Transfer Case Swap Info NP249->NP231 & NP242 - Page 66 - JeepForum.com
 13Likes
post #976 of 3430 Old 01-02-2012, 05:51 PM
squazz
Originally Posted by comptiger5000 View Post
Pre 96, they were. In 96, everything switched to the 0.840" input.
huh both my 93 4.0 Ax15 & 94 4.0 42re are both .0840"
squazz is offline
post #977 of 3430 Old 01-02-2012, 06:15 PM
comptiger5000
Before 96, 4.0s used the .840" input and possibly the .750" input, depending on which tranny they had, I think. V8s used the long input (around 1"). In 96, all engine and tranny combos changed to the .840" input.
comptiger5000 is offline
post #978 of 3430 Old 01-03-2012, 12:23 PM
LostDogs87
So what are the driveshaft issues somebody was talking about. Am I Gonna have to get different shafts?
LostDogs87 is offline
post #979 of 3430 Old 01-03-2012, 12:41 PM
super-gene
Is it possible to replace my 231J with a 249J in my 1993 Laredo? Also, my currently installed 231J does not show as shifting into "4 Full Time", but only Part Time. Is this normal?
super-gene is offline
post #980 of 3430 Old 01-03-2012, 01:11 PM
csouers
That's normal. Your transfer case does not have Full Time, as it is not a 242. Your case has 2hi, 4hi part-time, neutral, and 4lo (low range) part-time.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #981 of 3430 Old 01-03-2012, 02:40 PM
LostDogs87
So it says that the external slip yoke is generally found on 96 and newer jeeps, so does that mean I shouldn't have a problem with the driveshafts being as how the tc I'm getting is from a 99 Cherokee and my zj is a 98?
post #982 of 3430 Old 01-03-2012, 02:49 PM
KingtheZJ
249s are internal. if you look at yours you will see that.
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #983 of 3430 Old 01-03-2012, 03:10 PM
LostDogs87
So basically I have to find a driveshaft out of a 99 Cherokee with external slip yoke?
post #984 of 3430 Old 01-03-2012, 03:31 PM
KingtheZJ
no, cherokees are shorter wheelbase. you need a rear ds from a ZJ with a 4.0 and an external. or you can get your ds shortened. the esy is exactly 1.5" longer than the isy
'88 XJ
post #985 of 3430 Old 01-03-2012, 03:39 PM
LostDogs87
Alright i got it now! Was a little confused at first. Thanks for all your help!
post #986 of 3430 Old 01-03-2012, 07:00 PM
airwolf9090
I am gonna be pulling a 242 out a pre 96 ZJ 4.0 at the JY and was wondering what should i look at or worry about. I will be getting the Transfer-case, front and rear driveshafts, shifter and bazel, and the front axle with the U-joint style shafts
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #987 of 3430 Old 01-03-2012, 07:24 PM
Freestyle713
1994 ZJ
the tailshaft of my 231 is at most a half inch shorter than my 249. will this be a problem?
Freestyle713 is offline
post #988 of 3430 Old 01-03-2012, 08:22 PM
famouslee99gt
I have a 97 ZJ 5.2 in which the previous owner installed a 231 I believe (2wd, 4 hi, n, 4 lo) out of an XJ (he had to swap shafts if I recall). In 2WD it's fine, but when in 4 HI or 4 LO, the VIC displays 4WD Switch and beeps every few seconds. What might be the fix? Do I need to find a different switch or do I need to change the connectors behind the VIC? I haven't really looked into it as I haven't driven it much in the 6 months I've owned it.
'97 Jeep Grand Cherokee Limited. 150k miles, 5.2 V8, 242 Transfer Case Swap. Dana 44 rear axle, soon to have LSD. ProComp 3.5" lift with 1.25 spacers. Goodyear Wrangler MTR 245/75R16 on stock 16" rims
famouslee99gt is offline
post #989 of 3430 Old 01-04-2012, 07:14 AM
comptiger5000
For a 231, the whole case is shorter than a 242 or 249, hence why the external slip yoke isn't longer. The 1/2" should be fine with your current DS.
post #990 of 3430 Old 01-05-2012, 01:33 PM
Freestyle713
1994 ZJ
I have a problem. I swapped my speedo gear but the speedometer doesnt work. The gears arent the same. I was going to just swap them but the shafts are different lengths. I tried tapping the shaft out of the gears but it didnt work. Anybody have a solution? I need the green gear in the black housing
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
