Transfer Case Swap Info NP249->NP231 & NP242 - Page 2 - JeepForum.com
 15Likes
post #16 of 3442 Old 02-03-2009, 01:38 PM Thread Starter
JrMechanic
You positive? It looks identical to my black plug. Anyways, the black plug only uses 1 wire and the red uses 2, the plugs aren't the same.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #17 of 3442 Old 02-03-2009, 01:43 PM
BLACKzj52
yup, the bottom right one is the one that goes to my VIC 100% sure
BLACKzj52 is offline
post #18 of 3442 Old 02-03-2009, 01:52 PM
j.love
j.love's Avatar
1994 ZJ
I'm trying to remember this wiring thing, but I think you unplug the red connector. and then in that same wire bundle that the red connector is in there should be a black connector that isn't connected that needs to get plunged in. I think its a total separate black connector male and female. just like the red has a male and female. from what I remember you don't connect red to black.
David.
94 ZJ laredo 5.9 V8 swap D44a posi
Originally Posted by ratmonkey View Post
I wouldn't drive down a driveway on that.
''If we do everything right, if we do it with absolute certainty, there's still a 30% chance we're going to get it wrong.''
Joe Biden
j.love is offline
post #19 of 3442 Old 02-03-2009, 01:55 PM
BLACKzj52
ah im getting somewhat confused.
anybody got any actual pics of the plugs correctly plugged in and stuff?
post #20 of 3442 Old 02-03-2009, 01:58 PM Thread Starter
JrMechanic
I meant the one I have circled. That goes to the cigarette lighter? If it does, there's one that looks exactly like it, and another female connector somewhere in the bundle.
post #21 of 3442 Old 02-03-2009, 02:04 PM
BLACKzj52
yeah the one you have circle goes to the lighter.
so theres another black female connector somewhere in that bundle of wires, and i need to disconnect the red on and plug it in to the other black one? is that what im hearing?
post #22 of 3442 Old 02-03-2009, 02:08 PM Thread Starter
JrMechanic
No. There are 2 black plugs. One female, and one male somewhere in the bundle. Im going out to fix a power steering fluid leak here soon, I can take it apart again for a pic.
post #23 of 3442 Old 02-03-2009, 02:11 PM
BLACKzj52
ok thanks man
post #24 of 3442 Old 02-03-2009, 02:15 PM
j.love
j.love's Avatar
1994 ZJ
2 red plugs (male and female) and two black plugs (male and female). unplug the red and plug in the black.
You do know the difference between male and female don't you? Or do we have to explain that to you too?
David.
Joe Biden
j.love is offline
post #25 of 3442 Old 02-03-2009, 02:34 PM
BLACKzj52
you might have to explain that one
post #26 of 3442 Old 02-03-2009, 03:45 PM
j.love
j.love's Avatar
1994 ZJ
Tab "A" goes into slot "B"
If you try and put tab "A" into another tab "A" then that is called a "FAIL!"
David.
Joe Biden
j.love is offline
post #27 of 3442 Old 02-03-2009, 05:54 PM Thread Starter
JrMechanic
Thats what I said. Adding the VIC plug DIY now...
post #28 of 3442 Old 02-03-2009, 05:56 PM
BLACKzj52
lol this made me chuckle
jr did u take any pics?
post #29 of 3442 Old 02-03-2009, 06:08 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
there's that red connector, there's a black connector that's exactly the same as that one further up the loom to the right, the tab on it is backwards from the red one and cannot be plugged into the red. there's a one wire black one right in the middle that isn't plugged in. it'll be under the tape to the right of where the vic and hvac plugs branch off.
what i get when i plug various combinations in, anything with the red plugged in gives me 4wd switch malf in 4ft, reads n right and that's it. with the single wire black just plugged in, i get the 2 rear wheels lit up in anything other than 4ft and n, which read correctly. with the black 2 wire and the single wire plugged in i get the same readings.
part time and lo do not read for some reason.
ratmonkey is offline
post #30 of 3442 Old 02-03-2009, 06:25 PM Thread Starter
JrMechanic
VIC write up is now added to the original post.
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
