Transfer Case Swap Info NP249->NP231 & NP242 - Page 90 - JeepForum.com
 15Likes
post #1336 of 3442 Old 11-08-2012, 09:16 AM
mangle
Anyone know what size nuts are used to secure the TC to the trans?
This site lists the studs as M10x1.5 and the nuts as M8x1 (one, M8x1 is weird... two, they should obviously be the same thread).
http://www.factorychryslerparts.com/...category=20586
Have a better answer?
*edit* Looks like they're M10x1. Weird. Another post on this site mentions 3/8"-24.
mangle is offline
post #1337 of 3442 Old 11-09-2012, 05:43 AM
Proph2010
1994 ZJ
Im pretty sure they were all the same bolts and it was 9/16.
Proph2010 is offline
post #1338 of 3442 Old 11-10-2012, 07:06 PM
zachjf
Has anyone here managed to take a WJ 242 that has the speedo sensor provision and just cut the hole out to use the ZJ speedo sensor? I was looking at a WJ 242J in the yard and it has the hole in the rear tail shaft housing but its got a small cast in section blocking the actual hole, the small retainer hole is even there just no actual speedo sensor hole.
Needs parts?
PM
or
zachjf is offline
post #1339 of 3442 Old 11-10-2012, 10:57 PM
dnuccio
less work just to find a ZJ or XJ case
dnuccio is offline
post #1340 of 3442 Old 11-11-2012, 04:30 PM
zachjf
Trust me I'd rather find a case that I can just swap in like an XJ/ZJ case but the thing is around here newer jeeps never hit our U-Pull-It yards, they get cherry picked by the wreckers who extort an enormous amount of money for used Jeep parts. I called around my local wreckers and the best I could find was a 96 ZJ 242 case with 200k on it for $250! To get a nice 97 XJ case w/ 100k they want almost $400. Its either Craigslist, which again has nothing in terms of 96+ vehicles or making something else work.
If all it takes to make the newer 242 a bolt in swap is to remove the tailshaft housing, take a hole saw to the speedo sensor hole and tapping threads for the hold down bolt I'm all over it, it'll save me $300 since I can get the case for $100 and maybe 45 min worth of work
This is the 242 case I'm looking at;
Needs parts?
PM
or
zachjf is offline
post #1341 of 3442 Old 11-11-2012, 10:59 PM
dnuccio
I don't think it's that simple. The Speedo gear is driven by a set of "splines" on the mainshaft. If the wj case doesn't have the provision for the sensor, it most likely doesn't have the required splines to turn the sensor. Sure you could swap the mainshaft, but by the time you buy a new shaft, its cheaper and less work to buy a whole zj or xj tcase and be done with it
dnuccio is offline
post #1342 of 3442 Old 11-11-2012, 11:33 PM
zachjf
I don't think it's that simple. The Speedo gear is driven by a set of "splines" on the mainshaft. If the wj case doesn't have the provision for the sensor, it most likely doesn't have the required splines to turn the sensor. Sure you could swap the mainshaft, but by the time you buy a new shaft, its cheaper and less work to buy a whole 242 tcase and be done with it
After looking at exploded diagrams and parts lists it appears that 4.0 WJ 242 cases do in fact have the speedo drive splines on the main shaft whereas 4.7 V8 242's do not, the 242 in the 4.7 uses a completely different mainshaft, tailshaft housing etc. I just sent emails off to a couple NP/NV parts suppliers to double check their listings of the mainshaft part number interchanges so I'll know for sure in a few days.
Needs parts?
PM
or
zachjf is offline
post #1343 of 3442 Old 11-12-2012, 08:50 AM
dnuccio
After looking at exploded diagrams and parts lists it appears that 4.0 WJ 242 cases do in fact have the speedo drive splines on the main shaft .
huh. I never would've guessed. Interesting
dnuccio is offline
post #1344 of 3442 Old 11-12-2012, 08:23 PM
JakeC132
I have a 95 zj 5.2 with a late 95 np249. just pulled it out this week to swap in a np231 from a 96 xj. they are apart right now and the gear cut is in fact the same. Do i have to also swap the input bearings or should they be the same?
JakeC132 is offline
post #1345 of 3442 Old 11-12-2012, 09:36 PM
Georelle
I have been reading through this to get ready to swap out the 249 in my '93 5.2 ZJ. After reading through many many pages I think I have it mostly figured out. I am looking at a 231 out of a 93 XJ not far away that I will swap in then do the input shaft swap.
I must throw my humble opinion out here on the sensor and switch for the VIC indicator. There seems to be a lot of concern and time spent on this. Mine was beeping at me every 5 minutes with a "Service 4wd Switch" warning when I bought the Jeep a year ago. So I basically defeated it. Took about 15 - 20 minutes. I figured that if I need the VIC to tell me where I have the transfer case shifted I am in deep trouble anyway.
So here is a simple option to defeat the TC sensor at the VIC so you don't have to worry about what is going on at the TC sensor. The VIC just shows all four wheels lit up for me now. This diagram is if the VIC is already wired up for your 249. Be sure to tape off the end of the cut wires that will not be reconnected. And the one that is connected to ground can be cut long enough to put a wire lug on the end to screw to the metal behind the VIC, there was already a hole there for a metal screw on mine.
Georelle is offline
post #1346 of 3442 Old 11-12-2012, 10:11 PM
dnuccio
easier to just disconnect the plug from the sensor, thats what i did
dnuccio is offline
post #1347 of 3442 Old 11-12-2012, 10:12 PM
dnuccio
input bearings will be the same
dnuccio is offline
post #1348 of 3442 Old 11-12-2012, 10:13 PM
dnuccio
is it just me, or does the tag say 242 WJ? i always thought they just said 242 J for jeep
dnuccio is offline
post #1349 of 3442 Old 11-12-2012, 10:41 PM
zachjf
I dont have a picture of the one I'm thinking of buying but here's one just like it.
I honestly dunno what the difference is I because I've seen WJ's that say both 242J and 242WJ, both 6 cylinder Laredo models 1 model year apart, 2001 & 2002.
Needs parts?
PM
or
zachjf is offline
post #1350 of 3442 Old 11-12-2012, 10:55 PM
Wulff
This is not as easy as it seems, I am a Journeyman toolmaker and this casting would need more than a simple hole saw, it would have to be set up in a vertical mill and using a boring head machined out. The tricky part would be trying to find out the exact location so the gears mesh properly. Second the sealing wouldn't be there and it would leak oil like crazy.
Wulff is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 08:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 01:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 05:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 07:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 12:50 PM
