the pan I did the adjustment. The only special tool I needed was a 15/64's socket for the front band. I know that's not the correct tool, but it worked for me.
Woody 1985 1 ton Suburban, Detroit diesel, 36" tires and no lift. Giving it's life to a K-5 that might fit down a few of my trails better. When you have to turn around, an 85 point turn sucks, and breakover angle on a Suburban sucks. |
#9 |
There was something in the way on re42 on one of the bands. I cannot remember what is was or what tool I need to coorect for this. But I know for sure that I could not get to one of the bands??
#10 |
Some sort of crows-foot jogs my mind? Maybe an off-set one. Woody are you saying that a regular socket was all you used?
#11 |
I seem to remember i couldnt adjust one of them as well. One was in a tight area I thought.
edit: I thought they both were inside, but i guess the front is on the outside of the trans. Shows what I remember. ![]()
- Joe - '95 Jeep Grand Cherokee Laredo I6 4.0L 242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs Moog Cargo Control Springs Magnaflow Converter - Dynomax Muffler 235/75/15 AT Uniroyal Liberator Tires |
#12 |
This has got me curious now. I will have to rip that pan off to investigate … soon.
#13 |
The one that's hard to adjust is not in the pan, it's on top. It's a pain with all the linkages, you need to disconnect a few things to do it right.
I think I had to move the tranny shifter and T-case shifter tojust the right place. It's been awhile, I like the 5-speed better.
#14 |
OK now I remember. The front band is on the outside and at the time I decided to skip it. The rear band is inside the pan and this is the one I adjusted.
From what my brain can process from the FSM (it’s been damaged by beer) the bands really don’t do a whole lot. The rear one slightly controls the reverse gear and the front one slightly controls second gear shift. The clutches are more important and cannot be adjusted. I guess changing the AFT every 30 k miles is the most important thing that one can do!
#15 | |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Location of front transmission band adjustment on a 4.0L 99 GC | dirtyjeepdc | ZJ & WJ Technical Forum | 4 | 07-09-2009 12:24 AM |
| ZJ Transmission band Adjustment | -cAcHe- | ZJ & WJ Technical Forum | 1 | 01-22-2009 10:49 AM |
| Transmission band adjustment | 98zjteen | ZJ & WJ Technical Forum | 4 | 01-03-2009 07:16 PM |
| Transmission band adjustment | MNWJ | ZJ & WJ Technical Forum | 1 | 10-23-2006 07:43 AM |
| Transmission Band Adjustment | O Holy P | ZJ & WJ Technical Forum | 1 | 04-15-2005 07:46 AM |
The time now is 03:04 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
