Transfer Case Swap Info NP249->NP231 & NP242 - Page 26 - JeepForum.com
 14Likes
post #376 of 3441 Old 03-30-2011, 11:06 AM
PlatinumNiner
The 96-98 242 is a DIRECT swap for the 96-98 249 and no driveshaft mods are needed. I think people really need to start reading. This thread is great but it's full of useless questions that were already answered 15 times over.
PlatinumNiner is offline
post #377 of 3441 Old 03-30-2011, 12:14 PM
solomon8718
Well, the OP did give specific years but didn't explicitly say that compatibility included the five nines. It also would have been good for the OP to make note about the shift lever incompatibility.
solomon8718 is offline
post #378 of 3441 Old 03-30-2011, 12:50 PM
Candymancan
Yea no one has said anything about a 5.9 tho, i have seen some direct swap's with them but the drive shaft were also close to bottoming out against the slipyoke on the TC. Doesnt sound too safe too me specially if you are carryng a heavy load. Im sure to be safe you have to shorten the drive shaft.
I haul really heavy loads in my 5.9 in the trunk sometimes close to the max limit. Around 800 pounds, if the 242 has a longer slip yoke then that would shove the Drive shaft into my TC im thinking.
Candymancan is offline
post #379 of 3441 Old 03-30-2011, 02:27 PM
solomon8718
Originally Posted by Candymancan View Post
Yea no one has said anything abo*******[/PHP]ut a 5.9 tho, i have seen some direct swap's with them but the drive shaft were also close to bottoming out against the slipyoke on the TC. Doesnt sound too safe too me specially if you are carryng a heavy load. Im sure to be safe you have to shorten the drive shaft.
wouldnt it hit the bump stops before that happened?
post #380 of 3441 Old 03-30-2011, 08:43 PM
denso
thank-you very much!
[QUOTE=PlatinumNiner;11270713]The 96-98 242 is a DIRECT swap for the 96-98 249 and no driveshaft mods are needed. I think people really need to start reading. This thread is great but it's full of useless questions that were already answered 15 times over.
thanx,thats all I wanted to know all along!
denso is offline
post #381 of 3441 Old 03-30-2011, 09:21 PM
PlatinumNiner
249 behind the 5.2 and 5.9 are no different. When your ZJ squate the shafy gets longer. When it lifts the shaft gets shorter. Your heavy load actually helps the shaft not bottom out. I did it on my 5.9 and i have about 3/4" before the shaft bottoms out. The shaft slips 1/4" if that. You have nothing to worry about. If your worried, cut 1/2" off the driveshaft yoke.
post #382 of 3441 Old 03-31-2011, 05:17 AM
Candymancan
So i have it backwords ? Heavy loads pull the shaft out ? I thought it pushes the shaft in, and a lift pulls the shaft out ?
What happens with 800 pounds when you hit a bump on the road. The Jeep does swing up and down quiet a bit from that, i watch it through the rear mirror Its kinda funny to watch. I know i can shorten the driven shaft, but cutting it on the yoke end i dunno would that cause the shaft to be unbalenced? I would think cutting the shaft the real way and then have it balenced would be better. You know i saw a guy who cut the yoke end of the transfercase, i wonderd how that actually helps because wouldnt the drive shaft yoke still be too long ? Gah so confusing.
Thanks for the vote of confidence, not having to cut anything saves me $80, just worried that i should, i read a story once where a guy didnt do it and it bashed his TC and caused all kinds of vibration problems after that
Well hopefully the guy on this forum comes through for me, and sells me his 242, he lives 30m away and wanted $250 for it with the drive shaft, bezel and linkage. I offerd him $200 because i dont need the drive shaft and im cash short.. I have to pay a shop $200 to swap it for me because im not too confident in myself yet to do it myself lol. I should probably do it myself tho because the $200 i can spend on a Jack and stands and tools that i can re-use down the road..
post #383 of 3441 Old 03-31-2011, 08:03 AM
FamilyCrawler
I have a 98 5.9 and did the swap, but I also put an SYE kit on mine. I had to cut the shift shaft 1" and reweld along with putting a slight bend so it would no longer hit the cross linkage shaft. I also replaced both drive shafts front and rear with new double cardon types. The only problem I was having was the transfer case was popping out of 4WLo bu that was before I odofied the linkage. Haven't had it out in extreme conditions since. Hope to test it in a few weeks. I use a 89' 231 TC and the input shaft was the same!
FamilyCrawler is offline
post #384 of 3441 Old 03-31-2011, 08:19 AM
Candymancan
The shift shaft ?
post #385 of 3441 Old 03-31-2011, 09:59 AM
FamilyCrawler
What I called the shift shaft is the linkage shaft. Has knobs on both ends and connects to the TC palte the the upper shift linkage. Sorry about that. Maybe I will take some photos later and post.
post #386 of 3441 Old 03-31-2011, 11:51 AM
PlatinumNiner
Candyman you will not throw off balance by cutting a hair off the yoke on the driveshaft. You could probably cut the same 1" ouf of the tube, weld the end back on, and drive away with out ever having a vibration.
post #387 of 3441 Old 03-31-2011, 01:12 PM
rowdiebryan
hello from texas
Hi everyone, my name is bryan, most who know me call me Rowdie..
I just bought another Grand Cherokee. i have had several old jeeps, CJ to Cherokee, this is my first Grand. I purchased a 5.9 limited to use as a tow behind for my motor home.
Its had a hard life, but I will get it put back together soon. Looking for a front drive shaft for it. Among a few other thigns. Also, found this site while reserching Transfer cases. I would like to be able to pull this thing with all four wheels flat on the ground. Not sure I can do that with out alot of mods witht he stock TC. I have the NV 249 ( I think ) and after reading I beleive I would like to go with the NP249 Any thoughts?
Thanks everyone, and be safe
Rowdie
rowdiebryan is offline
post #388 of 3441 Old 03-31-2011, 01:15 PM
squazz
squazz is offline
post #389 of 3441 Old 03-31-2011, 01:49 PM
PlatinumNiner
^ LOL yea my thoughts exactly
Rowdie, read your manual. You can tow with all 4 wheels on the ground perfectly safe with the 249. Dont quote me but i believe all you gota do is put the t-case in neutral Like i said though read your manual and it will tell you all about it.
post #390 of 3441 Old 03-31-2011, 02:15 PM Thread Starter
JrMechanic
This is false. You need to shorten the rear drive shaft approximately 1.5" whenever you go from an internal slip yoke to the external style.
I don't recommend cutting the slip yoke or the transfer case output.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
