Transfer Case Swap Info NP249->NP231 & NP242 - Page 68 - JeepForum.com
 13Likes
post #1006 of 3430 Old 01-16-2012, 08:56 AM
Sublime69
I have reading this reading thread because i want to get rid of my 249. I am just confused on which tc i should look for in the junk yard. I have a 93/AW4/249. Which is the best tc to get and is there one that is just a straight bolt in? Or am i defiantly going to have to swap the inputs?
Sublime69 is offline
post #1007 of 3430 Old 01-16-2012, 09:22 AM
comptiger5000
Being that you have a 4.0, a 242 from a 93 - 95 4.0 ZJ, or 92 - 95 4.0 XJ should bolt right in (I'm not positive that those were all the same input, but I'm pretty sure they are).
comptiger5000 is offline
post #1008 of 3430 Old 01-16-2012, 09:43 AM
Sublime69
Thanks..can anyone else verify this?
post #1009 of 3430 Old 01-19-2012, 04:52 AM
Berti
Hello All,
I'm Berti from Hungary and just finished the swap on 96 ZJ. I took a NP242 from 90 with a 0.750 input. The old 249 had a 0.840 input, and after measuring the position of the output seal, I've decided not to change the inputs. Just to be sure, before installation, I disiassembled the 242, cleaned, renewed the seals. The swap went well, I could adjust the shift linkage, speedo is also working, the only problem is, that cable for the shift indicator is too short. But I can live without a properly working VIC. My decision was right, it is not loosing oil from the transmission output seal The Jeep drives great in 2WD, all the noises are disappeared!
Kind Regards,
Berti
Berti is offline
post #1010 of 3430 Old 01-19-2012, 10:55 AM
bullitt_9350
1995 XJ Cherokee
Read through this thread, did some reading on Novak's knowledge base and just want to confirm - 231 from a 92 XJ should have the same input as my 96 249?
96-98 249 should have medium input shaft.
Novak says 231s behind AW4s after 1990 with 23 spline are medium length.
1995 XJ Sport 4.0L/AW4/231, D30/8.8, Spartan F/R, 4.10s, HD Offroad 3-Link
bullitt_9350 is offline
post #1011 of 3430 Old 01-22-2012, 06:12 PM
steeleman3
So I was gonna head out this weekend and pick up a 231 TC to swap for my 249. I have a 93 so I'll have to swap my input shaft, but my tranny has been actin up too so I was wondering if I could pull a 46rh and 231 and just swap in the whole thing. Is this a possibility or has anyone done such thing?
Big Gulps huh? Alriight! Welp, see you later!
steeleman3 is offline
post #1012 of 3430 Old 01-23-2012, 09:50 PM
steeleman3
Went to U-Pull and Pay today and grabbed a 231 out of a 93 xj and a 249 out of a 93 zj. My 93 is a DD and can't have the downtime of swapping the input shafts so I pulled the same 249 out of another zj for the input shaft. No pics, yet. Should be tearing them both down and geting the 231 ready to throw in the zj in the next few days. I'll try and get pics. Pretty easy taking them out, now its just a matter of swapping inputs and getting the new one cleaned up. Anyone know how much play is supposed to be in the TC from the input to the front output? Seems like theres a bit of excess play in the both the new ones.
post #1013 of 3430 Old 01-24-2012, 07:17 PM
2GPS4ME
231 Question:
I have a match made in heaven. Vehicle is '98 Limited, and I'm swapping in a 231 from an '04 TJ. Identical input shafts, overall lengths, etc. However.....
Which lever (the one mounted to the transfer case) do I use on the 231 with the stock linkage in the ZJ? The long (249) or the short (231)?
Narrow Road Jeep Garage
Owner, Operator
2GPS4ME is offline
post #1014 of 3430 Old 01-24-2012, 08:05 PM
comptiger5000
You need the linkage lever that's already on the 231 (should be shorter than the 249 one).
post #1015 of 3430 Old 01-24-2012, 08:07 PM
2GPS4ME
Perfect, thanks a bunch!
Owner, Operator
2GPS4ME is offline
post #1016 of 3430 Old 01-26-2012, 10:56 PM
Taz360ZJ
Just an FYI i helped pioneer this swap 10 years back over on JU with my '93 V8 & 231. I did the 242 swap on my 5.9 2 weeks after i bought it in Feb '10, and Nov last year i swapped an older style non exposed output '95 ZJ 231 in it so the VIC would work correctly. Ended up swapping a '98 249 low range input in it to make it work, and hacking an inch out of my stock shift rod.
'94 ZJ, AX15, UC+BB, Ravine's, 31's, 3.8L fan, D2S's, fully murdered out.
Taz360ZJ is offline
post #1017 of 3430 Old 01-28-2012, 01:43 PM
E-rok
ended up pulling a 242 out of a 96 ZJ today because I really didnt feel like doing a front case swap on my 92, I also got the driveshaft so hopefully it should fit right up. it had a D35 so hopefully that added length wont be an issue.
anyways, the donor had 3.55 gears, and I have 3.73's and 31's. would leaving the 3.55 speedo gear and sensor essentially bring me back to stock settings since I have 31's? furthermore, did Jeep even use different gear and sensors for the two different gearsets or did they just run the same one since theyre pretty close?
2011 WK2 Laredo X Hemi
2013 Ram 2500 Cummins
E-rok is offline
post #1018 of 3430 Old 01-28-2012, 02:27 PM
Taz360ZJ
They used different speedo gears.
Taz360ZJ is offline
post #1019 of 3430 Old 01-28-2012, 02:41 PM
E-rok
yea thats what I just read. I dont have the swap the gear on the shaft, just the sensor one, right?
E-rok is offline
post #1020 of 3430 Old 01-28-2012, 02:55 PM Thread Starter
JrMechanic
Yes, the stock gear used with 3.55's is perfect for 31's and 3.73's. I have the same combination and at 65 MPH I read 66 on my GPS.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
