Transfer Case Swap Info NP249->NP231 & NP242 - Page 62 - JeepForum.com
 12Likes
post #916 of 3412 Old 11-24-2011, 12:05 PM
kmm2736
1994 ZJ
Originally Posted by vonericsen View Post
That is way high...I can pull one at a yard around here for $70...
No way! I'm still shopping around hopefully i can find a deal too!!
I need to figure some things out as far as compatibility. I really want to put a NP242 HD from a dodge in my 94 zj. Because of the higher torque ratings. I'm still unclear what if any modifications i need to do to make it work.
Thanks for the $ info!
kmm2736 is offline
post #917 of 3412 Old 11-25-2011, 09:35 AM
vonericsen
Thats the best deal I've found. Another yard here wants $150 which still isn't too bad.
Sometime in december I will be doing this swap myself. Good luck
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #918 of 3412 Old 11-25-2011, 02:05 PM
onevision
There are a bunch of aftermarket upgrades for the 231, and while I have yet to see one for the 249, I would bet that the same upgrade kit would work for both. Of course thats a bit like putting lipstick on a pig, but it could probably be done.
For $500, they better pull it, polish it, and guarantee it for give years. Lol Thats pretty high! I got my 231 out of s cherokee from a pick-n-pull place for $100
98 ZJ - custom double triangulated rear and 3-link front with 6 1/2" lift on 33"x13.5" and Teralow gearing
Wrenching pics at (slow connection) http://onevisionbeyond.com/gallery/v/jeep/
onevision is offline
post #919 of 3412 Old 11-25-2011, 02:19 PM
kmm2736
1994 ZJ
I finally got some numbers of my t case:
Model: 249
Assy No: 5209 530
Seral No: 228 94
Ratio: 72
The swap I am looking for a NP242HD. I want to make sure I buy the right one!?
My vehicles manufacturing date after looking up my VIN was 3/02/94. I Have not been able to pull it out to check the gear cut or anything yet because i drive it. Hopefully I can get my swap purchased after i put everything in order!
Thanks for all the help in advance everyone!
kmm2736 is offline
post #920 of 3412 Old 11-26-2011, 08:31 PM
steeleman3
ok some im needing to do the swap pretty bad. just double checking but please help me out.... I have a 93 5.2 with I think the 46rh. That mean its the 23 spline 1.55" input shaft?
Big Gulps huh? Alriight! Welp, see you later!
steeleman3 is offline
post #921 of 3412 Old 11-26-2011, 10:52 PM
Freestyle713
1994 ZJ
no, you probably have the 44rh, and you have the 23 spline 1.55" input shaft, so you got that part right. you will need a pre 94.5 242 or 231 out of an xj or zj. you will need to swap the input shaft with the one in your 249. there is no t-case that is a direct swap. the input shaft swap is the minimum you will need to do to make them compatible
Freestyle713 is offline
post #922 of 3412 Old 11-26-2011, 11:02 PM
steeleman3
ok yeah my bad. So there is no 231 OR 242 with 1.55"?
post #923 of 3412 Old 11-26-2011, 11:03 PM
csouers
WRONG. He has the 46RH (44rh doesn't exist, in jeeps anyways). To the poster, look at the first page. It has everything you need to know as, JrMechanic was in the same situation.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #924 of 3412 Old 11-26-2011, 11:16 PM
steeleman3
alright. I didn't know if it was the same for a v8 46rh setup. ok so I should be able find a direct swap for mine then, just make sure it has the 1.55 length input shaft and I wont have to bust it open, right? Would it still matter what year my new TC is from if that's the case?
post #925 of 3412 Old 11-27-2011, 05:26 AM
comptiger5000
If you're not swapping inputs, it doesn't matter what year the t-case is from. However, you've still gotta stay with 95 and older, as all 96+ cases have the .840" input, regardless of tranny.
comptiger5000 is offline
post #926 of 3412 Old 11-27-2011, 06:56 AM
Freestyle713
1994 ZJ
well it said 44rh on my build sheet
post #927 of 3412 Old 11-27-2011, 08:39 AM
squazz
Medio-
i just started pulling the 249 of her 94 and just like you that sob would not come the **** off I even hooked a winch ad chain to it nothing I drug the 94 across the driveway it was a croted stud holding it on finally got it off
So im throwing this 98 242 in both inputs art 7/8 inch long
got 2 questions
1 is it normal for tranny fluid to pour our tranny when tc is removed
2 what jack *** put motor oil in the 242tc and will it hurt it?
Im off to buy moar atf4 now
squazz is offline
post #928 of 3412 Old 11-27-2011, 12:12 PM
steeleman3
Ok thank you. Thats what I was thinkin I just wanted to double check with someone. I knew there was a cutoff for the newer cases like that just didn't know what year, now I know. Well...off to the JY to look for a 231 with the 1.55. But I found this--https://www.drivetrain.com/parts_catalog/transfer_case_replacements_and_parts/jeep.html#GRANDCHEROKEE
Looks like I'll be swapping the input shaft regardless, as it looks like my 249 is the just about only one with the 1.55" input? Unless I can grab a 242 out of a 93 zj. I was really looking at the 231 tho.
post #929 of 3412 Old 11-27-2011, 12:31 PM
steeleman3
https://www.drivetrain.com/parts_cat...#GRANDCHEROKEE
post #930 of 3412 Old 11-27-2011, 12:33 PM
squazz
I have sucessfully compleated the 249 to 242 swap it was awesome not being able to get out of the yard
just gotta swap speedo gear (plug is different) and switch plug in vic
squazz is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
