Transfer Case Swap Info NP249->NP231 & NP242 - Page 65 - JeepForum.com
 15Likes
post #961 of 3442 Old 12-29-2011, 07:16 PM
RedneckZJ
alright, didnt think so. now im on the hunt for a 96-98 242 then
'96 ZJ Orvis 5.2L (Mossy Oak Edit.)- UC+2" BB, Thrush Turbo, 2 12s, Lots Of Stickers
You drive a tj, we drive a zj. We have more power while you get more shower. We get the v8 while you get there too late. You have 2 doors well, we have 2 more. Ours costs a grand while yours has a price we cant stand.
RedneckZJ is offline
post #962 of 3442 Old 12-29-2011, 07:29 PM
squazz
i know where 3 are sitting ready to be pulled i never bought a tc from this yard but other yards in this area i have pulled from charge 90$ and i usually get the rear drive shaft i can look in to it if your intrigued
squazz is offline
post #963 of 3442 Old 12-29-2011, 07:42 PM
RedneckZJ
any idea what shipping would be. zip 37115
post #964 of 3442 Old 12-29-2011, 07:45 PM
squazz
would have to ask JrMechanic i believe he has shipped a few of these and would know the best/cheapest way
squazz is offline
post #965 of 3442 Old 12-30-2011, 01:46 AM
uplandhawaii
Happy Holiday guys, got a question I can't find an answer for.
I've done the 249 to 231 swap before in my 98 5.9 but a friend just brought me his 93 GC and a 2002 GC 242 to swap in.
Input length is correct but the tailshaft housing does not have a speedo hole, can I just swap the tailshaft housing from the 249 to the newer 242?
Looks like I can do it, lining it up side by side, the position of the circle clips look close enough that I think the housing swap will work. If for some reason it doesn't line up can I bolt the housing on without the circle clip to retain it? Will the bolts on the housing be enough or does the circle clip serve some other function?
Thanks for any help!
HOW MUCH is that to ship to Hawaii!!!???
uplandhawaii is offline
post #966 of 3442 Old 12-30-2011, 01:57 AM
jthayer0715
Help
Anyone in the MA or CT areas? looking for some help doing a transfer case swap on my 98 ZJ Limited. I want the stock one out and to put a 242 in. Thanks in advance.
jthayer0715 is offline
post #967 of 3442 Old 12-30-2011, 05:10 PM
uplandhawaii
Originally Posted by comptiger5000 View Post
Redneck - No, it won't. It'll physically fit and function, but the WJ 242 doesn't have a speedo sensor provision, as WJs get their speed from the ABS tone rings.
Is it possible to swap the tailshaft housing? See my post above.
post #968 of 3442 Old 12-30-2011, 08:25 PM
csouers
The WJ main shaft likely doesn't have the speedometer gear like the 94+ 242 does seeing as it didn't use it whatsoever. You could always crack one open and check.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #969 of 3442 Old 12-31-2011, 03:07 AM
uplandhawaii
Thanks, yep did that very thing this evening. I had the 2002 242, an 89 231 and a 93 249.
The output shaft from the 02 does not have any provision for the speedometer gear, its splined about 4-5 inches and then the shaft is a nice polished finish.
The 93 249 tailshaft housing will not fit the case either, its too wide. The 231 fit but would not bolt up, the housing did not have the 4 bolt holes, instead it had 5 10mm torx head bolts. Maybe a newer case with the correct bolt pattern would fit but I didn't have any around. Its pointless anyway because of the no speedo provision but at least I answered my own question.
As for swapping the case I took the .84 input shaft from the 249 and installed it in the 231. Bolted up and works with no problem. I need to adjust the linkage a little because it grinds coming out of 4lo. My friend is stoked to have a working 4x4 again.
post #970 of 3442 Old 01-02-2012, 04:19 PM
LostDogs87
TC Question
Hey, I'm hoping Somebody Can answer my question. I'm looking at buying a 231 transfer case out of a 99 Cherokee 4.0 for my 98 zj limited 5.2. Would anybody be able to tell me what the chances of the input shafts being the same length are?
LostDogs87 is offline
post #971 of 3442 Old 01-02-2012, 04:41 PM
csouers
Should swap right in, minus driveshaft issues.
csouers is offline
post #972 of 3442 Old 01-02-2012, 04:51 PM
squazz
thats not what i get from reading this thread 5.2 and 4.0 are always different lengths (correct me if im wrong)
squazz is offline
post #973 of 3442 Old 01-02-2012, 04:54 PM
KingtheZJ
from post 1
All 96-98 ZJ's: .840" 23 spline input
my 5.2L is a .840"
all 96+ 4.0 XJs should be .840
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #974 of 3442 Old 01-02-2012, 04:59 PM
LostDogs87
Originally Posted by KingtheZJ
from post 1
my 5.2L is a .840"
Thanks so much! That's what I was hoping.
post #975 of 3442 Old 01-02-2012, 05:37 PM
comptiger5000
Pre 96, they were. In 96, everything switched to the 0.840" input.
comptiger5000 is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
