Transfer Case Swap Info NP249->NP231 & NP242 - Page 42 - JeepForum.com
 14Likes
post #616 of 3441 Old 08-31-2011, 05:26 PM Thread Starter
JrMechanic
Originally Posted by caligiuri87 View Post
ok so i found a 242 for 136 bucks.
now i run a 249 with busted vc.
since vc is kinda expensive i go for this.
i have an 94 grand cherokee limited 5.2
not sure what year the 242 comes from but i have to check ONLY the shaft that goes to the tranny right??
should be 23 ????
also thinking of the shafts.
my front drive shaft has an 'extendable' part on it just befor e the diff.
does this matter etc??
and prob i will have to take that bezel to right?
since thats also 2wd i only have 4high and 4 low
also im gonna take the antenna and the left front blinkerlight
i have read the whole post and explains alot but just making sure incase i read something wrong
edit; in the door the plate says manufactured 93 but title says 94 and i just bought axles for the front all based on 94 so i think ill stick with 94 since that is everywhere except on my plate in the door.
You have to swap input shafts regardless of the case for your application.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #617 of 3441 Old 08-31-2011, 08:48 PM
caligiuri87
1994 ZJ
ok thats the shaft going into tranny right? but that shoukld be on the tc when i pull it out.
caligiuri87 is offline
post #618 of 3441 Old 09-01-2011, 06:19 AM
speedbucket
yes, but you bacically have to completely tear down the case to get to it, once you get the case open alot of things you have read will make more sense
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #619 of 3441 Old 09-01-2011, 03:28 PM
zander21510
OK, so I have a really bad NP242 in my Jeep. I was running it with low fluid (unknowingly) and the shop said the fluid looked really bad like it had been overheating a lot. They didn't open it up but they said it needs to all be replaced. My question is this: in 2wd can I move it about 3 or 4 miles to my girlfriend's parent's driveway to park it as-is without breaking something else? I'm parking it because I'm looking for a used 242 for 100-150 bucks...the shop quoted 1600 for a new one which is totally out of the question...but its difficult to find an exact match for my jeep. I found one in the Dallas area but it doesn't have the 23 spline input shaft....
So if you guys know anything please PM me, I'm stranded in Dallas until I find a correct 242...I'm in college and my parents aren't happy about me not having a car to get back to Houston...
zander21510 is offline
post #620 of 3441 Old 09-01-2011, 04:44 PM
ZJFABN
Does it make any noise while its in 2wd? If no then I would say you could move it 6 miles. Whats it doing thats bad? Have you tried changing the fluid?
Do you have a local Jeep club? If so, maybe they can help find you a TC.
You could also try searching the classifieds on CL, Ebay or other Jeep clubs and get one shipped. I bet with a little work you could find one for $200 with shipping.
My work, http://www.virtualjeepclub.com/showthread.php?70963-JW-Fabrication&highlight=Jwfabrication
ZJFABN is offline
post #621 of 3441 Old 09-01-2011, 05:03 PM
zander21510
I took it to a shop because my original problem was that my jeep after 30 minutes of city driving would start to slip and shift later, it would struggle going up hills even after downshifting. I had it in 4wd full time for the past few weeks...probably stupid on my part since it was such an old tcase that was basically unused before...but anyway I took it to the shop, said nothing was wrong with the tranny, but they said the tcase had been leaking and it was low on fluid, the fluid condition was terrible and they said it had been overheating...they quoted $1600 for new internal parts...said something about the oil pump and chain being bad.
I've been doing extensive searching and I haven't found anything really yet...basically all I can do now is park my jeep until I find one. The shop never took it apart and just filled it with new fluid.
post #622 of 3441 Old 09-01-2011, 05:07 PM
ZJFABN
Hows the tranny fluid look? Check the level in neutral. So, the TC isnt doing anything wrong?
ZJFABN is offline
post #623 of 3441 Old 09-01-2011, 05:15 PM
zander21510
The tranny fluid looks and smells fine, fluid level is fine. I haven't really checked the fluid in the tcase, the shop looked at that. I need to go back and maybe drive it around the block to see what's up...I don't hear or feel anything wrong with anything except what I described after 30 minutes.
post #624 of 3441 Old 09-01-2011, 08:14 PM
caligiuri87
1994 ZJ
ok so the 242 was crap finally had it out but then i see a big hole on the bottom front......no go.
but there were alot of 231 around there that kinda looked good.
so would i have to make adjustments in my 94 zj limited. i have an 249 now.
anyway today i broke down.....like theres no gas since the pump ws going. gage is not working so towed it 5 miles. 137 dollars........and then it fired right up how weird and pissed of since i got paid today and i had that money for a tc .......anyway would like an opinion.
tom replacing fuelpump it has 221900 miles on it and had struglles before so prob its going dead.
post #625 of 3441 Old 09-02-2011, 06:21 AM
speedbucket
wth? is that you boomhower?
post #626 of 3441 Old 09-02-2011, 10:14 AM
ZJFABN
I would give you an answer if I could understand a question.
ZJFABN is offline
post #627 of 3441 Old 09-02-2011, 11:33 AM
caligiuri87
1994 ZJ
lol im sorry but i always keep typing without looking. ugh have to get rid of that nasty habbit
now i have an 249 tc
wanted to swap to 242
that was no good
so i found 3 231 tc's
will that be ok to swap?
if so what adjustments will there be.
my 249 only has 4 high 4 low and neutral.
that was the question
could not afford the fuelpump so i bought a new ignition coil.
new fuel filter.
and new link bushings. had the end links replaced when i replaced the frontend
post #628 of 3441 Old 09-02-2011, 04:45 PM
MuddSlutt
i did the 242 swap in my 5.9, switched the plugs in the back of the VIC but none of the tires light up and part time, full time, low dont light up.... sound like a bad switch?
01 WJ 4.0 ((New Toy))
98 ZJ 5.9 Limited ((SOLD))
MuddSlutt is offline
post #629 of 3441 Old 09-02-2011, 05:11 PM
csouers
Does to me.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #630 of 3441 Old 09-03-2011, 11:08 AM
EdZJ96
ok ive read alot on here and the input shaft on my 96 zj is .840 from what ive read. well my dads friend owns a junkyard and he got in a 2000 xj with 86k miles on it for a cash for clunkers which is depressing but he hooked me up with the 231 tranfser case out of it for free but the date on the transfer case was like 12/08/99 so my question is would i be able to swap it in my zj to get rid of my 249?? i understand i need to get a rear drive shaft but from what im reading i dont need to really do anything else right? im only 17 and im doing the swap by myself so all the help would be a huge help thanks alot guys
EdZJ96 is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
