Transfer Case Swap Info NP249->NP231 & NP242 - Page 69 - JeepForum.com
 15Likes
post #1021 of 3442 Old 01-28-2012, 03:41 PM
Dodgeram1989
1976 FSJ Cherokee
I have a 242 with the old gear cut, and a 249 with the new gear cut. I have swapped the inputs before. What else do I need to swap over to make it work.
97 ZJ - Stock again
1976 Chief AMC 360 6 in lift, 35 inch tires
Dodgeram1989 is offline
post #1022 of 3442 Old 01-28-2012, 07:16 PM
E-rok
Originally Posted by JrMechanic View Post
Yes, the stock gear used with 3.55's is perfect for 31's and 3.73's. I have the same combination and at 65 MPH I read 66 on my GPS.
I wish I would have read this before I did the swap!
just finished up putting the 242 in, was pretty straightforward since it was from a 96. only thing I swapped over was my 3.73 speedo gear (I guess I should swap it back over)
I had to use the donor driveshaft because the one from mine bottomed out and I couldnt even fit it on the axle yoke. however, the donor shaft is about halfway on the output shaft, from the looks of the wear marks, it seems like it is about 1" further off than when it was on the donor. id say it has about 2" on the splines, think it will be OK?
I dont know what to do otherwise.
but anyways, the 242 shift rod is about 1" longer, but I didnt use it, I reused all the 249 stuff except the tab on the TC. shifts into all gears fine, but its on the edge of the adjustment rod. I assume the longer shift rod would place it more towards the center of the adjustment rod. wouldnt make any difference in how it shifts....
just have to do the VIC wiring and modify the bezel to use a XJ bezel pattern.
2011 WK2 Laredo X Hemi
2008 XK Overland Hemi
2015 F150 3.5 Ecoboost
E-rok is offline
post #1023 of 3442 Old 01-28-2012, 07:17 PM
E-rok
you need to swap the 249 front case onto the 242. I was going to do that but I knew if I opened them up, id end up rebuilding it and buying a new chain, so I just bought another 242 from the proper year to save some money and time
E-rok is offline
post #1024 of 3442 Old 01-28-2012, 07:21 PM
RedneckZJ
i got a 242 out of a 97 today. so other than shortening my rear ds an inch it should swap right in ?
'96 ZJ Orvis 5.2L (Mossy Oak Edit.)- UC+2" BB, Thrush Turbo, 2 12s, Lots Of Stickers
You drive a tj, we drive a zj. We have more power while you get more shower. We get the v8 while you get there too late. You have 2 doors well, we have 2 more. Ours costs a grand while yours has a price we cant stand.
RedneckZJ is offline
post #1025 of 3442 Old 01-28-2012, 07:45 PM
E-rok
yep
E-rok is offline
post #1026 of 3442 Old 01-28-2012, 07:51 PM
RedneckZJ
awesome. dont i need the shift plate or whatever it is to make the shifter work
post #1027 of 3442 Old 01-28-2012, 08:05 PM
E-rok
just the tab on the transfer case. the one on the 429 is too long. but all the linkages and whatnot on the jeep is fine. the 249 gate doesnt have the zig zag shift gate pattern that 242s have, but it will go into all the gears just fine.
E-rok is offline
post #1028 of 3442 Old 01-28-2012, 08:23 PM
RedneckZJ
ok so as long as the little tab is there im good? awesome it came with it...now gotta find time, and a ride up to get my ds shortened
post #1029 of 3442 Old 01-28-2012, 08:25 PM
E-rok
yea thats all I used and it shifts fine
E-rok is offline
post #1030 of 3442 Old 01-28-2012, 08:42 PM
Taz360ZJ
1994 ZJ
Originally Posted by E-rok View Post
yep
So the rear drive shaft has to be shortened on a '96+ ZJ w the 44RE trans & using a '96+ 242 exposed tail output shaft?
'94 ZJ, AX15, UC+BB, Ravine's, 31's, 3.8L fan, D2S's, fully murdered out.
Taz360ZJ is offline
post #1031 of 3442 Old 01-28-2012, 08:45 PM
RedneckZJ
thats right...at least what ive heard. an inch seems to be what everyone says
post #1032 of 3442 Old 01-28-2012, 09:02 PM
Taz360ZJ
1994 ZJ
Interesting. On my 5.9 w the 46RE i used the stock rear drive shaft, there was maybe 1" of travel left before it bottoms out. I left it like that since i went with a 2" lift & never had an issue
Taz360ZJ is offline
post #1033 of 3442 Old 01-28-2012, 09:06 PM
RedneckZJ
maybe itll work on my 5.2 then...since they both have the d44a and afaik the 44 and 46 re are externally the same
post #1034 of 3442 Old 01-28-2012, 09:06 PM
E-rok
must vary from rig to rig or something because I dont think my stock shaft would even fit
E-rok is offline
post #1035 of 3442 Old 01-28-2012, 09:07 PM
E-rok
see my quote above. maybe ill go under tomm and hold my original shaft up again and see how it looks. but the way I see it, id rather have a shaft fall out over having a shaft bottom out....
E-rok is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
