Transfer Case Swap Info NP249->NP231 & NP242 - Page 48 - JeepForum.com
 13Likes
post #706 of 3430 Old 09-27-2011, 10:53 PM
Mediokrates
Great work sskilla!
Got any pics... b4, during, after?
How much RTV did you use? Would the 80ml be enough or should I go big and get the 300?
Hope your around when I do mine in a couple weeks.
Mediokrates is offline
post #707 of 3430 Old 09-27-2011, 11:11 PM
Darman
i have a 95 v8 zj with a 249 external slip yoke. if i put a 242 with external slip yoke will my front and rear drive shafts work?
Darman is offline
post #708 of 3430 Old 09-28-2011, 07:25 AM
speedbucket
yes, but you will more than likely need to swap the input from your 249 into the 242
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #709 of 3430 Old 09-28-2011, 11:47 AM
Darman
ok, thats what i figured since i have the long input shaft. just aslong and when im done its not like "crap my drive shafts are to short/ to long".
also would the TC be closer to the front of the vehicle or sit in the same place?
Darman is offline
post #710 of 3430 Old 09-28-2011, 02:43 PM
Mediokrates
here's a question:
can the t/c be painted with engine paint?
Edit: probably ain't gonna happen. I don't think i'll be able to get it clean enough. Nice thought though.
post #711 of 3430 Old 09-28-2011, 04:33 PM
sskilla
same place. it almost looks identical to the 249
'95 ZJ: 5.2 v8 / 231 Tcase / 46RH
sskilla is offline
post #712 of 3430 Old 09-28-2011, 04:36 PM
sskilla
Originally Posted by Mediokrates View Post
Great work sskilla!
thanks! we'll see how great it is once i get it back in and it doesnt explode lol. i just managed to ruin my new tranny output seal trying to install it so im about to head to the parts store and see if they have one. hoping to get this thing in tonight.
i just used a little tube of ultra black.. actually dont think im gonna even use the whole tube.
i by no means a pro at this lol, but i am on the forum everyday so ill offer up anything i can to help smooth your project
sskilla is offline
post #713 of 3430 Old 09-28-2011, 05:22 PM
Mediokrates
How'd ya ruin the trans output seal?
I think someone posted using a 2" pvc pipe and mallet to tap it in. I might be thinking about another seal though.
post #714 of 3430 Old 09-28-2011, 05:59 PM
zonecone
231 swap
ok i just got 231 j from a buddy for free. the input shaft measrues the same as my 249, 23 splines so this should be direct bolt up right. no need to swap out any other things right. its going into my 1995 zj with 5.2 awd
zonecone is offline
post #715 of 3430 Old 09-28-2011, 09:32 PM
sskilla
banged it like a dummy and got half of it stuck too far in there.. ruined it tryin to pry it out.
sskilla is offline
post #716 of 3430 Old 09-28-2011, 09:35 PM
sskilla
ok so i got it back in the jeep, i even fired it up and rolled around the block. no explosion so thats good, however i cant find 2wd. i had the shifter on what i believe to be upside down and i had 4 full time, neutral and 4 part time. flipped the shifter linkage to the top side ( i think thats the way it goes lol) and now i got 4 part time and neutral.
ive tried moving the lever and adjusting the linkage both ways and cant seem to find 2wd... you think i messed somethin up in the case?? i tested all positions before sealing it up and it seemed to be workin fine.
ideas?
edit: I think i need the shift linkage from a 242.. i was underneath playin with it and it seems that the 249 linkage hits the case before allowing it into the 2wd position. crossing fingers lol
sskilla is offline
post #717 of 3430 Old 09-28-2011, 10:51 PM
sskilla
sounds good to go my man. both external slip yoke?
sskilla is offline
post #718 of 3430 Old 09-28-2011, 11:51 PM
Mediokrates
I think that's it exactly sskilla. From what I've read, the 249 transfer case shift lever will not work on the 242:
http://jeephorizons.com/tech/tcase.html
At the bottom of the page, you can see a picture of the 2 levers. The 249 is twice as long as the 242.
I've tried to replicate what you're reporting, and I think I can explain.
First, I believe your initial installation had the correct configuration (if not parts). But because the tc shift lever is so long, you are unable to shift into the extreme ends of the gear range (2WD & 4Lo). 4Lo is prevented, as the tc shift lever is probably in contact with the tc front case at this point; whereas, 2WD cannot be entered because the tc shift lever cannot be pulled forward far enough into the proper position.
This is the part you're looking for:
I'm pretty sure this is how it attaches. After going through the FSM, and looking at how the entire shift linkage assembly goes together and functions, the shift lever rod enters the transfer case shift lever from the side closest to the tc front input. The rectangular slot on the tc shift lever should be straight up and down, with the tc shift lever itself approximately at 45 degrees sloping downward towards the front. This is 2WD. I know the pic is a little blurry, but I just crawled out on my balcony (it's past midnight) to snap it.
When you pull the shifter backwards, going from 2WD to 4Lo, the shift lever rod will swing the tc shift lever backwards as well, thus cycling through the gears.
Sorry to hear about it, but atleast your jeep will drive, and it's just a quick fix once you've got the part.
Good Luck!
What method did you use to install the trans output seal? and did you have any issues installing the input and output seals on the tc?
post #719 of 3430 Old 09-29-2011, 04:15 PM
Mediokrates
OK,
Just finished the first phase of the swap... The Cleaning! Can't do the swap for another week, but I may start taking things apart (or trying to!) in the mean time to get a looksee.
Before:
After:
I was up to my elbows in grease... good thing too... since I needed so much of it
post #720 of 3430 Old 09-29-2011, 07:23 PM
sskilla
yes, that shorter linkage is exactly what i need! damn my dummy @$$ or not gettin it all at one time. oh well i still need to go back for the shift gate bezel also.
as far as the tranny output seal i just placed it in with my hands and lightly tapped it all around the edge until it seated flush. i literally took about 5 minutes lightly tapping so i wouldnt have to go into a hulk rage again after ruining a second seal lol.
thats one hell of a clean up job my man. i didnt think to buy some solvant and a wire wheel for my drill until i had the case back together already. doh!
sskilla is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
