Transfer Case Swap Info NP249->NP231 & NP242 - Page 71 - JeepForum.com
 12Likes
post #1051 of 3412 Old 02-08-2012, 06:22 AM
csouers
My 242 ESY swap on my stock 5.9 required rear dshaft work. We took an inch off.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #1052 of 3412 Old 02-08-2012, 09:23 AM
2GPS4ME
This is why I chose to go with the 231. The measurements are identical.
But the 242 is a nice TC, though....
Narrow Road Jeep Garage
Owner, Operator
2GPS4ME is offline
post #1053 of 3412 Old 02-26-2012, 01:41 PM
elkski
Before I read all 71 pages of this.. Why does one want to change out TC's?? I have a 93 GC 5.2
elkski is offline
post #1054 of 3412 Old 02-26-2012, 01:46 PM
KingtheZJ
blown viscous coupling in a 249 causing binding on turns. 242s and 231s are abundant and cheap
or, the ability to run a front automatic locker on pavement. or smoother operation having a rear automatic locker.
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #1055 of 3412 Old 02-26-2012, 02:00 PM
cttandy
Don't forget improved fuel mileage, stronger components, the ability to do 2wd burnouts, better traction offroad.
So to summarize
BETTER, BETTER, BETTER, BETTER, BETTER, BETTER, BETTER
SOLD - 1998 Jeep Grand Cherokee 5.9 Limited - stock 120,000 miles, NP242 conversion,1999 Jeep Grand Cherokee 4.0L Limited 4x4- Stock, 1999 Jeep Cherokee 4.0L 4x2 - Stock, 1987 Jeep Cherokee 4.0L 4x4 - Stock, 1987 Jeep Grand Wagoneer 4x4 - From from stock, far to much to list here
cttandy is offline
post #1056 of 3412 Old 02-26-2012, 02:06 PM
KingtheZJ
any reports of increased mileage are negligible. front axle still spins w/o lockout hubs. no overall increase
stronger components
the 249 has the highest torque rating
i'll agree with this!
'88 XJ
post #1057 of 3412 Old 02-26-2012, 02:09 PM
cttandy
I wouldn't call jumping from 13.5MPG to 18.5MPG negligible. I tried everything I could before swapping the TC. The results were worth the effort.
Granted, there was probably a lot more problems under the surface.
cttandy is offline
post #1058 of 3412 Old 02-26-2012, 03:26 PM
E-rok
I swapped in a 242 and run 2WD for the most part and found no noticeable gain in MPG.
unless you have disco hubs, its not going to make much diff.
2011 WK2 Laredo X Hemi
2013 Ram 2500 Cummins
E-rok is offline
post #1059 of 3412 Old 02-26-2012, 03:29 PM
KingtheZJ
i had 0 gain from the swap. you definitely had something else going on.
'88 XJ
post #1060 of 3412 Old 02-26-2012, 04:13 PM
Dyn0mitemat
x2 i didn't gain any mpg at all doing my swap
Actually lost a bit because i'm skinny pedal happy now drifting it around corners
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #1061 of 3412 Old 02-26-2012, 06:10 PM
cttandy
Before the swap, when I took my foot off the gas to coast, the jeep would just start stopping. Afterwards, it would coast great, even if I put it in full time 4wd it would still coast.
By the end, the 249 was only putting power to the front wheels. Made for some pretty awesome front wheel drive burnout's though.
cttandy is offline
post #1062 of 3412 Old 02-26-2012, 06:13 PM
comptiger5000
Then your 249 was screwed far worse than a bad VC, or your tires weren't matched front to rear (or the pressures were noticeably different).
comptiger5000 is offline
post #1063 of 3412 Old 02-26-2012, 07:49 PM
moldeck
OK im in the middle of the input shaft change. I turned the gear in the big fork around a couple times... not sure which way is toward the tail shaft. I am guessing that the thinner side goes toward the tail shaft. Can someone confirm this?
moldeck is offline
post #1064 of 3412 Old 02-26-2012, 08:08 PM
Dyn0mitemat
Your description left me clueless as to what your talking about, get a picture of what parts your talking about
There's not much in the cases that can be installed backwards, most likely if you can bolt it all together and run the shifter through the modes and everythings turning like it should you probably won't have a problem
post #1065 of 3412 Old 02-26-2012, 08:43 PM Thread Starter
JrMechanic
The low range (lower of the two forks) hub goes with taller portion facing down into the input assembly. The hub should be pretty much level with the fork once installed.
The mode sleeve goes with the taller portion and teeth facing up towards the rear of the case.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
