Transfer Case Swap Info NP249->NP231 & NP242 - Page 64 - JeepForum.com
 12Likes
post #946 of 3412 Old 12-04-2011, 09:41 PM
squazz
A jack under the trans after removing the crossmember is a good way to adjust the level prob not a good idea to just let it hang on the motor mounts
squazz is offline
post #947 of 3412 Old 12-04-2011, 11:17 PM
Freestyle713
1994 ZJ
yeah i know that. i meant the ramps in addition to the jack. just to make it lean forward some more
Freestyle713 is offline
post #948 of 3412 Old 12-05-2011, 07:36 AM
klindzy3
I have a 93 JGC limited and I can get a transfer case from a 95 JGC limited and was wondering if it would work and if so how hard would it be to do it.
klindzy3 is offline
post #949 of 3412 Old 12-08-2011, 02:17 PM
Freestyle713
1994 ZJ
bump: tag says 231J but it doesnt have the rubber boot. i know i gotta swap the input shaft, but does anybody think it will fit without getting the driveshafts lengthened/shortened?
post #950 of 3412 Old 12-08-2011, 11:56 PM
squazz
Have read that the external and internal slides are 1.5" different but thats 231 vs 231
Mesure from case to end of shaft see what that is compared to the one in your jeep
my 249 ds internal was shorter then 242 external luckly I picked the ds from the doner jeep get it done and measure for the ds you need I got a few laying around i'll get length and pics posted up incase any one wants one on the cheap
squazz is offline
post #951 of 3412 Old 12-08-2011, 11:59 PM
squazz
Also found out that the 242 and 249 4wd switch are the same part # gonna swap them this weekend and hope that that solves my vic issue
squazz is offline
post #952 of 3412 Old 12-09-2011, 07:45 AM
Freestyle713
1994 ZJ
ok ill let you know about the driveshafts. i got this out of an xj so they wouldnt have worked anyways
post #953 of 3412 Old 12-10-2011, 03:43 PM Thread Starter
JrMechanic
231 J signifies that it is a Jeep transfer case. All Jeep transfer cases have the letter "J" proceeding the model designation. You DON'T want the rubber boot (external slip yoke) for the easiest swap in any ZJ (unless it has a prexisting 242 with an external slip yoke).
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #954 of 3412 Old 12-10-2011, 05:11 PM
Freestyle713
1994 ZJ
wow, that is such a relief. so it should fit just fine? after i swap the input shafts that is
post #955 of 3412 Old 12-14-2011, 05:38 PM
wildman90
mainly because no one wants to shorten the driveshaft and noone knows what the number of the output seals are or where to ge t the boot!!
nothing i cant do--i'l pay myself $50/hr labor!!
the only thing you cannot do, is that which you have already accepted defeat!
many people search for god in the eleventh hour, only to die at 10:30
wildman90 is offline
post #956 of 3412 Old 12-17-2011, 02:40 AM
jthayer0715
98 ZJ wants a 242
Hey nice thread you wrote, really insightful. I have a 98 ZJ 5.2L Limited and want to remove the transfer case that's in there and out a 242 in there. Any chance you could build that specific T case for me? Let me know asap. Thanks
jthayer0715 is offline
post #957 of 3412 Old 12-29-2011, 02:21 PM
airwolf9090
If anyone is interested in Central Fl i found a NP231 forsale for $100 on craigslist...
http://lakeland.craigslist.org/pts/2774277802.html
1996 Jeep ZJ Orvis
airwolf9090 is offline
post #958 of 3412 Old 12-29-2011, 06:20 PM
RedneckZJ
just a question. would a 242 from a wj swap into a zj?
'96 ZJ Orvis 5.2L (Mossy Oak Edit.)- UC+2" BB, Thrush Turbo, 2 12s, Lots Of Stickers
You drive a tj, we drive a zj. We have more power while you get more shower. We get the v8 while you get there too late. You have 2 doors well, we have 2 more. Ours costs a grand while yours has a price we cant stand.
RedneckZJ is offline
post #959 of 3412 Old 12-29-2011, 06:35 PM
ExpeditionXJ
Anyone know at which point exactly i measure from to determine input gear length? Seal, bearing face?
I know what i need, and have aquired two inputs but need to verify it's an .0840" input.
ExpeditionXJ is offline
post #960 of 3412 Old 12-29-2011, 07:14 PM
comptiger5000
Redneck - No, it won't. It'll physically fit and function, but the WJ 242 doesn't have a speedo sensor provision, as WJs get their speed from the ABS tone rings.
comptiger5000 is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
