Transfer Case Swap Info NP249->NP231 & NP242 - Page 63 - JeepForum.com
 9Likes
post #931 of 3318 Old 11-27-2011, 06:11 PM
comptiger5000
Squazz - Motor oil (5W-30 or similar) won't hurt the 242 at all.
comptiger5000 is offline
post #932 of 3318 Old 11-27-2011, 07:49 PM Thread Starter
JrMechanic
Motor oil won't hurt, but it needs changed much more often. Motor oil doesn't have near the amount of detergents and cleaning agents ATF has so the case won't stay nearly as clean.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #933 of 3318 Old 11-27-2011, 11:12 PM
comptiger5000
The t-case doesn't have much dirt introduced to the oil, so detergents aren't a concern (plus, the ATF having more detergents thing hasn't applied since the mid 90s, modern oils have a lot more detergent than older ones). The reason it needs frequent changing is that it's not designed to stand up to continued pressure from gear drives, etc, so the pressure additives wear out faster.
post #934 of 3318 Old 11-30-2011, 11:47 AM
klindzy3
Ok guys so i have a 1993 jeep grand cherokee limited 5.2 V8 with the 4hi N 4lo options. I need to replace the transfer case because it is majorly cracked and winter is coming fast. I need to know what kind of transfer case this jeep take and if any one has any suggestions to a modified tcase or a t case change. Ive herd a lot about the 242. Will this work in my jeep? let me know
thanks
klindzy3 is offline
post #935 of 3318 Old 11-30-2011, 02:56 PM
steeleman3
thanks
I believe you can get a 242 that will bolt up as long as it has the same input shaft length and spline. I have same 93 v8, they should have 23 spline with 1.55" input shaft I believe. If you're looking for the 231 there is no direct swap, you will have to swap input shafts. There is a gear cut change mid 94 for the input shaft so look for a case made before that if you're swapping inputs. Stay pre-95 on all transfer cases.
Big Gulps huh? Alriight! Welp, see you later!
steeleman3 is offline
post #936 of 3318 Old 12-01-2011, 12:24 AM
squazz
So I did this after swaping in the 242
and in every position it says "service 4wd switch" am I doing it wrong? or could the switch be faulty? Will the 249 switch work?
squazz is offline
post #937 of 3318 Old 12-02-2011, 10:36 AM
Midnightluckey
For early (93-95) v8's, there is NO bolt in swap besides another early np249 due to the required input shaft length into the 46rh trans found in these early v8's. You WILL have to do some input shaft swapping or case half swapping to get anything but another 249. And I believe the gear cut change started showing up around March or April of 1994, so be sure to check the tag on the rear of the case and get the date.
95 Limited Chargold ZJ 5.2L -5.5" lift (IRO, Ironman, and RC parts), 33" BFG M/T's, 15x8 procomp crawlers, 242 swap, 2 12" subs, 1000w amp, cherry bomb, full skid package, Kevins rear stealth bumper clone w 3/4" D rings, Rlcwelding front bumper w 3/8" D rings, XRC-8, front tow hooks, 2 daylighter fairlead lights, 2 daylighter windsheild lights, 2 55w driving lights, OBA, Cobra 18 CB, dual 4' whips, RC disconnects, smittybuilt jack, optima yellowtop.
Built not bought #512
Midnightluckey is offline
post #938 of 3318 Old 12-02-2011, 01:01 PM
steeleman3
Ok my bad. Had a feeling there was NO direct swap but thought I saw somewhere that said there was a 242 with 1.55 input shaft. Thank you tho.
As for the swap, are there pros/cons to swapping the front half vs the input shaft, or is it just a convenience thing?
post #939 of 3318 Old 12-02-2011, 01:17 PM
Midnightluckey
It's a gear cut thing. If you've got an old (93) 249 and a, say, 95 242, the gear cuts are different on the inputs, so you can't swap them. But you can swap the whole front halves of 242's and 249's with relative ease, allowing you to use your front half of your 249 with correct input on a rear half of a 242.
post #940 of 3318 Old 12-02-2011, 01:35 PM
steeleman3
Oh ok I gotcha. Didn't know if the gear cut affected that or not.
post #941 of 3318 Old 12-04-2011, 10:03 AM
Freestyle713
1994 ZJ
so i picked up a 231 J out of a 93 xj today. the tag says 231 J but i thought these had a rubber boot on them compared to the 231 which didnt? will it still work? i plan on swapping the input shafts with the one in my 249.
edit: and can i use the shifter handle from my 249? cause the guy didnt give me the one out of his xj, thanks
edit again: and how much, if any, tranny fluid will leak out of the tranny when i separate that and the t-case? i just spent $100 on atf for my tranny and i dont want any leaking out
Freestyle713 is offline
post #942 of 3318 Old 12-04-2011, 02:11 PM
csouers
You'll get some, but shouldn't be catastrophic. Replace the trans seal while it's out for good measure.
The case will still work. Driveshaft issues might come up, but the input swap should be good.
What do you mean by shifter handle? If you mean by the actual handle in the Jeep, yes. You will, however, need the tab that goes on the transfer case from the 231.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #943 of 3318 Old 12-04-2011, 07:56 PM
Freestyle713
1994 ZJ
how much fluid are we talking? is it enough to worry about re-filling? and the case came with the tab you are talking about, so im set with that, right? and would i be able to tell if the driveshafts will fit or not before putting the case in? if they are too long or too short, can i find shafts at a jy? thanks for the info.
post #944 of 3318 Old 12-04-2011, 09:16 PM
squazz
how much fluid are we talking? is it enough to worry about re-filling?.
All depends how much of an angle you leave the trans on after removing the crossmember I lost about a quart the seal was easy and cost about 10$
squazz is offline
post #945 of 3318 Old 12-04-2011, 09:40 PM
Freestyle713
1994 ZJ
i have a set of car ramps i was planning on using. if i drive the rear wheels onto them to get the back end up more than the front, would i lose less fluid? or would it not make a difference?
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 08:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 01:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 05:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 07:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 12:50 PM
