Transfer Case Swap Info NP249->NP231 & NP242 - Page 19 - JeepForum.com
 15Likes
post #271 of 3442 Old 02-08-2011, 08:56 PM
harwood909
Question: Would a 99 WJ NV242 case work? I've been searching and searching for shaft length and spline counts, but have come up empty handed. Bolting it to a 94 AX15 tranny, currently have a 249.
Custom Machined Budget Boost
Literally Built
harwood909 is offline
post #272 of 3442 Old 02-08-2011, 09:05 PM
Virmagicus
Virmagicus's Avatar
No speedo hole on the dubs. Easier to find a ZJ unless you want to fork out the cash for a SYE from Tom Woods. You will have no core though.
Jeff
Virmagicus is offline
post #273 of 3442 Old 02-09-2011, 09:15 AM
Grandplans
I have a 242 transfer case out of a '93 ZJ that I plan on using to replace my worn out viscous coupling 249 in my '97 ZJ. Input shaft lengths are correct, so this should be a direct swap. After cleaning all the grease and crud off the donor 242, I discovered some JB Weld around the filler hole for the transfer case. Looks like someone in the past cranked on the filler plug and cracked or broke the case around the filler plug. I don't trust this patch job and will replace the back half of the transfer case. Anyone know if I can just use my 249 back half to replace the 242 back half (not changing any internals)? I know the tail shafts are different and those unbolt and can be swapped. The only thing I want from the 249 is the back of the case.
Grandplans is offline
post #274 of 3442 Old 02-14-2011, 06:58 PM
Darman
is there some website to tell you if your TC has the new or old gear cut? My jeep is a 95 and im going to assume right now, as its too dark to check, that my TC will be made around 94.5. So is there a site that lists serial numbers of the TCs with the old cut and new cut?
Darman is offline
post #275 of 3442 Old 02-16-2011, 03:12 PM
PlatinumNiner
I believe anything 1991 and newer is the new cut.
PlatinumNiner is offline
post #276 of 3442 Old 02-16-2011, 03:37 PM
Darman
crawled under my jeep today and took a picture of the metal tag. Does anyone know if this has the new or old style gear cut?
Darman is offline
post #277 of 3442 Old 02-18-2011, 02:06 PM
speedbucket
faq says the cut change was mid 94. if your border line i think you have to pull out and check
speedbucket is offline
post #278 of 3442 Old 02-18-2011, 09:40 PM
PlatinumNiner
I believe the code on that case shows december of 1994 so he should be safe to say its the new cut.
post #279 of 3442 Old 02-19-2011, 12:16 AM
Virmagicus
Virmagicus's Avatar
Yep. December 6th 1994. 99% sure it will be the new.
Jeff
post #280 of 3442 Old 02-20-2011, 03:51 PM
mark4370
What is the performance like after you do the 249 to 242 swap in a I6?
mark4370 is offline
post #281 of 3442 Old 02-20-2011, 04:20 PM
PlatinumNiner
Still sux lol
post #282 of 3442 Old 02-20-2011, 05:12 PM
mark4370
Still sux lol
Ha that bad LOL Is the acceleration a little better? lol
mark4370 is offline
post #283 of 3442 Old 02-20-2011, 05:42 PM
PlatinumNiner
lol im just busting your chops i honestly love the 4.0 May not be a beast but they are amazing engines. You will get a little bit better gas mileage and a little better performance. Dont expect the world but yes you will notice a difference. You gota fill out your profile. What year is your ZJ?
post #284 of 3442 Old 02-20-2011, 05:50 PM
mark4370
It's a 97 STI .
mark4370 is offline
post #285 of 3442 Old 02-20-2011, 05:54 PM
PurpleZJ
^TSI not STI bud....
1996 ZJ- 4.0, AX-15 5SPD/NP242, RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
RIP Troy (bigbluezj94) you wont be forgotten
December 2010 GCOTM
5spd ZJ Club Member 001
Glad you are ok. If you were a cat, you would be down to 8.:D
Originally Posted by Greengc4x4 View Post
Everything looks great, Hellen Keller! :D
Originally Posted by rritch View Post
plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:
RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11
PurpleZJ is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
