Transfer linkage???? -
post #1 of 2 Old 02-16-2014, 12:46 PM Thread Starter
I just had back surgery and I have my 17 year old son under my jeep to see if he can find out why my transfer shifter doesn't seem to operate anything. It seems that when we replaced the engine the transfer linkage popped out of the pivot bracket on the tunnel, (body side). I see that it is held on with what appeared to be four nuts, but they look like they are tack welded to the bracket, leading me to think that the bolts come through the tunnel from the interior? That means I will have to access them by removing the carpet between the driver's seat and the center console.
If this is accurate, can someone please let me know? My only other idea is to remove the trans mount and slide trans / transfer to the right far enough to get the linkage back in???
chiefjohnston is offline
post #2 of 2 Old 02-16-2014, 01:19 PM
Correct. I believe they are 10mm bolts that are in the passenger compartment/drivers side that fasten that bracket to the tunnel. Be careful to hold the female part of the fasteners in place so they don't turn when removing the bolts. I found out the hard way that it will destroy the rubber on them if they turn.
98Yeti is offline
In order to be able to post messages on the forums, you must first register.
