Transfer Case Swap Info NP249->NP231 & NP242 - Page 14 - JeepForum.com
 12Likes
post #196 of 3345 Old 11-27-2010, 09:00 PM
PlatinumNiner
Not sure what tranny you have but the 8.25 was never used in the ZJ. You have a dana 35 rear and dana 30 front
PlatinumNiner is offline
post #197 of 3345 Old 11-27-2010, 09:38 PM
anderob
1980 CJ7
That's terrible news. I have gone through a few dana 35s in some XJs and YJs.
I thought that only the 8.25s had the rubber plug in the cover.
anderob is offline
post #198 of 3345 Old 11-27-2010, 09:52 PM Thread Starter
JrMechanic
Nope, D35's have the rubber plug. As long as you don't wheel it too hard you'll be fine.
Your swap should be relatively easy as well. As you said, the transfer case will bolt right up. The rear drive shaft will be too long. I couldn't tell you if your XJ shafts would work, but it couldn't hurt to measure/hold them up and check.
If not, a shaft from a 96-98 4.0/NP242 (external slip yoke) ZJ will fit perfectly.
And you have a 42RE.
Want to swap an NP242 or NP231 into your ZJ? Here's how:
JrMechanic is offline
post #199 of 3345 Old 11-27-2010, 09:56 PM
anderob
1980 CJ7
Thanks! Both of the XJs had the Chrysler 8.25s in them. At least I think they did.
anderob is offline
post #200 of 3345 Old 11-29-2010, 12:33 AM
JustinLupyan
please help
I have a 97 zj 5.2 v8. I am wanting to swap the current quadra trac transfer case np249 with a 242. I know I will have to swap the input shaft. I plan on going to pullapart to pull the transfer case. But does it matter what year xj I pull it out of. Being that mine is a 97 and is obd2. Will I have to swap the sensors as well, or just the shaft. I want to do this swap and avoid annoying check engine lights or the vic beeping at me. Thank you in advance.
JustinLupyan is offline
post #201 of 3345 Old 11-30-2010, 12:29 PM
Lubo
1994 ZJ
Hi I have a 94 Grand Cherokee 4.0, tran. 42re, tc is 249J.
I had same problems with it .
Tha car startrs slowing down alot after the first 300fit it also pulls to the right side and when is about 5 ml per hr. I can hear the tires slip. This was a working 249J from 93 v8 grand Cherokee. My original 249J start clicking very loud when I go down hil and after few days was clicking all the time so I replaced it. I also instal a new transmission and torque convertor, new axel drives, new brackes new disks inspected diferential boxes.
I am runing out of ideas. If some one can help . Thanks
Lubo is offline
post #202 of 3345 Old 12-01-2010, 12:02 PM
Lubo
1994 ZJ
I just tried driving whit out the front d.s. it works fine no problems, but as soon as I put it back on the car starts to: when I pres the accelerator pedal starts to pull to the right side and as soon as I let go starts to slow down .
I have no idea can it be the front differential box or you think it is the TC?
Lubo is offline
post #203 of 3345 Old 12-01-2010, 12:05 PM
PlatinumNiner
Probably a bad transfer case. Sounds like the VC is shot and causing everything to bind up
post #204 of 3345 Old 12-01-2010, 12:13 PM
Oli
1994 ZJ
Hello,
I think my last question was lost with all the new posts, so here I go again:
Can I use the 4 prong plug 4wd switch that came out of my np249 to replace the np242 2 prong plug 4wd switch? I know Jr say in the OP that the np249 switch will work in the np242, but is it still true if the switch do not have the same connectors?
I have to lengthen the wires to reach the location of the switch on the np242, so before cutting thoses I would like to know if it will work.
Thanks !
Oli is offline
post #205 of 3345 Old 12-01-2010, 12:27 PM
PlatinumNiner
You need to use the 242 switch or the VIC wont display the proper gear selection. The only thing i had to swap over on my swap was the speedo sending unit. Plug was different and gear was different for different axle radios
post #206 of 3345 Old 12-02-2010, 07:21 AM
Oli
1994 ZJ
I wish my swap was as easy as yours...
I just realised than the younger np242 has the 4wd switch on the front case, engaged by the shift sector just like the np249. My np242 was pulled from a XJ 92, and the 4wd switch is located on the rear half, near the vehicule speed sensor, and is engaged by the shift rail.
I have looked at the schematic of the switch in the service manual of the 93 zj (page 8w-91) and it show a serial switch with 4 positions (N, 2wd, pt, ft) connected with the 4 prong connector. The problem is there is a single schematic and they make no distinction between np242, np249 and np231 switches. This is not really convenient if the switches are different.
If I look at my np249 and np242 switchs side by side, they look the same, except for the connector. So I guess my question is : is there a way to get the VIC to work with what I have? If not, can I get a switch that would work in my situation?
Thanks again !
Oli is offline
post #207 of 3345 Old 12-02-2010, 12:51 PM Thread Starter
JrMechanic
Thanks again !
Honestly, I've never tried to get the VIC to work with the older 242 case. In theory, it shouldn't be too hard.
If you switch looks the same, try installing it and see what happens. You may not be able to get 4 low to illuminate, but you may at least get part time to.
post #208 of 3345 Old 12-02-2010, 01:16 PM Thread Starter
JrMechanic
Well guys I added this to the original post:
****Currently, I am gauging interests for complete transfer case assemblies. I'm pretty flexible on what I can do, so shoot me a PM with your needs. Examples of services could include the location and shipping of complete used transfer cases intended to be a direct bolt in,
complete built to order transfer cases with new bearings, seals, shift pads, chains, VC's, and even the correct length input shaft for your application.
Used transfer cases will be inspected and guaranteed to be free of defects upon arrival with no implied warranty thereafter. Rebuilt transfer cases will carry an industry standard 18 month/unlimited mileage warranty
Installations are most definitely available as well!****
This is something I've been wanting to do for awhile now and I think I can make it happen. Once I get this up off the ground I'll take it up with the forum and make sure JF gets taken care of
post #209 of 3345 Old 12-02-2010, 09:43 PM
Lubo
1994 ZJ
I just install 242 from a 97 and switched my old 249. Tomorrow I will do my road test hope all the problems are gone
Thank you for some of your ideas.
Lubo is offline
post #210 of 3345 Old 12-02-2010, 10:07 PM
PlatinumNiner
Make sure its filled with fresh fluid!
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
NP231 vs. NP242 vs. NP249 offroader156 ZJ Grand Cherokee Forum 28 06-12-2016 07:40 PM
NP249 to NV249 Transfer case swap CDRFunkmeyer ZJ Grand Cherokee Forum 8 10-30-2009 12:39 PM
NP249 T-case dying & want to swap to a NP242 or NP231 IMin4Low ZJ Grand Cherokee Forum 15 10-02-2009 04:01 AM
UK NP249 Transfer Case Swap (+ PICS) UK Cherry ZJ Grand Cherokee Forum 4 07-12-2009 06:09 AM
NP249 to NP242 SWAP tb007 ZJ Grand Cherokee Forum 2 11-30-2004 11:50 AM
