Transfer Case Swap Info NP249->NP231 & NP242 - Page 27 - JeepForum.com
 12Likes
post #391 of 3412 Old 03-31-2011, 02:39 PM
PlatinumNiner
Disagree since i have had mine in for 6 months with no mods at all and no issues at all.
PlatinumNiner is offline
post #392 of 3412 Old 03-31-2011, 02:46 PM
Candymancan
Anyone know what this hole is ? I drove an hour to pick up a 97 NV242 and i noticed there was some kind of hole by the shift plate on the transfercase. I couldnt find this hole on my 249, so i decided to take a picture and drive back home before i bought it.
Could anyone tell me what this is ?
Candymancan is offline
post #393 of 3412 Old 04-01-2011, 12:48 PM
FamilyCrawler
The hole does not look normal. I would stay away.
Rowdie, I have a front DS off my 5.9, if you were closer I'd say come get it. Since I went to a differnt TC and double cardons I don't need it anymore.
FamilyCrawler is offline
post #394 of 3412 Old 04-01-2011, 01:01 PM
jlipka98zj
I can't see the picture since I am at work. However, I would *GUESS* that the hole is the access hole to the roll pin in the shift rail. The 242 has this hole, the 249 does NOT (since it only has a single shift fork).
I guess what I am saying is that if the picture is of what I think it is, this is perfectly normal. A little rubber plug normally fits in this hole. I will check the picture when I get home and I don't have a super-restrictive firewall blocking my access.
'98 5.9 Limited - Got some stuff done to it...
jlipka98zj is offline
post #395 of 3412 Old 04-01-2011, 02:14 PM
PurpleZJ
^ yes that hole is normal. my 242 had this same hole its fine. find a way to plug it and you'll be fine.
1996 ZJ- 4.0, AX-15 5SPD/NP242, RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
RIP Troy (bigbluezj94) you wont be forgotten
December 2010 GCOTM
5spd ZJ Club Member 001
Glad you are ok. If you were a cat, you would be down to 8.:D
Originally Posted by Greengc4x4 View Post
Everything looks great, Hellen Keller! :D
Originally Posted by rritch View Post
plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:
RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11
PurpleZJ is offline
post #396 of 3412 Old 04-01-2011, 02:15 PM
jlipka98zj
The factory rubber plug is still available from Mopar. It was like $3 if I recall. My 242 rebuild kit also came with one. I bought the one off ebay.
post #397 of 3412 Old 04-01-2011, 02:57 PM
charlesshoults
When I did my 242 swap, the housing on the 242 was cracked, so I had to use the front shell of my 249. I put a drill bit in the 242 hole to establish the size, then drilled a hole in the same location on my old 249, then reused the pug, securing it with RTV.
charlesshoults is offline
post #398 of 3412 Old 04-01-2011, 07:12 PM
XJ86Fever
Wondering about this and not being a wise guy, could it be because your 6" lift???
Just bought a 242 (going to rebuild it JIC) to replace the 249 in my V8 '97, so I'm curious. Haven't had any luck finding a ZJ ESY 242 DS at the pick-a-parts.
Seems to me that if the ESY TC is 1.5" longer there could be a problem specially if one is running a D44 HD (been told those too are a bit longer than the 35's) and sitting at stock height.
Not saying it can't work but probably giving up a bit of DS slip distance.
Anyway great writeup JrMechanic, thanks for doing it and keeping up with it.
XJ86Fever is offline
post #399 of 3412 Old 04-01-2011, 07:14 PM
PlatinumNiner
My ZJ has the 242 and thats at stock ride height. XJ have the 6.5" lift with a 231 and SYE
post #400 of 3412 Old 04-01-2011, 07:16 PM
PlatinumNiner
Here is my case installed on my 5.9 It has 3/4"-1" before the yoke would bottom out on the shaft. Has been this was since about october and it is my daily driver. No issues at all.
post #401 of 3412 Old 04-01-2011, 08:01 PM
Candymancan
I orderd a new VC instead, decided id rather keep the AWD option rather then getting a different case.
The one I orderd says its for 91 and up 249's, there was another one from a diff seller tho and his says 97 and up On demand , and he has a seprete one for 96 and under full time 4x4.
Are there really 2 different kinds of VC's ? Hope i didnt get the wrong one. This is the one i got VIA newfire's recomendation but im wondering if this is for the Fulltime 249 and not the On demand one. Is there really a difference between the VC's ?
http://cgi.ebay.com/ebaymotors/NEW-P...mZ360352022068
post #402 of 3412 Old 04-01-2011, 08:14 PM
PlatinumNiner
Looks like the one i removed from my 249 but maybe you should ask the seller before you buy.
post #403 of 3412 Old 04-01-2011, 08:22 PM
Candymancan
edit
post #404 of 3412 Old 04-01-2011, 09:02 PM
PlatinumNiner
Every 249 is "full time" or AWD there is nothing on demand about AWD. You have no choice but to be in 4WD which sux. Thats why people upgrade to the 242.
post #405 of 3412 Old 04-01-2011, 09:15 PM
Candymancan
edit:
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
