Transfer Case Swap Info NP249->NP231 & NP242 - Page 60 - JeepForum.com
 15Likes
post #886 of 3442 Old 11-09-2011, 05:44 PM
sskilla
yeah if you can find it
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline
post #887 of 3442 Old 11-09-2011, 06:35 PM
onevision
LOL Don't get me wrong, I'm not saying that the 249 is the end all transfer cases - or even that it's necessarily good. It does however perform well for what is was designed to do, but not really designed to last a long time. Personally I've never had any problem with the viscous coupler, but eventually that chain is going to stretch and cause a lot of problems.
If you have a Dana 35 in the rear, I'd say that is going to be a pretty weak link in your setup, but if your not doing any hard wheeling then you may get by just fine with it. I will however limit what you can pull or put extra load on. The rear axles on 93-98 ZJ's suck though, since they have an aluminum differential housing (unless you happened to buy a ZJ from Canada). That limits what you can do with it - mainly adding a locker is not an option. You can beef up the 35 by putting in 4340 chromoly shafts, and that will help a lot with making it stronger, but the big performance boost is really in locking it.
Nice, you have a 5.2 with a 46 RH trans! Did you swap the transmission or did it come like that? I thought they only put the 46 in with the 5.9 editions. The 46 is a lot more heavy duty than the 42RE or the 44RE. Not sure on the 242, but I know the footprint is pretty close to the same. The 249 will swap out to the 231 without much fuss, so long as you get the J type 231.
98 ZJ - custom double triangulated rear and 3-link front with 6 1/2" lift on 33"x13.5" and Teralow gearing
Wrenching pics at (slow connection) http://onevisionbeyond.com/gallery/v/jeep/
onevision is offline
post #888 of 3442 Old 11-09-2011, 09:06 PM
comptiger5000
93 - 95 5.2s had the 46RH, 96 - 98 had the 44RE, and the 98 5.9 had the 46RE.
Also, only 96 - 98 V8s had the D44a, the others had an iron D35. The 44a isn't weak anyway, it just has a few flaws.
comptiger5000 is offline
post #889 of 3442 Old 11-10-2011, 12:52 AM
RedneckZJ
i have a 96 v8 zj with the 249. would a 96-98 zj with the 242 be a direct swap (including driveshafts). if not what would be needed for the swap?
'96 ZJ Orvis 5.2L (Mossy Oak Edit.)- UC+2" BB, Thrush Turbo, 2 12s, Lots Of Stickers
You drive a tj, we drive a zj. We have more power while you get more shower. We get the v8 while you get there too late. You have 2 doors well, we have 2 more. Ours costs a grand while yours has a price we cant stand.
RedneckZJ is offline
post #890 of 3442 Old 11-10-2011, 03:35 AM
csouers
Depending on what rear end both Jeeps have, yes.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #891 of 3442 Old 11-10-2011, 11:30 AM
MilanJeep
MilanJeep's Avatar
Yes!
98 5.9 ZJ - 4.5" lift, 33x12.50 MT/R Kevlars
02 Z06 - Supercharged, E85, lots of rwhp, built and tuned by me
Milan
MilanJeep is offline
post #892 of 3442 Old 11-10-2011, 08:51 PM
kmm2736
1994 ZJ
How long did take to rebuild the transfer case? I Plan on driving my ZJ this winter and cant afford to have off the road. I was thinking of finding a 242 and rebuilding and then picking a weekend and Busting it out.
kmm2736 is offline
post #893 of 3442 Old 11-10-2011, 09:28 PM
squazz
Couple hours just make sure you order proper size bearings I got my kit including chain at a fair price from eastcoastgearsupply.com
Am I right in thinking only V8's have to worrie about gear cut change?
squazz is offline
post #894 of 3442 Old 11-10-2011, 09:34 PM
csouers
Yup. As long as you have all the parts on hand, maybe 3-4 hours if you have never done it before. Cleaning everything takes the longest. Reassembly goes by quick.
csouers is offline
post #895 of 3442 Old 11-11-2011, 12:11 AM
zachjf
so whats the deal with the WJ 242's? I tried searching through the 60pgs of info here and searching the forums but couldn't come up with a definitive answer. I have a 98 5.9 that NEEDS a 242 but I can't find a nice, low mileage one out of a ZJ or an XJ right now. I have found a half dozen out of WJ's for next to nothing but that doesn't do me any good if its not a bolt in swap, can't have my rig down for days since its my only transportation
Needs parts?
PM
or
zachjf is offline
post #896 of 3442 Old 11-11-2011, 09:59 AM
KingtheZJ
they have a different tailshaft that doesnt have the speedo gear output.
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #897 of 3442 Old 11-11-2011, 10:45 AM
comptiger5000
^ Correct. WJs sense the speedo from the ABS tone rings, so they don't have a speedo sensor provision on the t-case. If you've got a dead 249 and need something to throw in, I've got the 105k mile 249 (VC still good) that came out of my 5.9 laying in my parents' garage. It's yours for the cost of shipping if you want it.
post #898 of 3442 Old 11-11-2011, 12:17 PM
onevision
I think these two file will give anyone interested a lot of helpful information. They cover the complete disassembly and assembly of the 231, 242, and 249 transfer cases - as well as the 42RE, 44RE, and 46RE transmissions. I know it's been extremely helpful for me and my bible for the last 6 years. LOL
onevisionbeyond.com/jeep_manual/english/ezg_21.pdf
onevisionbeyond.com/jeep_manual/english/ezg_21a.pdf
post #899 of 3442 Old 11-14-2011, 12:49 PM
AngryVanilla
I've been researching this for awhile now and have some questions... I have a 94 ZJ 5.2 w/ 249 TC... The build date on my Transfer Case is pre-92, i forget the actual date, but it was in 1992... So i have the old style gear cut, correct??? From my research i have found that i need a NP242 from a XJ w/ Transfer case build date of Pre-94.5, and i will have to swap my input shaft from my 249, correct???
Last question is, i have a NP242 Transfer Case i believe is from a TJ, im not sure though, and the build date is 2001 on the case... Is there anyway i can make this work??? Like buying a junk 249 post-94.5 build date, and swap the input shaft??? Or is it useless in my swap into a 94 ZJ???
Thanks
AngryVanilla is offline
post #900 of 3442 Old 11-14-2011, 08:41 PM
4xclimb
So how much are these 242's finished going for? PM messageing box is always full so I try this way....
4xclimb is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 08:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 01:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 05:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 07:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 12:50 PM
