Transmission 42RE - JeepForum.com
post #1 of 4 Old 07-02-2004, 10:00 AM Thread Starter
DuneCrawler
Transmission 42RE
According to the manual on a '98 JGC 4.0L I6 with 42RE tranny, you should check the ATF in park while idling. The dip-stick indicates to check it in Neutral. It makes a BIG differance on the level, which is correct?
DuneCrawler is offline
post #2 of 4 Old 07-02-2004, 11:34 AM
greasefingers
greasefingers's Avatar
1994 ZJ
I asked the service mamager about this. He stated that it should be checked in neutral, at least for my 94ZJ. I noticed that it reads high if I check it in Park.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 4 Old 07-02-2004, 11:45 AM
Dalmask
Neutral's always been right in my experience. Park definitely gives a much higher level than neutral on the dipstick.
-Dal
Dalmask is offline
post #4 of 4 Old 07-02-2004, 11:50 AM
PlatinumZJ
Senior Moment Member
PlatinumZJ's Avatar
My 97 manual sez neutral.
Doug
Doug
When all is said and done, more is said than done.
Platinum '97 ZJ LTD, I6 (see profile) Paid for!
Links:
for ZJ & WJ stuff,
for performance stuff. I6 performance info at
Other stuff: Kevin's Roof Rack. KOR sliders, Bored 62mm TB, Blaupunkt Bermuda w/ ipod, Brembo Slotted rotors,
OME steering stabilizer, H4 headlight upgrade...
PlatinumZJ is offline
42re transmission pan pstack3315 ZJ Grand Cherokee Forum 2 04-11-2009 04:59 PM
42RE Transmission. Calamity ZJ Grand Cherokee Forum 2 01-04-2006 07:45 PM
42re Transmission??? 92cherokeesport ZJ Grand Cherokee Forum 9 12-27-2005 11:00 PM
42re transmission bikemanj7 ZJ Grand Cherokee Forum 19 10-31-2005 05:26 AM
Transmission Again!!! 42RE or 42RH??? crazynut52 ZJ Grand Cherokee Forum 2 02-07-2003 06:55 PM
