Transfer Case Swap Info NP249->NP231 & NP242 - Page 44 - JeepForum.com
 12Likes
post #646 of 3381 Old 09-09-2011, 08:15 AM
speedbucket
Originally Posted by caligiuri87 View Post
got my 242 yesterday from a 93 all good!!!! 150 dollars including the front driveshaft.
OK so i see that the inputshaft from the 249 is bit longer then the 242 ao i will swap it. i see only few bolts......i just take those out and wwap? also what would be the torque for it....and do i get a new seal for that? and how do u name that seal
you have to tear the case completly down to remove the input, like i said before, read the first 2 pages of this thread
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #647 of 3381 Old 09-10-2011, 01:48 PM
caligiuri87
1994 ZJ
got her done!!!!! 242 is in works awesome........2wd yahoo what a difference
caligiuri87 is offline
post #648 of 3381 Old 09-12-2011, 02:45 AM
fatboys95zj
alright so my tcase took a dirtnap yesterday and i seen this swap. im kinda confused on the swaping of the output shafts if they are different is there any way that you could give me little more detail? will i need another front driveshaft? about how many quarts of tranny fluid will the 231 hold? thanks DJ.
95 ZJ 2in BB 31 buckshots, lincoln locker in the rear.
"when in doubt, throttle out!"
fatboys95zj is offline
post #649 of 3381 Old 09-12-2011, 02:39 PM
caligiuri87
1994 ZJ
i jsut swapped from 249 to 242. if u look between 93 and 95 u should be ok.. u will have to change input of where it connects to the tranny...simple take the one form ur tc put it into the new one. when i had found a 242 i looked up the numbers to match like product numbers... cant get the correct word out. but u should not have to swap drive shafts i believe as long ur doing it in the same years (93-95) but thats for an swapping to 242 i dont know for 231
post #650 of 3381 Old 09-14-2011, 04:14 PM
EdZJ96
alright so i have a 96 grand cherokee with the 5.2 v8 and the 249j i just got a 231j from a 2000 xj with a build date of 12/7/99 i also have the rear driveshaft from the xj and i also took the 4x4 shifter linkage from the 231. i havent done the swap yet but can someone clue me in if i need anything else to make this swap and last question DOES ANYONE HAVE A 231 BEZEL FOR A ZJ!! please
EdZJ96 is offline
post #651 of 3381 Old 09-15-2011, 04:13 AM
csouers
From what I know, that's a bolt on deal. Input gear should be the .840" one. Speedometer stuff will swap over. Driveshafts may be different. The range sensor wiring can be made to work.
Good luck with the install and with finding a matching bezel!
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #652 of 3381 Old 09-20-2011, 08:12 AM
tinow
Ok. after reading this thread and installing one bad 249 into my Jeep, I took the plunge and bought a '94 242 from a Cherokee Sport. To my surprise and delight, the process of putting the input shaft from the 249 into the 242 was not that hard. The trickiest part was getting the shift fork out. A few pots of coffee, some various mumbling and cursing, and 3 trips to the parts store and now I am driving around in 2wd! Thanks to everyone on this forum for all the input and tips. Go jeepforum!!
tinow is offline
post #653 of 3381 Old 09-20-2011, 08:30 AM
Mediokrates
what parts did you need to pick up?
Mediokrates is offline
post #654 of 3381 Old 09-20-2011, 06:46 PM
Dyn0mitemat
Just a word of warning to those whom are going to attempt this: Change all the seals (output for transmission, input for trans case) while you have everything apart. I had to do a front case swap, and since nothing leaked before I figured I wouldn't touch the seals since both were going back together....
Picked up new seals tonight, gonna have to drop it again to fix a slow leak (1-2 drops a day)
Any recommendations on changing them? Is the one on the transmission just pop out and push the new one on?
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #655 of 3381 Old 09-20-2011, 08:07 PM
caligiuri87
1994 ZJ
yes it is its kinda tight but i pried it out side by side and lubed it. when u put the new one in clean out the housing and lube it a bit makes it alot easier i had to hammer it softly but if u haveto use an rubber hammer or put a fodled rag on it preventing damage.
Shaky.......shaky shaky shakyyyyyyy.....crack boom pow @%^@%@%@$@#$^%&*(^&&%$@!!!!!!
Happy to be a JEEP owner
post #656 of 3381 Old 09-20-2011, 08:09 PM
caligiuri87
1994 ZJ
i can get uone here the junkyard has around 13 of m from zj i can ship it for ya.
post #657 of 3381 Old 09-20-2011, 08:30 PM
EdZJ96
How much? That would be such a big help
EdZJ96 is offline
post #658 of 3381 Old 09-20-2011, 08:37 PM
Mediokrates
Picking up my early 94 242 t/c end of this week, early next week to swap into my 93 5.2L auto GC Ltd.
Thinking of doing the swap up at the cottage on Thanksgiving weekend (Canadian), since there's a workshop up there.
What else should I be picking up for this job?
RTV, fluid, output trans seal, input t/c seal....
I'm gonna clean the 242 up, and take it apart once I get it (to familiarize myself), so it'll be a quick input swap.
Thanks
post #659 of 3381 Old 09-21-2011, 07:56 AM
tinow
Mediokrates- I picked up a set of seals for the TC and one for the tranny. On install of the tranny seal, I bent the lip and went back for another. I did find, however, that if you use never seize and a piece of 2" pvc to drive the seal in, it goes much smoother than trying to tap it on with a mallet. The third trip was simply for ATF +4. This is my first Jeep so I only had Dexron in the garage. That being said, on the dipstick of the tranny it says that dexron II is acceptable. Can anyone confirm that it is ok to run dexron in the tranny?
tinow is offline
post #660 of 3381 Old 09-21-2011, 03:15 PM
Mediokrates
Thanks tinow,
What set of seals did you need for the t/c? input and what?
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
