Transfer Case Swap Info NP249->NP231 & NP242 - Page 154 - JeepForum.com
 14Likes
post #2296 of 3442 Old 07-14-2014, 07:35 AM
WildTornado77
I am bolting in the slip yoke to the transfer case. Installed a Dana 30 pinion seal in Dana 35 rear axle. Installed a front output yoke of 231 t-case as pinion yoke. Then I am installing a front driveshaft in rear backwards. Double cardagine joint at pinion yoke. I will show pics when finished.
WildTornado77 is offline
post #2297 of 3442 Old 07-15-2014, 01:35 AM
WildTornado77
I think I figured out my 231 transfer case issue. I watched a video of a rebuild and I reassembled the yoke forks wrong, time to remove and crack open. I will take before and after pics.
post #2298 of 3442 Old 07-16-2014, 11:55 PM
WildTornado77
Here are the before and after pics.
post #2299 of 3442 Old 07-17-2014, 02:39 PM
ZJshortbus
The 231 that I bought has studs for the transmission that I want to replace. In shipment, they got slightly bent. I can't find replacements anywhere, so if anyone has a suggestion as to where I could get them that would be a huge help.
ZJshortbus is offline
post #2300 of 3442 Old 07-18-2014, 12:25 AM
WildTornado77
I can remove mine of my old 249 and send then to you for shipping cost from 06351, jewett city, ct.
post #2301 of 3442 Old 07-19-2014, 11:38 PM
iann32
I too have left over studs if you need them.
iann32 is offline
post #2302 of 3442 Old 07-20-2014, 07:41 AM
iann32
Why do they have you use linkage from the 231? I did my swap yesterday and had to use the one from my 249. The 231 linkage was too short and 249 linkage worked fine and I get all my modes.
iann32 is offline
post #2303 of 3442 Old 07-20-2014, 08:04 AM
94cherry
1994 ZJ
I used the stock linkage on my 94 249 to 242 and used the stock linkage on my 95 231 to 242 with no problems.
Kiss my shiny metal bumper.
94cherry is offline
post #2304 of 3442 Old 07-20-2014, 10:01 AM
WildTornado77
iann32 thanks for the help on the setting of my shift linkage on my swap. When I split case open I reassembled front low range fork incorrectly as you can see in my pics pervious. My friend and I finished it then did a test drive worked fine all four gears and then toasted front left rotor. Now replacing, calipers, rotor and pads on both front.
post #2305 of 3442 Old 07-26-2014, 03:43 PM
unabashedpraise
Can you put a 249 tail housing on a 242 with external slip yoke?
1998 Grand Cherokee Limited; 5.2 L, 249
Help: Rear left lock doesn't lock using power locks, but will unlock. Any ideas?
unabashedpraise is offline
post #2306 of 3442 Old 07-26-2014, 06:27 PM
94cherry
1994 ZJ
No.
94cherry is offline
post #2307 of 3442 Old 07-26-2014, 06:31 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
did my 231 swap today on my 98. used a 231 from an 01 XJ. Stock 249 linkage worked great with no adjustment needed.
Did have to shorten my drive shaft just over an inch however. nice to have 2wd when i want, and hopefully no more broke front axles from my tight VC in the 249.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #2308 of 3442 Old 07-27-2014, 01:31 AM
unabashedpraise
Originally Posted by 94cherry View Post
No.
Booooo. Thought so, just hoping.
post #2309 of 3442 Old 08-12-2014, 08:49 PM
Bigdogg
I am new and have read this over and over it is great. I am going to the yard and getting a 231 my 249 cv is going. I gave read and am sure if I get the 96-01 XJ 231 it sounds line a direct swap. Who ever has done this if they could guide me I have to do this over the weekend and need it to at least drive in 2wd. I have a 98 grand 5.9 limited thanks.
Bigdogg is offline
post #2310 of 3442 Old 08-13-2014, 04:15 PM
Bigdogg
Anyone?
Bigdogg is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
