Transfer Case Swap Info NP249->NP231 & NP242 - Page 140 - JeepForum.com
 9Likes
post #2086 of 3318 Old 04-14-2014, 01:31 PM
ejschultz
ejschultz's Avatar
The wiring harnesses were up behind my HVAC controls rather than right behind the VIC. Check there first before you go pulling your hair out wondering where they're at. I think they're only behind the VIC for 93-95 models.
01 TJ - 4.0L, NV3550, 2" Skyjacker budget boost, Trail Gear front bumper, 31" Duratracs on 15x8s
ejschultz is offline
post #2087 of 3318 Old 04-14-2014, 06:12 PM
smccloud
Can a 242 with external slip yoke be run in PT4 and no rear driveshaft until it can be cut down without issues?
Sent from my SM-N900V using JeepForum
smccloud is offline
post #2088 of 3318 Old 04-14-2014, 06:49 PM
mrgimble
2015 JK Wrangler
Can anyone tell if this is the .84 or .75 input length?
mrgimble is offline
post #2089 of 3318 Old 04-15-2014, 12:55 AM
WildTornado77
First find the proper way to measure. I think the only way to be sure is to open and remove the input shaft. From the pics on the first page and on web searching shows all side by side.
WildTornado77 is offline
post #2090 of 3318 Old 04-15-2014, 12:58 AM
D-rey
Mine were behind the VIC ('98 Limited).
D-rey is offline
post #2091 of 3318 Old 04-15-2014, 03:55 AM
ejschultz
ejschultz's Avatar
I stand corrected.
post #2092 of 3318 Old 04-15-2014, 04:50 AM
tucsonzj
I believe so but am not 100%
His:00 TJ "Fiona" stuff/stuff/stuff
95 ZJ 3.5" w/242 swap-Sold
Hers: 15 JK Sahara-3" Teraflex
tucsonzj is offline
post #2093 of 3318 Old 04-15-2014, 10:00 AM
MurdaJs
Yes, make sure it's 4 part time and not 4 full time.
MurdaJs is offline
post #2094 of 3318 Old 04-15-2014, 10:01 AM
MurdaJs
The top pic is the correct way to measure
MurdaJs is offline
post #2095 of 3318 Old 04-15-2014, 01:04 PM
mrgimble
2015 JK Wrangler
So i would say .75 then.
mrgimble is offline
post #2096 of 3318 Old 04-15-2014, 01:13 PM
smccloud
Yep, since 4 full time = not moving.
smccloud is offline
post #2097 of 3318 Old 04-16-2014, 12:33 AM
WildTornado77
A scale or depth mic, or even dial calipers would be better than tape measure. The tab on the end may give you a wrong measurement since it floats for carpenters.
post #2098 of 3318 Old 04-17-2014, 10:28 AM
thcheme
I am about to embark on my transfer case swap journey. I have a used 242 to replace my 249. I expect that I need to swap the input shaft. What other parts should I consider replacing? Just seals and such? Or the chain? I am going to start taking it out, possibly as soon as this weekend. I will have it open soon and should start acquiring the required parts. The donor case was out of the vehicle, and the only thing I know about it is that someone couldn't get the fill plug out and went after it with a bunch of pliars, saws, grinder, etc. This will have to be drilled, I think, to get out as the nut is mangled beyond recognition.
Is there a great place to get an all-inclusive kit of seals, etc? I found drivetrain.com that seems to have a pretty decent seal kit, or rebuild kit for the 242.
thcheme is offline
post #2099 of 3318 Old 04-21-2014, 05:56 PM
smccloud
Since my VC is just about gone and because my dad has offered to loan me the money to pick up a 242 (all of $75 but monies is tight with the spawn on the way now). I'm guessing the one from the GC, just want to make sure. Its going into a 1997 5.2 Laredo.
smccloud is offline
post #2100 of 3318 Old 04-21-2014, 06:04 PM
comptiger5000
Either one of those 242s should bolt right in.
comptiger5000 is offline
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 08:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 01:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 05:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 07:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 12:50 PM
