Transfer Case Swap Info NP249->NP231 & NP242 - Page 55 - JeepForum.com
 15Likes
post #811 of 3442 Old 10-18-2011, 01:07 PM
Shadowless127
Would a 242 out of a '99 XJ be a direct swap in (ie no changing input shafts or rear driveshafts) for my 97 ZJ?
Gone: 1997 ZJ Limited 5.2L - NP249, Skid Plates, JVC KDR-320 HU
Shadowless127 is offline
post #812 of 3442 Old 10-18-2011, 01:10 PM
KingtheZJ
the input shaft will be good. the rear output depends on the specs of the casses. i'm guessing the 242 has an esy and your 249 has an isy. so the 242 will be 1.5" longer. unless you are lifted to 4.5"+ with appropriate bumpstops, this will not work. you will need to get the rear drive shaft shortened or find one that is shorter.
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #813 of 3442 Old 10-18-2011, 01:18 PM
Shadowless127
Would a driveshaft from a 96-98 ZJ w/selec-trac work?
post #814 of 3442 Old 10-18-2011, 01:44 PM
KingtheZJ
it depends. the d35 in the rear has a 1" shorter pinion, but the tc is likely an esy so that would be 1.5" longer...
i;d measure to make sure
'88 XJ
post #815 of 3442 Old 10-18-2011, 02:01 PM
Shadowless127
Ok.
Do you happen to know the length of the 249 rear driveshaft?
post #816 of 3442 Old 10-18-2011, 07:29 PM
mrgreen98ski
1994 ZJ
Ok so I took the planetary here deer out of my 249 and installed it in my 242. Put the two halves together and RAM it through the gears and at no time when I turn the input shaft do either outputs turn. It's to late to tear it back apart. Any ideas on whats wrong?
mrgreen98ski is offline
post #817 of 3442 Old 10-18-2011, 07:32 PM
sskilla
sounds like you might have the t-case in neutral?
try rotating the shift lever (little tab sticking out of the side)
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline
post #818 of 3442 Old 10-18-2011, 07:41 PM
mrgreen98ski
1994 ZJ
I did and it always acts like its in neut
post #819 of 3442 Old 10-18-2011, 07:42 PM
sskilla
drag. sounds like you need to pull it apart and make sure all the peices got put in there correctly.
sskilla is offline
post #820 of 3442 Old 10-18-2011, 07:49 PM
mrgreen98ski
1994 ZJ
I know and I was all pumped too.
post #821 of 3442 Old 10-19-2011, 09:09 AM
mrgreen98ski
1994 ZJ
Ok took it apart this morning and found the I put the mode shift sleeve in backwards. Now its back together and I have a working 242 with a swaped 1.55" input shaft.
Next question. I was comparing the 2 shift indicators and I noticed that the spring end is bout 2 to 3 time longer on the 249s then on the 242s. The threads are the same and the same length. Will this be an issue?
post #822 of 3442 Old 10-19-2011, 09:21 AM
squazz
MrGreen are you refering to the ball on the end, different lengths were an issues for me in my 231-231 swap it caused me not to be able to shift cuz it hit the shift pattern piece but you cant swap 249 242 as long as you got all gears I can for see no issues
squazz is offline
post #823 of 3442 Old 10-19-2011, 09:55 AM
mrgreen98ski
1994 ZJ
the 249 is on the left and the 242 on the right
It's the ball end I m concerned with
post #824 of 3442 Old 10-19-2011, 10:17 AM
squazz
Yours looks bout the same length if you can shift all gears you should be good here was my issue http://www.jeepforum.com/forum/f13/t...l#post11173533
squazz is offline
post #825 of 3442 Old 10-19-2011, 10:33 AM
mrgreen98ski
1994 ZJ
Ya I car shift all so I m gonna go install it in th ZJ now
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
