Transfer Case top nut.... - JeepForum.com
post #1 of 17 Old 03-31-2014, 07:10 PM Thread Starter
jmonty0523
So after having blown the hi gear completely outta my NP 242 over a month ago, i finally got the time to take the case outta her last Thursday. First time pulling a t-case, everything went well except for getting the top nut off. I pulled the tranny mount completely out and was able to get it off with a socket, universal joint, and assortment of extensions.
THERE HAS TO BE A BETTER WAY.
I have one of these on the way
http://www.sears.com/craftsman-9-16-...p-00914572000P
I think this should help, i hope.
I also picked up a long 9/16 combination wrench, about 10 inches long. If i heat and bend it, I should be able to get to it better, i think.
Anyone have any advise? I hope to have a better idea on to install by the time I get the new case.
...________oooo_
/ ./.\...,\_____ \,_____
[_---_______---_\-\\\\\\-\
(o) )-o---) ) (o) )-o---) )______
jmonty0523 is offline
post #2 of 17 Old 03-31-2014, 08:45 PM
JohnnyZJ
drop the tcase cross member and use a stubby 9/16 wrench. if you don't have a stubby get one.
there is no easier way. to make it easier, I picked up a ratcheting wrench that you can use on the other 5 bolts so you can save your hand/strength for that ***** of a bolt on top of the tcase
07' JKUR rollin on 35s
JohnnyZJ is offline
post #3 of 17 Old 04-01-2014, 07:35 AM
Snowfan2
Cut a spare wrench in half with a hacksaw. I go up from passenger side, feet at rear (R handed) after dropping trans a couple inches.
Snowfan2 is offline
post #4 of 17 Old 04-01-2014, 09:25 AM
localfiend
Yup, just did this on Sunday. Stubby 9/16 is the way to go. Harbor freight even has a nice set of ratcheting ones. Makes life so much easier.
2001 TJ 60th Anniversary Edition
1995 ZJ 4.0 w/ AW4 Swap
1966 Gladiator Pickup
1964 Gladiator Thriftside
localfiend is offline
post #5 of 17 Old 04-01-2014, 09:33 AM
ejschultz
ejschultz's Avatar
I used a quarter inch ratchet and a quarter inch 9/16 standard socket. I had no issues doing it that way. Either you guys are way over thinking it, or I just got lucky.
ejschultz is offline
post #6 of 17 Old 04-01-2014, 10:36 AM
JohnnyZJ
most (i reiterate most) 1/4" standard sockets sets that i've seen don't have a 9/16" socket, they all stop at 1/2"
JohnnyZJ is offline
post #7 of 17 Old 04-01-2014, 10:54 AM
ejschultz
ejschultz's Avatar
Yeah, but that's nothing a trip to Sears (or maybe even Harbor Freight) can't solve. I'm fairly positive the socket I used was a Craftsman.
post #8 of 17 Old 04-01-2014, 11:12 AM
zjosh93
The standard 1/4" Craftsman sets stop at 1/2" but you can buy larger as singles. I definitely have a 9/16" and I think you can get a 5/8" FWIW. Just the same as you can buy 1/2" drive sockets down to like 5/16".
zjosh93 is offline
post #9 of 17 Old 04-01-2014, 11:42 AM
ejschultz
ejschultz's Avatar
I can't remember what mine goes up to and my work computer blocks the part list from my set. I have the 309 piece mechanics set along with lots of other sockets and wrenches I've purchased for odd jobs.
post #10 of 17 Old 04-01-2014, 12:58 PM
Pierre_r
1989 XJ Cherokee
I use one of these and have never had a problem with the top bolt on the transfercases on any jeep:
They are also good for the startermotors on some cars, and to get to the nuts that are behind the turbo on any car/truck
Jeep Cherokee XJ 4.0 -89
Jeep Cherokee XJ 4.0 -90 (partsjeep)
Jeep Grand Cherokee 5.2 -93
Chevrolet Silverado 2500 6.5TD -94
Chevrolet C20 6.2 -82
Pierre_r is offline
post #11 of 17 Old 04-04-2014, 05:13 PM
Snowfan2
I like those and they would look great in my toolbox.
Snowfan2 is offline
post #12 of 17 Old 04-04-2014, 06:36 PM
bobinAZ
What are those called and where can I get me some?
I'm stuck in the "why not cycle" Since i have to do, A & B "why not" do C & D while I'M at it.
bobinAZ is offline
post #13 of 17 Old 04-04-2014, 07:09 PM
zarnold
What you need is a 1/4 to 3/8 adapter.
Here is one in a set: http://www.craftsman.com/craftsman-4-pc-accessory-set-1-4-in-dr/p-00942352000P?prdNo=8&blockNo=56&blockType=G56
But, I can't find the individual adapter.
zarnold is offline
post #14 of 17 Old 04-05-2014, 01:06 AM
WVZJ
1/4" ratchet does the trick. Just go buy a 9/16 socket in 1/4 drive
98 ZJ 5.2, LA n Locked, 242 sye, 35's
87 MJ, 4.0, 8.8, 33's, oba
07 Ram 2500 5.9 ctd
WVZJ is offline
post #15 of 17 Old 04-05-2014, 04:01 AM
Pierre_r
1989 XJ Cherokee
They are called obstruction wrench, you can get them in almost any size you need.
Look for them on ebay or in a toolstore where you live, if they dont have any they should be able to get some for you.
Pierre_r is offline
