Transfer Case Swap Info NP249->NP231 & NP242 - Page 36 - JeepForum.com
 9Likes
post #526 of 3318 Old 06-21-2011, 06:56 AM
csouers
Originally Posted by dlvsdh View Post
i have a 95 249 do i have the new or old gear cut ive herd 95 is the year change but here is says 94.5 and down how do i know
Does it say 95 on the case or are you going by the year of your Jeep?
Originally Posted by Timon View Post
I found a 231 from a 1993 XJ will this be a bolt on? Or will I have to open it?
I dont know what AT I have, but the car is registered in 1992, the shifter sais 1.2, 3, D, N, R, P and its a 4.0 I6. The transfer case is a 249.
I can also get a 242 from a 1990 XJ a lot cheaper, but that one has the 21 spline input right?
So, which one to buy?
Depends on the transmission. You need to find that out first.
1998 Bright Platinum ZJ 5.9 Limited - 5.9l, 46RE, NV-242, D30/44a (Trac-Loc) w/3.73s -
1999 White XJ Sport - 4.0l, AW4, NP-231, D30/8.25 w/3.55s -
csouers is offline
post #527 of 3318 Old 06-21-2011, 07:41 AM
Timon
How can I find out, without removing the TC?
1993 Grand Cherokee Limited 4.0 4x4 AT
Timon is offline
post #528 of 3318 Old 06-21-2011, 08:50 AM
csouers
The metal tag will say "9x x". Replace x with whatever I says.
csouers is offline
post #529 of 3318 Old 06-21-2011, 08:56 AM
dlvsdh
i went by the tag it says 95 3
95, zj, ORVIS, Iro critical path, 1 tons, 35's etc.
dlvsdh is offline
post #530 of 3318 Old 06-21-2011, 10:11 AM
csouers
Ok. You have the new cut.
csouers is offline
post #531 of 3318 Old 06-21-2011, 11:28 AM
nadman009
1994 ZJ
I just swapped a 242 in for a 249 in my 94 limited. I found the red and black wires, just like in the pictures, I unhooked the red and plugged in the black, but nothing happened. My VIC just says "Service 4WD switch".
What should I do?
'94 ZJ 5.2 V8
Temporary fix is still a fix!
nadman009 is offline
post #532 of 3318 Old 06-21-2011, 03:21 PM
Timon
My car:
92 1
Will the 231 fit?
Timon is offline
post #533 of 3318 Old 06-21-2011, 03:56 PM
csouers
My car:
92 1
Will the 231 fit?
Sorry for the confusion. When I talk about the build date and gear cuts, that is when swapping the input shaft from the inside of the old transfer case to the new one.
There are instances when this is not necessary if you're lucky. Your Jeep could have either the AW4 or 42re, thus having either the .750" or .840" input shaft.
So, really, you're going to have to pull the case currently installed in your Jeep off to see how far the input sticks out past the housing. If it is the same on each case, it should be a direct swap, which would be good news!
csouers is offline
post #534 of 3318 Old 06-21-2011, 04:00 PM
csouers
What should I do?
Did it say service 4wd switch before?
csouers is offline
post #535 of 3318 Old 06-21-2011, 07:11 PM
rob_kennedy
Done!
I done this swap 249-->242 this past weekend with no problems what so ever!! The 96 zj limited w the 249 has a .840" input shaft, I said that cuz I'm sure someone is searching for right now! I scored a 242 out of XJ with a build date of 1/96. It fit perfect. Only question I have now is about the linkage, I have F***ed with the old 249's linkage all week and I still can't get it right, the shaft that the linkage pivots on is almost completely screwed now that to my hard headedness "if it don't work make it work" ideas. Any suggestions???? Nydriver could not of done this with your tread thx
rob_kennedy is offline
post #536 of 3318 Old 06-21-2011, 09:53 PM
csouers
@Rob, awesome! You honestly got lucky. I've never seen a 95 with the .840" input. That was 96 and up thing. Nice find.
csouers is offline
post #537 of 3318 Old 06-21-2011, 10:07 PM
speedbucket
its normal to have spider cracks all over the inside of the case right?
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #538 of 3318 Old 06-21-2011, 10:42 PM
dlvsdh
great thanks
dlvsdh is offline
post #539 of 3318 Old 06-22-2011, 06:03 PM
jnjtrevino
1994 ZJ
what would happen if you put in a tcase with a shorter input shaft?
You laugh because I'm different...........
I laugh cause I just farted!
jnjtrevino is offline
post #540 of 3318 Old 06-22-2011, 06:15 PM
csouers
Every case I've seen has been like that. I'm assuming it's from the forging process. As long as it's not cracked all the way through, you're fine.
It wouldn't properly seat against the output shaft/seal of the transmission and bad bad things would happen.
csouers is offline
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 08:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 01:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 05:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 07:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 12:50 PM
