Transfer Case Swap Info NP249->NP231 & NP242 - Page 18 - JeepForum.com
 9Likes
post #256 of 3318 Old 01-23-2011, 11:27 AM
Grandplans
I may have found the answer to question without having to pull the transfer case from the '93. Not 100% sure, but I believe that this year 242 in a ZJ with 6 cyclinder will have the 1.550" input shaft and not the .840" like I think my '97 ZJ has.
Grandplans is offline
post #257 of 3318 Old 01-27-2011, 12:16 AM
ZebraZJ
From what year and model would I find 231 t/c will work in a 98 ZJ w/5.2 I believe it is a .840 23 spline.
Tim
1998 Jeep Grand Cherokee Limited "Casper" 5.2 - stock for now
White jeep club #135
Colorado Jeep Club #212
US Air Force Jeep club #118
ZebraZJ is offline
post #258 of 3318 Old 01-27-2011, 12:53 PM
MurdaJs
Tim
http://www.drivetrain.com/parts_cata...arts/jeep.html
MurdaJs is offline
post #259 of 3318 Old 01-28-2011, 01:50 AM
wildcatkit52
Okay this is a great thread! Too great...
I have a friend that has a 98 Grand Cherokee Limited and it has been "funny" since he got it. He thought it must have a problem with the rear axle and/or front axle.
He managed to drive it with the little issues and noise. It has been sitting for some time now and he is wanting to fix the few issues and drive it. I told him today that it is likely the transfer case after he explained in more detail what it is doing.
After some internet research I determined that he should put in a 231. Great. What to get it out of? I found that here in this thread! Go me!
I start doing more research on how to find the right donor vehicle and see the 241 with 4 to 1 gear reduction...
My questions for the man that seems to know it all here...
CAN my friend use a 241 in his ride? Is it worth while over the 231 behind the 360? What all is required as far as drive shaft modification, linkage issues, etc. might we run into?
Any help would be great if you can!
wildcatkit52 is offline
post #260 of 3318 Old 01-28-2011, 08:26 AM
project_zj
The stock linkage should work.
project_zj is offline
post #261 of 3318 Old 01-28-2011, 08:34 PM
MurdaJs
Im pretty sure its been done. From what ive read the 241 from rubicons have an .840" input shaft, same as 96-98 ZJs
Linkage shouldnt be a problem, just make sure to use the tab on the donor tcase.
Driveshaft may or may not need cut and rebalancing
MurdaJs is offline
post #262 of 3318 Old 01-30-2011, 05:23 PM Thread Starter
JrMechanic
Only the 249 behind 93-95 V8's had the long 1.55" input. If the transmission is indeed different in the Jeep you were looking at, it would be the AW4. It would either have the .750 or .840" input, I'm not 100% positive on which one. If it is the shorter of the two, the . 090" shouldn't make much of a difference.
As for the 241OR, it will bolt up in place of existing cases with a .840" input, but that's about it. The OR utilizes a flanged 32 spline rear output, a 1330 front output yoke, and a different speed sensor than the typical gear driven ZJ sensor. Definitely not one of the most difficult swaps out there, but it's far from a direct replacement like a 231 or 242.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #263 of 3318 Old 01-31-2011, 12:04 AM
FALudwig
1994 ZJ
Quick question:
I have a '94 GC 5.2 with a 249 TC. I'd like to do a straight transfer as my VC seems to be dying on me.
Can I use a 249 transfer case from any model Jeep from '93 to '95?
I want to go sopping online to find a replacement and wanted to narrow down the selections.
Thanks
FALudwig is offline
post #264 of 3318 Old 01-31-2011, 12:10 AM
Virmagicus
Virmagicus's Avatar
Originally Posted by FALudwig View Post
Quick question:
Thanks
You will need a 93-95 with a V8 to be a direct swap. You can just replace the viscous coupler (VC) though without pulling the whole transfer case (TC)
Jeff
Virmagicus is offline
post #265 of 3318 Old 01-31-2011, 08:57 AM
jlipka98zj
Has anyone ever done just a VC replacement? I'd be curious about how hard it is to do in the vehicle.
I keep going back to when a guy mentioned that a 249 with a WORKING VC is really difficult to beat in terms of transfer case performance. Overall, I am satisfied with my 242 swap but I got lucky in finding a direct swap TC with an SYE kit already installed locally for an unbeatable price. If someone has done a VC replacement and felt it was definitely worth the money, I may have considered it.
Any writeups out there for a VC replacement?
'98 5.9 Limited - Got some stuff done to it...
jlipka98zj is offline
post #266 of 3318 Old 01-31-2011, 07:46 PM
cirame1
Did my 242 swap a while back and just got around to changing my vic connectors today. Now it shows all modes correctly! I have a question regarding the linkage. The shop that did the swap used my original 249 linkage and as you know its a bit shorter, whn i shift the linkage it only shifts into 4 part time and nothing else then doesnt go back into 2wd. i an do it manually but seems that the linkage is not adjusted riteand to short. where can i get a full 242 linkage assembly.
98' 5.9 slate on slate...
3.5" F>R swap, front and rear adj. track bars
17" rubicons w/ 285 70 17 inch hankook mtr's
full 3 inch exhaust w/flowmaster 40 series
242j tcase swap completed by jeeps unlimited providence,R.I.
cirame1 is offline
post #267 of 3318 Old 02-05-2011, 12:55 PM
optimaldave
So we are confident that this site is correct?
If so then my 96ZJ can take a 242 from a 96-8ZJ or 97-01 XJ? Can someone verify this?
Cheers
Dave
optimaldave is offline
post #268 of 3318 Old 02-05-2011, 01:30 PM
PurpleZJ
i have a 96 zj and whilst swapping from a 42re auto to ax-15 manual i swapped in a 242 from a 00-01 xj. bolted right up. so yes you can get a 242 from a 97-01 xj
1996 ZJ- 4.0, AX-15 5SPD/NP242, RE 4.5" lift, 36x12.50x16.5 Goodyear military surplus tires, Longarms/Tri-4 link/one ton axle build/swap in progress, arb bumper, a bunch of other goodies
1995 XJ- 4.0 HO, ax-15(stolen for swap), stock
2001 GMC Sonoma-RIP...
2002 GMC Sierra 1500 ECSB-roadtrip/long haul vehicle
RIP Troy (bigbluezj94) you wont be forgotten
December 2010 GCOTM
5spd ZJ Club Member 001
Glad you are ok. If you were a cat, you would be down to 8.:D
Originally Posted by Greengc4x4 View Post
Everything looks great, Hellen Keller! :D
Originally Posted by rritch View Post
plastic + Fuel + Ignition = "Bubba wake up this is gonna be good" :rofl:
RIP William Anthony Kolich(DAD)
you were the best father i could have wished for. I'll always miss you
04/28/58-2/13/11
PurpleZJ is offline
post #269 of 3318 Old 02-05-2011, 02:05 PM
optimaldave
Awesome, Cheers
post #270 of 3318 Old 02-06-2011, 02:45 PM
ArmyVet717
Ok... I recently (This Past Friday), picked up my ZJ after having some (ok, a lot!) of work done. Included was a 242 swap since my VC was on it's way to full FUBAR. My VIC is not screaming at me because of the swap. If I read correctly, unless I missed something (which at my age is highly possible), all I have to do is tear apart my dash, unplug the red connector, plug in the black unplugged connector (not for the cig lighter), and the VIC will recognize my 242 gear selection???
Nice write up by the way!!! Sooner or later, I will start understanding this "Jeep Thing" better!
'96 Grand Cherokee Laredo, 5.2L, NP242 Swap, Closing in on 300K miles, 4.5" RE lift, Tow Pig: 04 Dodge Durango SLT, 4.7L
http://www.facebook.com/#!/smontgomery717
ArmyVet717 is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 08:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 01:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 05:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 07:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 12:50 PM
