Transfer Case Swap Info NP249->NP231 & NP242 - Page 4 - JeepForum.com
 12Likes
post #46 of 3358 Old 02-06-2009, 10:19 PM
bigbluezj94
1994 ZJ
is a 242 from a 91 jeep cherokee going to have the same gear cut as my 94 grand? found a good deal, close.
94 Grand Cherokee Laredo ZJ, lifted, 37s, yada yada yada
BigBlue build 33s, 6in lift and short arms
BigBlue build 3/4 ton axles, LAs, 37s
99 Grand Cherokee Laredo WJ, 4.7 liter, 247 Quadra Trac II, fully loaded
bigbluezj94 is offline
post #47 of 3358 Old 02-06-2009, 11:32 PM Thread Starter
JrMechanic
Whats the MFG. date on your ZJ?
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #48 of 3358 Old 02-07-2009, 12:08 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
the change was in 95 iirc.
ratmonkey is offline
post #49 of 3358 Old 02-07-2009, 10:25 AM Thread Starter
JrMechanic
From everything I've read, the change was between 94 and 95.
post #50 of 3358 Old 02-07-2009, 12:09 PM
BLACKzj52
hey boss,
ive got a 231 sittin in the garage at my parents house back in nc. Its out of a 97 or 98 TJ. i would love to use it for my swap and save some dough but my zj is a 94. im worried that if the shafts arent the same size, which they more than likely arent, then the gear cut will be different. there is really nothing i can do but rip them apart and see, huh? great write up btw
if u use the tj case ull have to swap the front output yokes. tjs used different front driveshafts i think
BLACKzj52 is offline
post #51 of 3358 Old 02-07-2009, 02:00 PM Thread Starter
JrMechanic
Yeah, I missed where he said TJ. I it was either the front output yoke or the splines on the drive shaft were different.
post #52 of 3358 Old 01-17-2010, 12:07 AM Thread Starter
JrMechanic
Okay guys, I updated this thread with a freaking TON of information, as well as a whole different swap. It now covers swapping inputs, as well as the information on gear cuts and input shaft length.
I ask that anyone who has done this swap make suggestions and or give input on this thread.
I have some pictures, but I won't be adding them until tomorrow. I just spent two hours revising this, and it's time for bed.
post #53 of 3358 Old 01-17-2010, 12:12 AM
MurdaJs
tons of info, thanks
MurdaJs is offline
post #54 of 3358 Old 01-17-2010, 04:21 PM Thread Starter
JrMechanic
Well I finished up the 242 swap today. Tested everything out and it seems great Did a nasty burnout too.
I was told there's a revised part for the bushing that atatches to the body for the transfer case linkage. Anyone have a part number for it? The bushing is bad on both mine and my buddy's ZJ's.
post #55 of 3358 Old 01-17-2010, 04:53 PM
highlyuncntered
Originally Posted by JrMechanic View Post
93-95 V8 ZJ's: 46RH transmission, 1.55" 23 spline input shaft
93-95 I6 ZJ's: Used both the .750" and .840" 23 spline input with the 42RE and AX15.
93 I6 ZJ's with the AW4: 1.55" 23 spline input
All 96-98 ZJ's: .840" 23 spline input
Are you sure?? I have read a lot of other places that my '98 ZJ V8 will have the 1.55" input. I have a '93 231 23-spline with the .840" and if what you say is true, it should swap right in without having to change inputs. I am really tempted to just pull my 249 and measure. It seems to be the only surefire way to know.
"Si Vis Pacem, Para Bellum"
'98 ZJ Limited V8 "Daisy"
highlyuncntered is offline
post #56 of 3358 Old 01-17-2010, 06:34 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
no, he's not sure. we make this stuff up.
to quote another poster here.
post #57 of 3358 Old 01-18-2010, 09:01 PM
highlyuncntered
I understand what he said. I have just read up a lot on this topic and everyone else has been giving conflicting information. If it is completely true that ALL ZJs, no matter what engine, have the .840 input, then that makes the PITA input swap unnecessary for us 96+ V8 owners. I think I have read every t-case swap thread and I grew into the understanding that I needed to swap inputs. I want to be sure because this is my DD and toy all in one.
post #58 of 3358 Old 01-19-2010, 11:01 AM Thread Starter
JrMechanic
96+ V8 ZJ's are known as the easiest swap as 96-98 4.0/Selec-Trac combos are very common, and they both share the .840" input shaft.
93-95 V8 ZJ's are generally a PITA because they all have the 1.55" input shaft.
I just added a few pictures to the original post.
post #59 of 3358 Old 01-28-2010, 07:05 AM
blues_brother
hello, a few days ago we make the tc swap from a 97 Cherokee to my 98 GC. No problem, it was an easy job without any mods on the tc. Just pull out the 249 and put in the 242. After adjusting the linkage everything works fine. Thank you for the infos of this thread, it helps me by giving me the kick to do this mod. Ps sorry for my bad english, school time is far away.Dany.
blues_brother is offline
post #60 of 3358 Old 01-28-2010, 09:59 AM Thread Starter
JrMechanic
Glad I could help, that's why I took the time to make this thread
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
