Transmision Jeep Zj 98, 5,2l - JeepForum.com
post #1 of 7 Old 04-01-2014, 01:34 AM Thread Starter
austriansgt
Hello !
Does anyone know which kind of problem it could be.
My Jeep shifts very late ( only first shift after motorstart) after that it shifts normally
Thanks
austriansgt is offline
post #2 of 7 Old 04-01-2014, 05:47 AM
JasonStebbins
It's normal to shift differently when it's not warmed up.
Check the dipstick while running warm in neutral. Adjust the TV/kickdown cable. Change the fluid and filter.
Poop
JasonStebbins is offline
post #3 of 7 Old 04-01-2014, 01:47 PM Thread Starter
austriansgt
Do you mean it really could be the oil and filter
That would be great
But it also happens when the engine/ transmision is already warm
but only the first time after start
Thanks regards
post #4 of 7 Old 04-01-2014, 08:01 PM
dusterdude
After you first start it,let it idle for about a minute and see what happens,let us know how it goes
dusterdude is offline
post #5 of 7 Old 04-02-2014, 11:35 AM
RangeDrive
Mine does the same thing... It shifts hard and late like around 1st and 2nd gear but after that it's ok
RangeDrive is offline
post #6 of 7 Old 04-02-2014, 11:49 AM Thread Starter
austriansgt
Ok i tried to let the engine run idle about 1 min
It was a little bit better but still the first shift is a bit later
After that shifting on the first gear is normal
First time about 2200 rpm
After that about 1700 rpm
post #7 of 7 Old 04-02-2014, 05:11 PM
dusterdude
Interesting,im out of ideas
