Transfer Case Swap Info NP249->NP231 & NP242 - Page 43 - JeepForum.com
 14Likes
post #631 of 3441 Old 09-04-2011, 07:39 AM
ny_driver
If the input shaft is the same length you should be able to just bolt it in there.
Piece of cake.
I have a 231 sitting here waiting to go in the place of a 249 myself.
ny_driver is offline
post #632 of 3441 Old 09-04-2011, 07:51 AM
EdZJ96
Is there anyway to find out the length without dropping the case? Because if I take the transfercase out its not going back in lol
EdZJ96 is offline
post #633 of 3441 Old 09-04-2011, 11:29 AM
caligiuri87
1994 ZJ
so what i see i woud also be able to replace my 249 with an 231? as long as i swap both shafts? and the year range is what?
caligiuri87 is offline
post #634 of 3441 Old 09-04-2011, 02:54 PM
speedbucket
read the first 2 pages of this thread for the both of you, all your answers are there, if you can't find them then ask the question but everything is pretty much covered
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #635 of 3441 Old 09-04-2011, 04:05 PM
Foundrydude
Originally Posted by speedbucket View Post
wth? is that you boomhower?
Go easy on the caligiuri, he's a good dude with a lot of mechanical knowledge that doesn't always come across due to 2nd language issues.
This thread could really use a moderator to thin it down, there's a lot of excellent info plus thirty pages of confusion.
Foundrydude is offline
post #636 of 3441 Old 09-05-2011, 07:40 AM
zonecone
zj t case
i have a 95 zj awd. 5.2 with 46rh trans and 249 t-case. so what exact 231 do i need to find and what years. is there alist of everthing i need. im putting d44 in front and 9'' in the rear. building my own long arm with custom crossmembers and want to make sure the trans and t cases are in b4 the fabwork starts. i dont want to do it twice. thans in advance for info.
p.s im new to the jeep world so bare with me on the stupid questions.
zonecone is offline
post #637 of 3441 Old 09-05-2011, 08:53 AM
zonecone
zj t case
i think a rubicon with the 4:1 is also a 231. is this possible to put in. or can i upgrade the earlyer 231 with a different ratio. i dont mind spending alittle extra to find a good rubicon one if i need to.
ok im wrong with the rubicon being a 231. sorry. but on that i could just put the tera 4:1 in it correct.
Last edited by zonecone; 09-05-2011 at 09:12 AM. Reason: jumping the gun b4 looking
zonecone is offline
post #638 of 3441 Old 09-05-2011, 09:37 AM
caligiuri87
1994 ZJ
thanks buddy. i know sometimes i sound stupid but i kinda already rebuilt my 94 jeep already. im well known in mechanical work but to explain it in english can be hard sometimes. btw frontend does well!!!! still some noises but tc is on its way im looking for a 242 but i already found 2 231's trying to figure out if it would fit an what i would have to adapt
post #639 of 3441 Old 09-05-2011, 09:41 AM
caligiuri87
1994 ZJ
if YOU would reread it u would see i already said i have read it all but it was confusing to me.
post #640 of 3441 Old 09-06-2011, 05:52 PM
94jeepers
Hi im new to this forum but I just gota 94 jeep zj and I love it.. it hasthe awd transfer case where the only positions are 4wd all time nuetral and 4low and I wanna swap it with the np242 and I was jw is it just a straight sway or do I have to swap out other stuff.... btw my jeeps the 4.0 i6... any helps aprecitaed just didn't wanna read all the stuff on the first page lol
94jeepers is offline
post #641 of 3441 Old 09-06-2011, 08:10 PM
caligiuri87
1994 ZJ
so i am pulling a 242 thursday in newton. they have like 14 of lol imma pull the cleanest. the jeep looks like an 97 or 98 so i have to lokok at the 23 spline count but do i need the shafts to the front and rear too? rear shaft on that jeep has a boot by the tc. also i have to get that bezel but do i need to make adjustments or is it just the black plastic.....or also the white underneath.
post #642 of 3441 Old 09-06-2011, 08:48 PM Thread Starter
JrMechanic
You're much better off pulling a case from a 93-95 ZJ, or a 94 or earlier XJ. With the 96+ case you will have to have your already short rear drive shaft shortened, and you will have to deal with a front case swap to change inputs. Much more trouble than it's worth.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #643 of 3441 Old 09-07-2011, 02:52 PM
caligiuri87
1994 ZJ
aaa hthanks ill check for sure what year it is. anyway if i would have a 242 from a 93-95 and the spline count is 23 do i have to change shafts then??? driveshafts i mean?
also i want to know about my shifter.......im thinking taking the bezel out with also that white part udnerneath and put it in mine......any suggestions?
post #644 of 3441 Old 09-08-2011, 02:39 PM
comptiger5000
A Rubicon 4:1 case is a 241OR.
comptiger5000 is offline
post #645 of 3441 Old 09-09-2011, 08:08 AM
caligiuri87
1994 ZJ
got my 242 yesterday from a 93 all good!!!! 150 dollars including the front driveshaft.
OK so i see that the inputshaft from the 249 is bit longer then the 242 ao i will swap it. i see only few bolts......i just take those out and wwap? also what would be the torque for it....and do i get a new seal for that? and how do u name that seal
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
