Transfer Case Swap Info NP249->NP231 & NP242 - Page 40 - JeepForum.com
 15Likes
post #586 of 3442 Old 08-09-2011, 07:42 AM
comptiger5000
The hex plugs for fill/drain are 10mm, IIRC.
comptiger5000 is offline
post #587 of 3442 Old 08-10-2011, 09:08 PM
jaguarjoe
Everybody sez to get a good pair of snap ring pliers to do this swap. Are all these snap rings the external type? Are the pliers straight or 90 degree?
Can anyone just give me a name and model number for a good pair?
jaguarjoe is offline
post #588 of 3442 Old 08-13-2011, 12:26 PM
JordanZJ
I have a 98 zj with the 294 thats going out. My donor is a 231 from 95. The input length on the 231 is .750 adn the 249 is .840. Do i use the 249 shaft in the 231 case?
JordanZJ is offline
post #589 of 3442 Old 08-13-2011, 04:58 PM
corndogduff
Just get a good universal set (craftsman makes a pair that I've used EVERYWHERE) and you'll be golden. Get some lock ring pliers too. Using snap ring pliers on lock rings is a quick way to break tools.
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
corndogduff is offline
post #590 of 3442 Old 08-13-2011, 04:59 PM
corndogduff
Now for my question. Anyone know if an XJ rear DS would fit after a 231 swap? My DS is WAAAAAYYYYY too long to fit.
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
post #591 of 3442 Old 08-13-2011, 06:11 PM
ZJFABN
You dont need to swap anything. Thats too close to even worry about.
My work, http://www.virtualjeepclub.com/showthread.php?70963-JW-Fabrication&highlight=Jwfabrication
ZJFABN is offline
post #592 of 3442 Old 08-18-2011, 03:25 PM
MuddSlutt
just did my 242 swap in my 98 5.9... donor was a 96.5 zj with an external slip yoke, swap went well minus me F'in up the output shaft seal. the only problems i ran into was the rear DS which i ended up just cutting the shaft on the TC and cutting the yoke on the DS, and the current problem i have is there are no 4wd light turning on in my VIC (before and after a swaped the red and black plugs)... any thoughts? bad switch?
01 WJ 4.0 ((New Toy))
98 ZJ 5.9 Limited ((SOLD))
MuddSlutt is offline
post #593 of 3442 Old 08-18-2011, 11:45 PM
Travis873o
Did anyone ever figure out how to wire the 2 prong 231 shift sensor plug to the 4 prong 249 plug?
FOR SALE: ZJ 231 bezel. 1996 ZJ Lifted
Travis873o is offline
post #594 of 3442 Old 08-19-2011, 02:37 PM
csouers
Wire the corresponding wires to each other. Seems like that would work.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #595 of 3442 Old 08-19-2011, 03:30 PM
Travis873o
Could you go a little more in detail? Which wires are you talking about? I have 4 to choose from when I can only use two. How do you know which ones that correspond to the 2 prong plug?
post #596 of 3442 Old 08-19-2011, 09:28 PM Thread Starter
JrMechanic
I currently have two Selec-Trac bezels for sale, $25 shipped a piece.
Here's a good visual for those of you unsure of the different input lengths. From the left, I have a 1.55" input from a 249, a .840" input from a 231, and finally a .750" input from a 242. They are all 23 spline shafts with the old style gear cut and they are all three interchangeable between each case.
A word of caution to those who attempt installing a .750" input in place of a .840" input: If you look closely at the center (.840") input, you'll see the upper most wear ring on the input. This is where the transmission output seal rides on the input shaft. As you can see, it's not very far from the edge of the shaft (approximately 3/10ths of an inch). If you attempt this swap, I recommend sealing the transmission and transfer case surfaces with Ultra Black or Gray RTV. I recommend this if your rig sees any deep mud or water anyways to keep sediment from ruining the transfer case and transmission seals.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #597 of 3442 Old 08-19-2011, 10:40 PM
Travis873o
So i figured out how to wire in the 231 sensor with the zj. Works and shows 2wd and part time 4wd. will be posting pictures and a how to some time tomorrow.
post #598 of 3442 Old 08-20-2011, 11:06 AM
Travis873o
Alright so I figured out how to wire up the 2 prong sensor from the 231 with the 4 prong wires from the 249. It's a lot simpler than you may think.
Alright so first off, you have to disconnect the red plugs behind the VIC and connect the black ones as the original writeup describes. All this action does is interpret the signal from the sensor differently. When the red plugs are connected (with the 249) the signal is interpreted as "4wd Lo". And when the black ones are connected it interprets the signal as "2wd", "Full-Time" and "Part-Time". Now when I say the sensor sends a signal, it's not really a signal, all it's doing is completing a existing circuit.
Alright so first you'll have to cut the 4 prong harness off and strip the 4 wires so you can do some splicing. then you'll have to connect the two wires you see in the first picture. Just twist them together for now. What this does is completes the circuit telling the VIC that you are in 2wd. the rear tires should be lit up on the VIC.
NOTE: I am unable to tell you the colors of these wires as...I'm colorblind, I was surprised I was able to figure this out as wiring, as you can imagine, is quite difficult for me.
So now cut the exposed wire completely that you see in the first picture...the one all the way to the right. You wont be using this. This wire is for the 242's "Full-Time" feature.
So now, while looking at the first picture, if you were to connect the all three wires the VIC would think you are in "4wd Part-time". So all the sensor really does is connect these three wires.
So splice the two wires from the 231 harness to the 2 wires you now have. See second picture.
NOTE: it does not matter which wires you use from the 231 harness because it's just jumping the wires together when the sensor is activated.
Now you're done test it with the sensor connected and when you depress the button on the sensor it should be in "part time" and when you release the button it should be in 2wd.
post #599 of 3442 Old 08-26-2011, 12:29 PM
skimsurf
looking to do this t-case swap on a 96 v8...should have the 249, since that is what everything i have found says. its a v8 not sure what size, guessing 5.2...im trading my 2k pos bravada for it...this guy thought it was a good buy sold my 94 yj, and 96 xj, still kicking myself for it, to buy it...tired of beating my head against the wall when the damn car keeps stalling after being run for an hr...anyway, I want to do the swap so I am not running in 4wd all the time, $3.50+ a gallon would like to save some cash...so what years in the t-cases should i be looking for? I found one out of a 99...pretty much all i could find...but i am not 100% sure...i get lost in a lot of the specs, after reading so many threads they all run together...the t-case out of a zj is the same deal, but with the v8 and i6 what kind of swaps in the tcase will i have to make? help, what kinda donor do i need to look for to make this as painless as possible?
skimsurf is offline
post #600 of 3442 Old 08-26-2011, 12:56 PM Thread Starter
JrMechanic
You won't gain any fuel mileage, so if that's your only motive for this swap then forget it. However if the VC is locked up (which it almost certainly will be), then swapping transfer cases is a good option.
A '99 will not work unless it is from an XJ and it has the speedometer provision. You want a 96-98 242 and will need to address the rear drive shaft only, or if you get lucky enough and find a 93-95 ZJ 242 with the .840 input shaft and internal rear slip yoke it will be a direct swap.
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
