Transfer Case Swap Info NP249->NP231 & NP242 - Page 95 - JeepForum.com
 13Likes
post #1411 of 3430 Old 01-07-2013, 10:01 PM
zturn13
Ok I'm sure y'all are tired of getting asked this I tried to skim threw the old post and learn what I could. If I'm understanding this right I have a 98 zj and anything from a 96 to 98 will work for the 249 to a 242 swap and its a direct swap except I might have to use a shorter drive shaft is this correct?
zturn13 is offline
post #1412 of 3430 Old 01-07-2013, 10:02 PM
comptiger5000
Correct.
comptiger5000 is offline
post #1413 of 3430 Old 01-07-2013, 10:09 PM
zturn13
Originally Posted by comptiger5000 View Post
Correct.
Thanks for the quick reply!! One more question. Will the one that would be with that transfer case(if I can find one together) work?
zturn13 is offline
post #1414 of 3430 Old 01-07-2013, 10:15 PM
comptiger5000
The DS that comes with the t-case will likely also be too long, as a 4.0 would have a D35 rear axle (your 5.2 has a D44a, which is longer than the D35). If you have an alternate method of transport, I'd see how it lines up with your current shaft, and if it's too long, then take it to a driveline shop and have them shorten it an inch or so.
post #1415 of 3430 Old 01-07-2013, 10:19 PM
zturn13
Ok sounds great! Thanks for the help
zturn13 is offline
post #1416 of 3430 Old 01-08-2013, 05:06 PM
Snowfan2
I bought a 231 off eBay for 150 bucks. It's out of a 98 Cherokee. Can't wait to get her in. She took a bit of damage on her way to my house but its easily fixed. Yee Haw...2WD!!!
Snowfan2 is offline
post #1417 of 3430 Old 01-08-2013, 06:29 PM
zachjf
Nice score on the xfer case, too bad the monkeys who delivered it couldnt resist throwing at your front door while driving by at 30mph
Needs parts?
PM
or
zachjf is offline
post #1418 of 3430 Old 01-09-2013, 12:44 PM
zturn13
What's the difference in a 242 and a 242j? So places list both so I'm assuming they are 2 different things.
zturn13 is offline
post #1419 of 3430 Old 01-09-2013, 01:08 PM
zarnold
242 and 242J should be the same, but some WJs got 242HD. So, if you can get a 242 from a 96, 97, or 98 ZJ you'll be in good shape.
zarnold is offline
post #1420 of 3430 Old 01-10-2013, 10:32 AM
ghatid
2002 to 1998?
Hey guys,
I recently picked up a 1998 limited with a bad transfer case hoping to fix it up and learn something while I did it. I took out the xcase and ripped it apart and it looks like it's the VC (obviously) that's bad since nothing else seems to have any damage.
I've been reading this thread, and others, and I've decided the cheapest way for me to get this car rolling (other than taking out the front drive shaft) is to get a 242.
Does anyone know if I can use a 242 from a 2002 Grand Cherokee and stick it in my 98? I'm willing to do the input shaft switcharoo...I've dug around, but I couldn't find much information about the 2002 242's.
*edit* Okay! Well, cancel that. There seems to be a lot of information about this, I just have to use WJ and XJ instead of the years:-D. Hehhh...sorry. Ignore!
ghatid is offline
post #1421 of 3430 Old 01-10-2013, 10:47 AM
Snowfan2
I'm thinking about hacking 1" off my output shaft instead of shortening the driveshaft.
Anyone have a problem with that?
Snowfan2 is offline
post #1422 of 3430 Old 01-10-2013, 12:06 PM
comptiger5000
I cut mine, but don't do more than a 1/2". Any more than that, and it's the outside of the piece of the driveshaft that's what hits, so you'll gain nothing from cutting more.
post #1423 of 3430 Old 01-10-2013, 12:45 PM
zarnold
^this
The yoke will most probably hit the oil slinger on the tail piece, if not you should be OK.
zarnold is offline
post #1424 of 3430 Old 01-10-2013, 12:48 PM
comptiger5000
Originally Posted by zarnold View Post
^this
Yep. With the shaft un-cut, it'll bottom out with about 3/8 to 1/2 inch of clearance to the slinger. Cutting it gives you that little bit of extra travel.
post #1425 of 3430 Old 01-10-2013, 01:53 PM
Snowfan2
Thanks. I'll pre fit the yoke and see how much room I have available to trim, go from there.
Snowfan2 is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
